Question about Gateway GTW-P42M303 42 in. Plasma Television
Power supply I need a schematic or picture image of the main power supply for Gateway GTW-P42M102.Can any One help mi?Please!
  • 1 more comment
  • Anonymous Nov 03, 2007
    clicks will not come on
  • toscano Dec 16, 2007
    need schematics of main power supply 3501Q00001A. If some one can help... Thanks a lot
  • cupcake16 Jan 08, 2008
    My power light comes on, but there is no picture or sound at all.  I am thinking that the power isn't being fed correctly.  It just stopped working all of a sudden.  Help!
Here's the information you requested.  See pages 30,31,and 32.
Download the .pdf file here:
http://www.eserviceinfo.com/downloadsm/28159/Gateway_P42M102.html
Posted on Oct 16, 2007
SOURCE:
The menu pops up on starting and continues to scroll. The front panel buttons on the TV do not do what they are supposed to do (i.e. Vol button changes input option, etc.)
i have the gtw-p42m102 and it did the scrolling thing and i had the image board dpwb11393-1g-l changed and it worked fine for 2 years.Now it made a pop like a firecracker and i am working in it now.
Aug 03, 2010 | Gateway GTW-P42M102 Television
NO PICTURE ON MY 42 IN PLASMA TV GTW-P42M102
http://shop.adc-ast.com/cgi/display.cgi?item_num=DPWB11396-1G-T http://shop.adc-ast.com/cgi/display.cgi?item_num=DPWB11393-1G-L http://shop.adc-ast.com/cgi/display.cgi?item_num=PDP42WVSN3S
Jun 11, 2009 | Gateway GTW-P42M102 Television
Gateway GTW-P42M102, first sparks, now flashing green lt. in back
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jun 21, 2017 | Gateway GTW-P42M303 42 in. Plasma...
Main Power Board
The power supply board can be changed without any knowledge of repair but there are sometimes adjustments necessary if the picture is not normal. Many times it is fine. There a 4-5 voltage adjustments that would take some knowledge and a meter to accomplish. You need to hope it was diagnosed properly first. If it is completely dead the p.s is a good possibility. If it clicks on then back off almost immediately it is not likely the power supply.
Jun 02, 2008 | Gateway GTW-P42M102 Television
Set has bad power supply,
Hey there...
When I fixed the parts on my same model, I aways ordered from www.digikey.com. You'll find your transistors there.
Jim
Feb 14, 2008 | Gateway GTW-P42M102 Television
Mine does the same thing. Was told by the TV repair guy it is a bad control panel.
May 18, 2007 | Gateway GTW-P42M102 Television
Gateway GTW-P42M102 / Won't come on
Check the panel voltages, and start unplugging the cables to each PCB and check the voltages each time, if the voltages come back up the its probably the PCB that is disconnected, in most case its the logic main board. Hope this helps
Jun 11, 2006 | Gateway GTW-P42M102 Television
Gateway GTW-P42M303 42 in. Plasma Television Logo
472 people viewed this question
Top Gateway Televison & Video Experts
Ronald
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
