Question about Intermec CN3
3G connection keeps dropping / device freezes
We have several CN3 devices that we are testing with. The application communicates back to a back end server using a 3G connection that keep dropping randomly. The devices are always in cellular range, and regular cell phones are communicating without issue wherever the CN3 goes.
Due to the communication dropping, the device eventually freezes and we need to cold boot (pull the battery) the device in order for it to work again.
To re-establish connectivity, we use the phone on the device... occasionaly have to "repair the 3G connection" and sometimes use the browser to find a web site.
Eventually communications are re-established and everything works again.
Any suggestions or ideas would be appreciated.
  • Anonymous May 04, 2009
    I have the same issue where the device drops the connection to the internet. Only fix is to "Repair Connectoid" to fix the 3G connection.
Not sure if you fixed this but I had the same problem with Intermec CK30's a couple of years ago, and it was in relation to the number of terminals using the same username & password to connect to the client server - might be a indea for you to check out.
Posted on Jan 22, 2009
Can't connect to TV
Most connection problems that prevent streaming occur on the device itself, or on the home network. In a nutshell, we will have you test the Internet connection on the device, log out and back into Netflix, restart your device, and restart your home network equipment.
Select your device from the list below for steps tailored to your device:
  1. Test the Internet connection on your device
    Many devices have an application to test the Internet Connection. If not, try opening the application store or another Internet-enabled application and check if your device is able to reach Internet services.
    • If you are unable to connect to the Internet, you may be having network connection issues.
  2. Restart the device
    Restart your device by unplugging it from power for at least 10 seconds, then plug it back in and turn it on with the power button. Restarting the device is often enough to restore your ability to connect to our service.
    Note: All devices are different. Some may take up to 15 minutes to fully restart.
  3. Disconnect and Reconnect the Netflix application
    These instructions will work on most consumer electronic devices with the Netflix application.
    1. Launch the Netflix app.
    2. Using the arrows on your remote, enter the following sequence:
      • Up, Up, Down, Down, Left, Right, Left, Right, Up, Up, Up, Up
    3. Select Deactivate and exit the screen.
    4. Restart the Netflix app and sign in to your account.
  4. Troubleshoot your Internet Connection
Oct 07, 2013 | Netflix
Phone will not turn on Intermec CN3
sounds although the unit has been dropped and the power connection between the battery, the back up battery and the rest of the unit has been severed. Or it could be a CPU failure - If you need assistance with this please contact jack@codeo.co.uk
Aug 02, 2011 | Intermec CN3
Date keeps resetting to 01 Jan 2005 why?
When the battery dies there is an internal battery that will keep the device running so that all of the programs will still have functionability. Once that internal battery dies the date/time stamp resets back to the factory settings which is January 1, 2005. To keep this from happening you will need to install a time patch onto the device.
Jan 13, 2011 | Intermec CN3
Cant install any applications
Run the TI connect software on you computer. Turn the calculator on and connect it to a USB port on the computer. Before you drag and drop applications on the TI connect software window, Click on one of the icons (TI Device Explorer, TI Device Info, TI Screen Capture). Two new smaller windows pop up, the one on top has the title Select TI device. If in that window it recognizes your Calculator Model, you click on select and OK, and you are ready to communicate with it.
If on the other hand, it fails to find your calculator on any of the 3 or 4 communication ports (COM3, COM4, USB1, etc.) then you click on the communication setting and in the drop down lists
Sep 03, 2009 | Texas Instruments TI-84 Plus Calculator
Example sorurce code for database
Hello my friend try this code: This code is design for Visual Basic 6.0
Function for Connection and recordset string.  '========Connection String====== Public Sub connection(ByRef dConnection As ADODB.connection, ByVal dLocation As String)     dConnection.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & dLocation & ";Persist Security Info=False;" End Sub '======End of Connection String======
'=======Recordset String=========== Public Sub recordset(ByRef sRecordset As ADODB.recordset, ByRef sConnection As ADODB.connection, ByVal sSQl As String) With sRecordset .CursorLocation = adUseClient .Open sSQl, sConnection, adOpenKeyset, adLockOptimistic End With End Sub '======End Recordset String========
How to apply the above function? Application:
'====== Command Save Button======== Private Sub cmdsave_Click() Dim cn3 As New ADODB.connection Dim rs3 As New ADODB.recordset
Call connection(cn3, App.Path & "\CASGC.mdb") Call recordset(rs3, cn3, "Select * from Debtor_Creditor_Account") Set dtglobal.DataSource = rs3.DataSource
With rs3   .AddNew   .Fields("Code") = txtCode.Text   .Fields("Description") = txtDescription.Text   .Fields("Tag") = cbotag.Text   .Update   .Requery    End With   MsgBox "New Account has been Added", vbInformation   Set cn3 = Nothing Set rs3 = Nothing
End Sub '=======end of Command Save button=====
The advantage of using this code is setting your database connection is you have a reliable connection towards your database where ever you place your database you can you don't to remount you databse connection control. Also you are no longer need to use a ADO control or DAO control just copy the function and paste it in your coding area and call the function and you have now a working database and recordset connection string.
For more details regarding how to apply this code just email me at this address: geo_jonas@yahoo.com to get more codes. thanks.. Please rate this Solution.
Jul 08, 2009 | Microsoft Visual Basic 6.0 for PC
How to do a hard reset on CN3 device
To cold boot your CN3
1 Press the Power button to suspend the CN3.
2 Remove the battery pack from the CN3.
3 Press the Reset button on the back of the CN3.
http://www.isg-service.com/Portals/0/ISGPdf/Intermec/IntermecCN3.pdf
Jan 16, 2009 | Intermec CN3
Sync
While the iPhone certainly isn’t the first mobile handset to suffer from freezes, its functional breadth and the fact that many of its users install unsupported third-party applications make the device, generally, more freeze-prone.
settings can result in a reduction in or complete elimination of freezes:
  • Tap Settings on the home screen. Tap General. Tap Auto-Lock. Set to “Never.”
  • Tap Settings on the home screen. Tap Brightness. Turn Auto-Brightness off.
Oct 13, 2008 | Apple iPhone 3G
Blackberry 7290 issue
my blackberry 7290 keeps saying device error:400 then below says reset i keep reseting it and nothing comes but it keeps saying reset .. wat can i do ?
Nov 20, 2007 | RIM BlackBerry 7290
E115 main memory problem
The memory problem can be fixed easily. It is not only you. It is a common problem with some pocket pc. Instructions according to Casio Customer Service: You will have to back up all of the data. Then remove the backup battery and main battery for ten minutes. Restore all of your files and you should be back in business. Also, to prevent this from happening again and to keep program memory high, perform a soft reset at least once daily. This will almost certainly fix your problem.
Sep 06, 2005 | Casio Cassiopeia E-115
Computers & Internet Logo
564 people viewed this question
Top Intermec Computers & Internet Experts
Computer Repairing
Computer Repairing
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you an Intermec Computer and Internet Expert? Answer questions, earn points and help others
