Question about Intel DG31PR Motherboard
I have a pci e 16x vga and a capture card pci e 1x
When i install both of them vga and capture card it and system down POST windows does not start and screen just black
  • David Preston
    David Preston May 11, 2010
    Does the Motherboard have an integrated Video card?
    Do the boards have GPU's from different Manufacturers? (Ie..... ATI and Nvidia)
    To Further Aid you it would be helpful to know the manufacturer and model of your Motherboard and the 2 cards in question.
    Looking forward to helping you
    Dave
  • 33 Answers
HI
Maybe you should try taking off one of these cards and try them one by one.
I mean, install the AGP and test if your system will work, if not, unplug it & try the other one.
If you have an integrated graphic card, you shouldn't connect the monito cable to it, but to the new one you are using.
I hope this is helpful.
Posted on Nov 08, 2008
Are pci and pci-e cards the same
No the cards are not the same. One has 62 pins on each side of the card (minus a cutout for a key with the slot) and the other has 32 pins (PCIe 16x) or fewer. They have different power requirements and won't fit directly in the other slot. There are adapters for PCI-e 1x cards to use them in a PCI slot and adapters to put a PCI card in a PCI-e 1x slot. See any of the component vendors for details.
Make sure to order a card that will fit in your computer's slots. It will save you trying to determine if the card, slot or adapter has failed.
I hope this helps.
Oct 27, 2011 | Lenovo IBM ThinkCentre A30 8199 (8199XX2)...
How to install Pci-e 16x in a pci slot
Do not put a PCI-e card in a PCI slot. It will not fit and the card won't work. The PCI card has 58 or 60 pins on each side with the slot (62 pins would be present if not for the key notches for alignment). PCIe 16x cards have 32 pins.
There are adapters to put a PCI card in a PCIe 1x slot (will fit any PCIe slot) or a PCIe1x card in a PCI slot. See http://www.amfeltec.com/index.php for a sample of the adapters. For the PCIe 16x cards, you need a new motherboard.
If you are placing a PCI-e 16x card in a PCIe 16x slot or a PCI card in a PCI slot, then open the side of your case. Locate the matching slot (remove the current card) or an empty slot depending on your motherboard. Depending on the case, you may need to remove a screw to remove the old card. Wiggle the card straight up to remove it. If you are putting in a new card, you will need to remove the cover from the slot. (For some larger PCIe 16x cards, you need to remove the adjacent slot cover as well.) Some covers just pull straight up or pry a lever up and then pull; for others, you will need to use a screwdriver to break the cover out. Make sure there is sufficient room near the slot for the card. (You may need to move other cards around.)
Then line up the card so that the back of the card will fit into the opening and the contacts on the bottom of the card are above the center of the slot. Firmly press the card down into the slot without changing the alignment. You may need to wiggle it (press down on the back and front, alternatingly). Then make sure the card is fully seated. Attach the addtional power cord from your power supply, if needed for a PCIe 16x card.
Close your case. Then if this is a new video card, turn on the computer and enter the BIOS (press F1, F2, F10, Esc depending on the machine). Disable the on-board video. Then reboot the computer and load the drivers you need for the card.
I hope this helps.
Oct 16, 2011 | Computers & Internet
I have the Board ASUS P5VDC-MX. And I wonder that there is no pci-e slot, but in the information there is written:"this board is pci-e (16x) ready".... is it right ? Can i use a pci-e (16x) video...
No, you can't use a PCIe x16 card in any of the slots on the P5VDC-MX board. A PCIe x16 card can't fit into the PCIe x1 slot. Attempting to force a PCIe x16 card into the PCIe X1 slot will break the card or bend the pins. A PCIe x1 card will work in a PCIe x4, x8 or x16 slot, though. Similarly, the AGP and PCI slots are not compatible with the PCIe x16 card design.
I wish that I had better news for you.
Aug 19, 2017 | ASUS P5VDC-MX (P5VDCMXGREEN) Motherboard
Black Screen after installing new NVidia 9400GT
Put the old card back in, remove the old drivers and restart it in VGA mode.
You don't say what operating system you use, but XP & Vista you should be able to hit F8 before the windows splash screen to select VGA mode or Safe Mode.
Once you do that you should be able to put the new card in and start it in standard VGA mode then load the new drivers.
May 25, 2010 | SPARKLE Computer Sparkle GeForce 8500 GT /...
Asus p4p800s.x motherboard drivers
Hi bernard_in_c, you can download the audio & VGA software directly from Asus. Click on the link below. Choose your operating system from the pop-up window than click search. The driver download page will open: http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P4P800S-X An Asus pop-up window will open & you must choose your operating system from the dropdown menu. Than click the Search button.
Click the + sign next to the device you want to download. With the Asus P4P800S-X motherboard there is not a separate VGA driver. (The VGA graphics card is a PCI VGA integrated card).
The VGA driver is part of the chipset software. Open the + sign next to Other. Download, Intel(R) Chipset Software Installation Utility 5.0.2.1003 for Windows.
By installing the chipset driver software (In a running system of windows), it will over-write all chipset drivers within your system. It is possible your windows may become wacky. Normally the chipset driver software is installed right after installing windows. (A fresh install).
Make sure you have the bios settings set correctly for the VGA/PCI. Open your manual to page 2-18 & set up per page 2-19. Go to Graphic adapter priority set this to, [PCI/AGP]. Next set the amount of system memory you want the graphics card to use. At the bottom of page 2-16, leave AGP/PCI frequency set to, [Auto].
If you run into any troubles, just post them here.
Good luck bernard_in_c!
Mike
Sep 22, 2008 | ASUS P4P800-X Pentium Motherboard
PCI express
your board supports 1X and 16X PCI Express cards
link to board specs
May 31, 2008 | Intel D101GGC Motherboard
Video card for the gateway 507gr
Yes, your computer specifically supports:
PCI Express 16x and
PCI Express 1x
The 16x is the long one and the 1x is the reallly short one. Most likely the card that you get will fit the big slot. Be careful not to upgrade too high though, because if you do you may have to upgrade your power supply as well. Ask someone at gateway or a local shop for a recommended card for your system.
Apr 23, 2008 | Gateway 507GR PC Desktop
Graphics card upgrade
  • 2 slots
  • 1x PCI Express 16X
  • 1x PCI Express 1X
  • any nvidia 8 series will support your game
    Nov 30, 2007 | Graphics BV200 BizView 128MB (128 MB) PCI...
    Pc don't reboot
    just incase you didnt get a solution from your last post, see this link:- http://www.fixya.com/support/t145701-system_dont_reboot
    May 18, 2007 | Pine Technology TLSI211004 Motherboard
    System don't Reboot
    Assuming you have already installed the AGP driver for the motherboard, you will have to start the pc in safe mode (F8) on boot up, to start in VGA mode only and see if the graphics are ok. If it boots into VGA mode then the card itself is ok, but the card driver and agp motherboard driver, if not already; will need to be installed at this point because im assuming you were not able as you were getting the fault on screen.
    May 01, 2007 | Pine Technology TLSI211004 Motherboard
    Intel DG31PR Motherboard Logo
    Top Intel Computers & Internet Experts
    Tony
    Alun Cox
    David
    David
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
