Question about Canon PIXMA iP4200 InkJet Photo Printer
MY PRINTER printer say error cde 6AOO MY PRINTER IS CANON MP 830
  • dmiller48 Apr 10, 2009
    Shortly after power up (10-15 secs) the machine stops and shows the 6AOO error code. This occurred suddenly after months of good use. The ink cartridges were new and I ran all the maintenance items recommended (cleaning the jets, alignment, nozzle check, etc.) None of the other MFP functions work either (fax, copy, scan).
Strip the purge unit ( cleaning/waste unit ) out. its got stuck of all the waste ink inside the purge unit that got dry. the machine is thinking that there is blocking of paper or it cant get the printer head to its home posision. and also clean the carrige unit bar. normally this is done by a printer tech.
Posted on Apr 02, 2009
  • 421 Answers
I need a disc Canon mp 830 mp navigator 2.2 have lost it moving the the printer to another room
You can download the Canon printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :- http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
May 01, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP830 Error Code 6AOO
The error seems to indicate a failed sheet feed, check the paper path to see for any stuck bits of paper, however I have heard that this can also be caused by a flaky sensor in the paper path.....
apparently the best way to deal with this is to turn it upside down and give it a shake.
hope this helps
Jul 21, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP 830 I replace purge unit
You may need a new printhead now, or you may have left a foam packing block inside the new purge unit.
Oct 29, 2009 | Canon PIXMA MP830 All-In-One InkJet...
I have a error code 6A00 and alarm light flashing on my canon pixma mp 830
Canon lists the solutions for the error 6A00 as...
1.
Press ON/OFF switch to reset the multifunction device
2.
Press Stop/Reset and ON/OFF to reset the printer
3.
Removing paper jams
4.
The MP830 may require repair
5.
Unlock the scanner lock switch (MP830)
Oct 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Error code 5010
try these steps..
1. Turn off the printer (MP 830) or other 2. Disconnect the printer from the power outlet (totally unplug the printer) 3. Wait for 1 minute - not less than that. 4. Plug the printer back in to the electrical outlet. 5. Turn the printer on
Sep 28, 2009 | Canon PIXMA MP520 InkJet Printer
Scanning error on mp 830 - code 5010. What is
Hi, did some research for you and this is what I found:
Dear Customer,
Thank you for your recent enquiry regarding your Canon product.
In response to your query, please be advised that the error code "5010" indicates there is a scanner error and the printer will require service.
If the printer was bought recently you can contact the dealer and check the replacement program.
If you are outside the replacement policy, please find below a list of authorized service centers for your device and some packaging instructions:
The following office peripheral products: A3 and portable printers which are still under warranty, Laser Beam Printers, PC/FC Copiers, Multifunctional Devices and Fax machines benefit from on-site service.
On-site service can be arranged by dialing 0870 400 2080, or by contacting
Canon Ireland Ltd (Fax, Multifunctional and PCFC Copiers)
Arena Road
Sandyford Industrial Estate
Dublin 18
Tel: 01 205 2400
Fax: 01 295 8141
Web: http://www.canon.ie
Sep 24, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Feed switch & alrm light on
The MP 830 usually will give you an error code in the display. If these lights just come on and you don't hear anything moving inside and no error codes, the main logic board could be bad. A rather expensive repair. Have you tried unplugging the printer and plugging in again?
Jun 25, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon mp-830 error code 5010
That code is a scanner error. The scanner unit can not detect the home position or the scanner unit warming up is not done properly at power on. Most of the time the Scanner unit needs to be replaced.
Nov 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
0 answersI lost power. My canon MP 830 will not turn on now that power has been restored.
Yikes... This is common with electronics for some darned reason.
The power adapter that comes with the printer may need to be replaced. If this does not fix the issue.. then the power outage has shocked the device and it needs to be replaced.
Oct 31, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA iP4200 InkJet Photo Printer Logo
158 people viewed this question
old marine
old marine
