Question about JBL Simply Cinema Satellite Speaker (Each)
Older JBL System
I recently moved and my 10 year old JBL Sumply Cinema powered subwoofer wont work now. There is no way to access it beyond the remote which is also not working. It worked before I moved it and it hasnt been dropped. I can hear bass through it but it sounds muted. I dont know what to do. Its a great stereo but maybe its time to upgrade.....
runebeard
  • 905 Answers
SOURCE: connection a JBL surround cinema speakers with sub to a Yamaha
if you do not have the digital hook up from the tv to the reciever
304c659.gif then you will not get the subwoofer sounds or the dolby digital sounds
if you don't have this on your tv then just turn off the dolby digital when watching the tv , and you should be able to hear the subwoofer thru the virtual surround sound
hope this info is worth a fixya and if you need other help then just ask me and
i'll be glad to help
electech
Posted on Nov 23, 2008
  • 43 Answers
SOURCE: Subwoofer Bass Level Problems
What is your sub stood on? If it is on a piece of furniture then this could be the problem. Bass frequencies travel further than higher frequencies due to their longer wavelength and will also be transmitted through any solid objects the speaker is in contact with. The solution is to mount your sub on a piece of foam to provide some damping.
Also if your sub has a port (a hole) on the back or side this needs to have a good 3 or 4 inches clearance from nearby walls or panels.
Finally the speaker cone itself needs to have a clear path to push sound energy into the room, if this path is blocked by furniture (some people like to hide them under tables) then it may make that furniture vibrate.
Posted on Nov 27, 2007
SOURCE: jbl 12 subwoofer
Winslow is correct. It is likely to be a bad capacitor on the power supply. There should be two large capacitors on the power supply circuit. These capacitors filter the 60Hz waveform from the power. These will be the two largest capacitors in the entire system. The bad capacitor is probably bulging. For safety, you should replace both capacitors with exactly the same uF, voltage, and temperature ratings. Don't use anything smaller than the ratings of the current capacitors. And don't waste your time going to RadioShack, they won't have any big enough capacitors. It would also be a good idea to check any resistors that are near the capacitors, if you see a slightly larger resistor that is burnt, then you will probably want to replace it.
Posted on Jul 01, 2008
jmeredith
  • 417 Answers
SOURCE: JBL Pro Computer Speakers....
hi,
I believe your old sound card may be of higher quality than your new one, I had the same problem years ago what I did was this, I ran my speakers through an old dedicated dubbing cassette player out of an old kenwood stack stereo then into the computer, the cassette has a mild adjustable preamp when in record, you will have to put the deck on record the rest of the time with a blank tape- any old cassete deck will work.(thrift store) and your going to need a couple parts from radio shack. If you have the know how I suggest switching the audio cards out, drivers etc and / or seeing if you can have them both plugged in without an issue. If issue then try cassette then call and complain to the computer company for installing sub standard equipment.
computer audio output-> line in cassette->line out cassette-> line to speaker input
good luck
J
Posted on Jul 26, 2008
SOURCE: JBL Radial Remote stopped working.New battery replaced no avail.
Turn on the JBL with the ipod in place, turn off at the mains plug, turn back on, turn on your JBL and the remote should work.
Posted on Mar 11, 2009
Jbl sb400 remote
is it the remote not working or the receiver not receiving
take your remote and point the lens at the camera of your phone
turn the camera on and when you press the remote button ( any button ) you will see a white dot on the phone screen if it is working
Jul 12, 2016 | JBL Cinema SB400 Soundbar w/ Subwoofer
How do I pair my JBL Cinema SB350 sound bar and subwoofer
This PDF should help you with anything you need related to your JVL Cinema SB350. http://fccid.net/pdf.php?id=2287143
Oct 18, 2014 | Audio Players & Recorders
JBL-SUB135S please i need User Manual
As it is also sold as part of this system, Cinema ProPack 600, this manual should suffice.
http://www.jbl.com/resources/Brands/jbl/Products/ProductRelatedDocuments/en-US/OwnersManual/JBL%20CPP600%20OM%20(final).pdf
Page 37 gets into it. That's all there is to know.
There's not a lot going on in a vanilla self-powered sub. You seen one, you've seen them all.
Jun 28, 2011 | JBL Audio Players & Recorders
How to repair a broken remote of a JBL ESC 340 Simply Cinema syst
set an old radio to am get remote as close to aerial as possible when a button is pressed beeps should be heared thru the radio speaker
Feb 08, 2010 | Audio Players & Recorders
Still not found a remote to my jbl esc333.can anyone help
ive got the whole system simply cinema but mine is the 300 if any one is intrested
Jan 28, 2010 | JBL ESC-300 Speaker
Lost remote
i saw one on display in edgeware road and needed the sensor at the time and i got i..t but that was years ago.. ive got the whole setup if any one is intrested?
Sep 03, 2009 | JBL ESC-300 Speaker
JBL Simply Cinema Satellite Speaker (Each) Logo
37 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
