Question about Samsung HT-DS610 System
Sound center and rear speaker jacks produces no sound, speakers play when plug into front and sub woofer jacks.
    Problem Solver:
  • 15 Answers
First check the settings of woofer or dvd player (keep in 5.1 mode and RAW)
mail me clearly about the problem,
Posted on Jan 27, 2009
Why Onkyo HTS-9400THX: Front both and subwoofer not working.?
Try differnt speakers, if they do not produce sound, amp channels may be blown and then you need to take it to a shop.
Aug 01, 2014 | Audio Players & Recorders
My dav-dz270 has no sound from the centre and rear speakers. only the sub-woofer and front speakers produce sound.
Make sure your sound mode is set to Dolby Pro logic II. This will force it to produce sound from all of the speakers.
Mar 13, 2011 | Sony DAV-DZ100 System
I been having a problem with my JBL TLX CSS-SUB1, I don't have the manual. Connecting speaker wires from the JBL TLX CSS-SUB1 to the a Digital Audio/Video Control Center ( it's a reciever) I confused,...
The connection on the receiver would be the sub woofer out. Not a sub woofer out LFE, a sub woofer out with speaker wire connection. From there you plug it in to the top section of the available terminals on the sub you are referring to (speaker level input). One in positive and the other in negative matching what you did on the receiver with correct ends. The speaker connections underneath the top connections is for additional speakers like surrounds to be able to be connected directly to the sub woofer speaker level out for sound. This of course would be for an older receiver connection. I do not think it is possible to convert this connection to an LFE and have it work properly. If the receiver does not have sub woofer speaker connection and only a RCA out then you can try to connect both rear speaker connections from the receiver to the speaker level inputs on the sub and then connect your rear speakers to the speaker level output on the sub to power them. This is an active sub woofer but for some reason they made it connect as if it was passive. I am not sure if this sub is designed for really low frequencies required for movie or if it is better for music.
Nov 01, 2010 | Audio Players & Recorders
What do i hook the sub woofer to
the sub woofer speaker should be connected to the Center, the main speakers should be set to the front and the secondary ones in the rear....(front = main just in case surround is not on, center = is for that ump / boom sound, rear = that just pass you by (make you look behind yourself)
Aug 30, 2010 | Yamaha RX-V659 Receiver
Could you tell me what plug in ports i need for X540 or 530- on my desktop
You need three ports in order to use all the speakers 5.1 sound. They are all headphone jacks but they are front speakers, rear speakers, and sub/center
8th pic
Apr 06, 2010 | Logitech X-530 Computer Speakers
Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only.
make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer.  connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
Mar 13, 2010 | Yamaha HTR-5540 Receiver
2 Dell 5650 have no sound
the surround sound speakers plug into the rear of the computer with three plugs. an adapter comes with it to plug those three into one green plug. if you plug that green plug in, the rear and center speakers should work, although i don't know if the surround sound will work correctly but you should get sound
Apr 03, 2009 | Dell 5650 Computer Speakers
Please check your model number, I can not find it on the JVC service website.
This is a powered sub-woofer I think. You need to have a thick black cord that connects the sub to the head unit. Then the satellite speakers get connected to the speaker jacks on the sub-woofer box. The sub-woofer should also be plugged into an A/C outlet on the wall.
The speaker outputs are labeled right there where you connect the speaker wires. You should see a red and black connector for each speaker and they are labeled "front right" "front left" "center" "rear right" "rear left".
If you do not have the thick black cord you need to connect the head unit with the sub-woofer, you can not use this system.
If you look at the head unit and give me the model number on it, I may be able to find the part you need. But I must have a good model number to work with, preferably from the head unit.
Nov 10, 2008 | JVC SPPWA670 Subwoofer
Sound problems through subwoofer
check all speakers wires andcheck test mode. every thing ok, may be input wiring problem ,check every thing after that internalcircuit may be problem..
Oct 08, 2007 | Audio Players & Recorders
Samsung HT-DS610 System Logo
161 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
