Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Dont sound right starting when hot
My 07 ultra starts good when i first start it when its cold but after i ride it and turn it off and then restart it . it dont sound right could this be a bad battery or bad plug
  • 216 Answers
Batteries will charge up alittle over nite, so first thing in the morning you have the most juice. It could be a battery on the way out or a problem with your charging system not quite meeting all the needs of your bike.
Posted on Nov 07, 2008
How do u no when the valves need adjusting on yzf450 07 model
Usual signs are reduction of power when engine is warm. difficult to start or won't start when hot but will probably start well when cold.
Sep 24, 2015 | Garden
Worx mower. I was mowing fine..stopped to change bag.. Wouldn't restart when pushed the key button. handle engaged and it would power move forward. Engine would not start.battery fully charged
sounds like, a valve clearance adjustment problem. starts when cold, looses some power when hot, if turned off or stops, won't restart until cold.
Aug 04, 2015 | Garden
I have a 2014 Electra glide ultra classic. won't start. Starter makes a "click, click, click" sound. Took to HD mechanics and replaced starter plunger. 5 rides later, same problem. Anyone? Thanks!
I would check the grounding of the Starter and make sure the Hot wire to the starter is in good shape. Sounds like you are not getting enough Amperage to the starter
Apr 26, 2015 | Ultra Motorcycles
1997 grand marquis wont restart when cold
change air filter and fuel filter clean fuel injectors.faulty coolant temperature sensor will cause cold start problems.
Jan 04, 2013 | 1997 Mercury Grand Marquis
2008 harley ultra classic intermedant cranks no start when engine hot
This is just a guess, but the problem may be with the crank and/or cam sensors.
Sep 03, 2012 | 2002 Harley Davidson FLHTCUI Electra Glide...
1985 Honda shadow vt500c how to replace front turn signal stem, after engine gets hot and you shut bike off try to restart bike won't start, also I have a noise sounds like coming from water pump
Hi, Luther the answer to all those questions is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
Good luck and have a wonderful day.
Jun 21, 2017 | 1984 Honda VT 500 C Shadow
My dodge dakota 4.7 starts without any problem and runs great for approximately one minute. It then starts floundering and will die. You can turn it off or wait for it to die, and restart it and it runs...
Sounds like you have a restricted fuel filter that is causing your vehicle to start sputtering because it can't meet the engine's demand for fuel and then dies when fuel is depleted. After your vehicle stops running, fuel starts seeping by and you can start it again with ease hot or cold and you get the same results moments later if this sounds right replace your fuel filter.
Mar 30, 2011 | 2003 Dodge Dakota Club Cab
My mower starts and runs great when cold but dies when hot. It will restart but won't stay running until it cools off again.
How old is your mower ? Sounds like points and condensor if older model ,or ignition module if its newer , points tend to stick together when they get old causing no spark at plug when they cool they come appart allowing it to spark again , module is sort of the same except you have no way of replacing points you have to replace module .
May 11, 2009 | Garden
Won't start after stopping
sounds like the thermostate is no good and you probably overheated the car hope you didnt ride to long while overheating ---fill all fluids to normal and try to turn the car over when the engine is cold to see if it starts. if it runs and sounds fine dont let it get to hot watch gage let it go to 180 - 200 if it climbs higher shut car off and have a mechanic check it out or replace thermostate cheapest way out. if car does not run right or makes noise as soon as it starts u have added problems. u didnt mention if there was antifreeze leaking any where
Mar 18, 2009 | 2001 Chevrolet Metro
Will not restart after being warmed up, it starts easy when cold.
those symptons sound like too rich , air filter clean , plugs dirty
nothing blocking the air intake make sure the valve clearances are as per manual
burnt valves ?
get a compression test done
Dec 31, 2008 | 2006 KTM 560 SMR
Lands Phones Logo
61 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
