Question about Audiovox CDM-8915 Snapper Cellular Phone
CDM-8915 PHONE IS DEAD!
The phone dropped into a puddle of water. I later found it and it worked for a few hours. The next morning, no life. I tried recharging battery. After inserting the battery, the vibirator activitated and stay activitated until I pressed the "ON" button to turn on the phone. Now there is no response. How can I access the phone numbers? I don't care about the phone. I care about the phone numbers and not losing them. Will new battery work? Since I see that this model is discontinued, are batteries still available?
The solution: I left it alone for 24 hours.
Here's what I did:
I plugged the charger in and allowed it to charge overnight. No lights or screen or screen appeared but I kept it in anyway. After charging, I removed the battery and cleaned all the contacts with Isopropyl rubbing alcohol. When I reinserted the battery, it vibrated intensely, which indicated a strong battery. I did not turn the phone on right away but waited a day. When I turned it on, it responded like nothing was wrong. Perhaps the phone reset itself. That’s how it behaved.
In any event, I have my phone back and it’s working well.
To summarize what happened:
The phone drops into a puddle and is partially submerged for an hour or so. I find it, dry it off and make some calls, with no effects of any kind.
The next morning, it fails completely. No response whatsoever. I recharge the battery and that doesn’t work. What did work was to remove the battery and clean all the contacts and reinsert it and leave it alone for a day.
Lesson learned: record all phone numbers before I lose them forever.
Also, get a better holster so that the phone is secure from falling out.
Thank you very much for your support.
Bill
Posted on Nov 10, 2008
Changing lcd screen
LCD fitting instruction videos for most phones can be found on youtube.
Jan 12, 2014 | Audiovox CDM-8915 Snapper Cellular Phone
Hi im looking 4 nokia 3650 flash file
Hi, you can use this link to know how to get flash file for your phone. You can browse through it.
(hubpages.com/hub/How-to-Flash-your-cell-phone).
Hope it helps.
Have a nice day.
Sep 13, 2010 | Audiovox CDM-8915 Snapper Cellular Phone
Tuesday I dropped my Motorola Rival in to a thing of water on my phone, it was in it's case. I took the back off and the battery out and placed the rest of the phone in rice. It seemed to work fine in the...
there might be water blog near battery connector or near charging section.kindly wash your phone with petrolium liquid & rehot with blower .don,t try this your self .kindly visit any service shop near by you.
Apr 08, 2010 | Motorola Mobility Rival A455 Cell Phone
Forgot lock code cannot unlock phone
If you forgot you can generate master code using your IMEI, which can be viewed by pressing *#06# and keying that in the link mentioned below,,
http://www.unlockme.co.uk/master.php
Hope this helps
Nov 14, 2009 | Audiovox CDM-8915 Snapper Cellular Phone
Dropped Blackberry 8100 in water now wont turn on...
Get some ipa [isopropanol] leave phone submerged in same for a few hours [with battery removed] then remove from ipa, leave for 24 - 48 hrs as long as you can and it should come back to life. All the components in your phone are waterproof so the ipa will eliminate the moisture and should make you happy again.
May 01, 2009 | RIM BlackBerry Pearl 8100
I dropped my LG enV into a puddle of water.
Sounds like you will need a new battery. My env2 would only work if plugged into the wall charger after I dropped it in the toilet. I got a new battery and it works fine now!
Mar 12, 2009 | LG enV VX9900 Cellular Phone
Phone fell in puddle
Sadly I think it is too late to help. If it had water inside, that probably shorted it out. However, in the future, you should take the battery out as soon as possible to prevent this.
If you want to try something, just let it dry completely and then try using it again. I doubt that this will do anything, but it might end up working.
Mar 04, 2009 | Sony Ericsson w580i Cellular Phone
Dead KRZR K1m
hola soy manuel y tengo un problema me consegui un k1 y tnia clave de desbloqueo mi pregunta es: como lo desbloqueo?
Nov 09, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Audiovox CDM-8915 Snapper Cellular Phone Logo
130 people viewed this question
Top Audiovox Cell Phones Experts
svicari124
svicari124
Level 1 Expert
Computer Repairing
Computer Repairing
Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
