Question about Kenmore 63942 Dryer
Kenmore 80 Series Dryer - No Heat - Thermal Cutoff Kit 279769
I have a Kenmore Series 80 110.62842100 and the thermal cutoff went bad. I bought Kit 279769 that has the cutoff and the hi limit thermostat. I replaced the TC and the dryer is back to blowing heat. My question is concerning the suggestion to replace the thermostat as well. In looking at my current thermostat in the unit it appears to have one clip available for an electrical wire but the other end of the thermostat is connected to a white piece that has the heater coils plugged in on one side and the thermostat appears to be crimped to the white piece on the other. In other words the new thermostat has two clips available for leads like the TC but the old one in the until only has one clip and then the other end is crimped to the metal that has the coil plugged in on the other side. So, if that makes sense can I leave the thermostat out and should the unit still run fine?
  • fritznewt Nov 09, 2008
    The problem is that the new therm won't connect the same way. The old one appears crimped to the heating element part and the new one has two "fins" to accept connections like the TC.
  • 62 Answers
That therm. will actually come off the heating element part, it is always good to change both, I use a small screwdriver to get it off
Posted on Nov 09, 2008
  • cmcarter13 Nov 09, 2008
    it is not crimped on, it does come off that heating element
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: my dryer wont heat up
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Aug 24, 2011
Dryer tumbles, no heat, thermo fuse has been changed. Can it be the cycling thermostat or the heating element?
If you have changed the thermal fuse you may have a defective thermal cutoff (located at the top of the heater housing in the back). The thermal cutoff will come with the high limit thermostat located at the bottom of the heater and you should change both parts if the thermal cutoff is bad.
You can take both of the parts (the heater and the thermal cutoff) to a parts supplier to have them checked for continuity (they should both read "closed" if they are good).
Good luck to you!
Oct 07, 2010 | Whirlpool WED5300S Electric Dryer
How to connect dryer wires to thermal cutoff
The first thing I would like you to do is get your model number from the dryer, it is located near the inside the of the dryer door. you need to make sure you have the right heater and thermal cutoff kit. The manufacture has more than one type of heater and thermal cutoff kit out, (( some will not work with others ))... Call another parts store or sears and make sure you have the correct parts !!
Most of the thermo cutoff kits have direction and if they are not making scence then the chance of you having the rong one is good !!!!!!!
If you remove the thermal cutoff from your origanal heater and then look at how many conetion pins are left. The new heater and old heater should be the same.
The most common heater is the 2 conection. But they made one with three. and if you have the one with three, it has to be replaced with the same one !!!
Without knowing the model of your machine, I cant tell you how to wire your machine.
I recomend you use the direction that came with the Cutoff kit.
Aug 11, 2010 | Kenmore 62602 Electric Dryer
Kenmore 80 series dryer, no heat. blower works
Check to see if the glow bar is coming on first. If it isn't, it is probably the thermal fuse/ cutoff. It is a small white plastic piece on near the motor housing.
http://www.partselect.com/PartDetail.aspx?Inventory=345113&SourceCode=6
or
http://www.partselect.com/PartDetail.aspx?Inventory=344958&SourceCode=6
If it is coming on but not lighting the flame, then you probably need gas coils. They are the two cylinder shape black and white objects attached to the gas valve.
http://www.a-1catalog.com/gasvacokit2.html
Jan 15, 2010 | Kenmore 73952 Gas Dryer
Dryer only heats on more-heat setting
Could be heat selection switch is bad, need to test it with a volt ohm meter
Jan 07, 2009 | Kenmore Dryers
HOW TO REPLACE A THERMAL CUTOFF ON ELECTRIC DRYER
you will need too take off your back panel of your dryer and the heater is on your right the thermal cutoff is on the left of the heater housing at the top and then there is a little white thermal cutoff on your blower housing in the bottom left of the dryer now if this is not how your dryer looks let me know cause there is several different style of kenmore dryers but this is the most common one
Dec 29, 2008 | Kenmore 67082 Electric Dryer
No Heat - Kenmore Series 90 electric dryer
check cord conections and timer contacts (big wires)
Dec 24, 2008 | Kenmore Dryers
Clothes dryer not heating
I eventually changed the thermal cutoff switch and the high limit thermostat as suggested in one of your replies to another consumer and now the dryer is working fine. Thanks.
Nov 13, 2008 | Zanussi TC7114W Electric Dryer
Kenmore 63942 Dryer Logo
2,471 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
