Question about Mitsubishi CS-27209 27" TV
Mitsubishi cs-26ex1 tv has no picture ,but there is sound. i can get the menu to come up and see the menu just fine. is there any way to fix the picture, like do i need to reset the tv and if so how do i reset tv? please help
  • dazyjune Feb 26, 2009
    I have the same problem and was going to get rid of this tv, as it has been just sitting. But this seems like an easy fix. I think I will give it a try. I am just wondering how hard the area is to get to? Having never done anything inside a tv before. Just the boards themselves. Many years ago! Old as it is, I really like the tv. Same tv Mitsubishi cs-26ex1 (for some reason it says that is not a valid product, age probably)
    President:
  • 3,130 Answers
If your set has Picture in Picture, I would say your problem is with the PIP module. if it does not have PIP then the problem is most likly in the video switching or the video processor Printed circuit board. if you know anything about solid stae serviceing, there is a modification I will include here for the PIP as the module is no longer available and has to be jumped out of the curcuit.. Good Luck. Follow the picture and instuctions to the "T" PS please do not forget to rate this thread
Posted on Oct 17, 2006
Tip
Mitsubishi parental lock removal/v-lock redo
Models:
Color Televisions
CS-20EX1, CS-20301, CS-26EX1, CS-26201, CS-26301, CS-2725R, CS-27EX1,
CS-27MX1, CS-27TX1, CS-27200, CS-27201, CS-27301, CK-27304, CK-27306,
CS-27401, CS-27403, CS-3135R, CK-3136R, CS-31AX1, CS-31FX1, CS-31MX1,
CK-31MX2, CS-31301, CK-31302, CS-3525R, CK-3526R, CK-3527R, CS-3535R,
CK-3536R, CS-35X7, CS-35AX1, CS-35FX1, CK-35FX2, CS-35MX1, CK-35MX2,
CK-35MX3, CS-35201, CS-35201A, CS-35203, CS-35205A, CS-35301, CS-35401,
CK-35402, CS-40FX1
Projection Televisions
VS-40VA2, VS-4517S, VS-45VA1, VS-45VA2, VS-4561, VS-4562, VS-5016R,
VS-5017S, VS-50VA1, VS-50VA2, VS-50VF1, VS-50VF2, VS-50VX2, VS-50VX3,
VS-5061, VS-5062, VS-6017R, VS-6026R, VS-60VA2, VS-60VF1, VS-60VF2,
VS-60VX2, VS-60VX3, VS-6061, VS-7017R
This system locks only the entire TV. The TV will display a screen that
will indicate "Parental Lock ... Now the lock is on" and request the
personal four digit code when the TV is powered on.
IMPORTANT> You must use the original remote control that came with the
TV to release the Parental Lock, you cannot use a remote
that came with a VCR, Audio System or from any other
manufacturer.
1. Depending on which remote came with your TV, press the button at
the top labeled TV,OR set the TV/VCR switch in the upper left
corner of the remote to the TV position. .
2. Press the button on the remote labeled POWER.
The TV will turn on and display an information
screen that indicates "Parental Lock ... Now the
lock is on" and ask for the four digit personal code.
3. Press the #9 and the QV buttons at the same time.
The TV will turn on.
4. Press the button labeled MENU.
The "TV Main Menu" will be displayed.
5. Press the ADJUST UP or DOWN button to move the arrow next to the
"Advanced Features" selection and then press ENTER.
The "Advanced Features" menu will appear and
indicate that the lock is ON.
6. Press the ADJUST button to move the arrow next to the "Parental
Lock" option, and then press ENTER.
The screen will change to indicate "Parental Lock
... Now the lock is on" and ask for the four digit
personal code.
7. Press the #9 and QV buttons at the same time.
The screen will return to the "Advanced Features"
menu and indicate that the lock is off.
8. Press the MENU button twice to return to normal viewing.
The original lock code has now been erased and the lock canceled.
on May 16, 2010 | Audio Players & Recorders
Mitsubishi CS-35X7 CRT TV (vintage 1993) no picture
THE PIP MODULES GO BAD IN THESE SETS. THEY PLUG IN AND ARE EASY TO CHANGE AND EVEN CHEAPER IS THE PIP BYPASS MODULE. IT ELIMINATES PIP AND PLUGS INTO THE SAME SPOT
Dec 21, 2009 | Televison & Video
I have a mitsubishi cs-26ex1 tv and the parental code is set but I dont have the original remote or a user manual to reset the code. How can I unlock the tv?
well first lets narrow this down so the tv is already holding a code you will need the old code to re-enter a new 1 okay if the code is known you may be able to set with the menu button goto pc option try to use the channel up and down and volume see if this will help now lost remote may try a universal remote make sure it has the menu option on it ,also when entering code numbers some have over 5 or so codes okay the tv may respond to 1 code but not let you use the menu so try each code also if you cant remember the code its not to good you will have probally no choice to take to tv shop okay good luck shad
May 06, 2009 | Televison & Video
Mitsubishi vs5003r troubleshoot
I found this in another website... i hope this can help you. I'll try too...
Found this on the web, hope it helps.
Thank you for contacting Mitsubishi Digital Electronics America, Inc. We
are pleased to be able to assist our customers via our website. Here is the
information that you have requested:
TV Lock #8
Models:
Color Televisions
CK-35402, CS-40FX1
manufacturer.
personal code.
Oct 26, 2008 | Televison & Video
Mitsubishi cs-26ex1
This sound like the standard Mitshubisi PIP board problem. There are two ways to adress this one is to repair the board, this involves replacing surface mounted capacitor and is about %80.00 sucsessful. The other is to simply bypass this board. this option is the way to go, it involves installing two capacitor on the main board and fixes the main pix but kills the Picture in Picture (PIP) I will send off both these repairs to your E-mail
Feb 13, 2008 | Proton MM2701VT 27" TV
Mitsubishi CS026201 TV screen problems
If the picture looked good last night
then the Tube is fine. The problem is
Power suply . I think there great tvs.
Made to last .a fair price for repair
is about 80.00-100.00
Nov 12, 2007 | Mitsubishi CS-26201 TV
Mitsubishis TV Problem
have a Mitsubishi TV 1993. Model CS-35301. The problem is that there is a white line that is running through a blank screen. The sound is fine just no picture. Have you heard of "Vertical Collapse?" I would love to save the TV. Hi nothing to worry just minimise brightness to avoid screen burn. "Vertical Collapse?" means one bright hor.line in the middle of screen. this problem can be solved 1 check vertical yoke connector or wire loose 2 check supply to vertical section which normally comes from EHT transformer check components in vertical section or print loose regards thanks
Sep 10, 2007 | Televison & Video
Mitsubishi CS-27405 no picture but sound
your problem is the PIP board,tough to repair,can be taken out and replaced with two 10 mfd caps 50v bipolar from pin5 to 11 and from pin 7 to 9
Sep 27, 2006 | Mitsubishi CS-27405 TV
Televison & Video Logo
438 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
