I have an Nvidia geforce 8500gt ddr2 512mb 128bit pcie. It worked just fine for about a month then one day after the monitor went into screensaver mode it would not return to normal function. It just refuses to bring the monitor out of powersave mode no matter which machine I plug it into no matter whether or not I use WindowsXP or DOS. In fact I have another of the exact same card so I swapped them around between the two machines, one works works fine and the other simply will not wake up the monitor. I've removed and reinstalled drivers, checked for driver version, all to no avail. I phoned Nvidia support and they want to know who the card manufacturer is. They ran every number i could find on the card with no luck. It looks like I won't get any warranty support from Nvidia unless i can figure out who made it. (made under NVidia's licence I'm guessing) I can add that the box that the card arrived in, has a picture of a mouse holding a machine gun. The mouse has a sign on his belly saying "FREUD WAS RIGHT"
There are different manufactueres that actually sell the nvidia video cards. Some names are EVGA, BFG, and XFX. It most likely says a name on the box and you will need to contact them for better support for your specific product.
As for the monitor going to sleep, I have had this problem before in an older machine. The solution unfortunetly was to replace the videocard.
I hope this helps. If ya need any more support, ya know where to post.
can you update the graphics card in a gateway gt5482E? I attempted to install an Nvidea 9800GT, and...
(More)
can you update the graphics card in a gateway gt5482E? I attempted to install an Nvidea 9800GT, and then tried a NVidea GT240 but both did not work. The PC continues to read the original 6160 se card in spite of the drivers being un-installed. HELP! :-)
Code 43 when try to reload drivers. Will not work alongside NVIDA gforce 8200 graphics card. Any...
(More)
Code 43 when try to reload drivers. Will not work alongside NVIDA gforce 8200 graphics card. Any ideas???
I updated my Nividia GeForce X40 graphic card through the manufactur after windows said they didn't...
(More)
I updated my Nividia GeForce X40 graphic card through the manufactur after windows said they didn't have anything newer, 1 month later windows came and updated it and now my screen is jarbled and missing half of the color. I was able to do a system restore and fixed it but my roommate let windows update it again and now it won't let me do a system restore and won't let me manually change the settings for the color. It went from a 32 bit to a 4 bit. What can I do?
it wont boot up computer!!! when i put my post card i changes post codes first it stops c1 then...
(More)
it wont boot up computer!!! when i put my post card i changes post codes first it stops c1 then continues to 25 then resets to c1 and so on and on
