Question about OKI MICROLINE 320 Turbo Matrix Printer
Oki Microline 320 turbo alarm light
Hi
THe alarm light keeps going off when I turn it on. Has been doing this for a week. I changed ink yesterday. Usually just rethread the paper this is not working. The icon says it is out of paper. It is not. Took it apart blew it out, rethread the paper, redid the ink cartridge and still an alarm light...any other suggestions. WOrking on downloading the manual,.,
  • 3 more comments
  • mediacomgal Nov 07, 2008
    Ok update manual says the lever is in the wrong position. Moved the lever turning the printer off and on with each move. 2nd time through the possible solutions the alarm light went off. The printer works when I shut it off at night, I change nothing and yet it will not work in the morning. Any tips are still welcome....thinking about leaving it turned on all the time. ????
    No LEDS flashing just the alarm light flashes.
    Please clarify you said
    If it is set correctly, there might be an obstruction on the printer top cover that interferes with the cover sensors. This forces the printer to think that the lid is still open and will signal it as you have described.
    Where would I find this? Have taken just about everything apart cleaned it and put it back together just like I did my old one. No lid that I am aware of.....
  • mediacomgal Nov 10, 2008
    Thank you for your help..I am for right now not turning it off I will milk it along till it dies. This was my replacement for the last one having issues...will probably have to go back to that one it jammed all the time but worked pretty well otherwise. Rolls eyes. Thank you!!!
  • Kevin Shafer
    Kevin Shafer May 11, 2010
    Okay I have the service manual for this. Are any of the LEDs blinking?
Hi i have an oki microline 320 turbo matrix printer it started to print very light ,i want to change the ink but don't know where to put the ink .please help
Posted on Jul 13, 2010
If the printer worked one day and stopped working after turned off/on, you most probably have a bad paper sensor. This is basically a switch that is no longer working, therefore cleaning will no fix it. Determining which one is actually bad is difficult, so many places actually replace them all. I might be able to get you the part numbers if you really want to try it out. But be aware that this is only an educated guess, your unit might have another issue involved.
Be blessed.
Posted on Nov 07, 2008
  • 161 Answers
First, make sure that paper feed switch is set accordingly to the paper path you are using (rear feed, bottom feed or friction). If you make a change, turn the unit off and on.
The last option will be a damage to the sensors or to the mainboard. This is rare, but if the case, you need a repair center.
Be blessed.
Okidata 30 turbo carriage keeps running when reaches far left
Have you contacted OKI Data? Live customer support is available 24/7 (within the US and Canada) at 1-800-OKI-DATA.
Jan 27, 2013 | OKI MICROLINE 320 Turbo Matrix Printer
Oki Microline Turbo 320 stopped working. When I turn it on makes some kind on noise but won't work.
does the printhead assembly move at all? try taking off the ribbon and moving it by hand with the power disconnected. try moving it to the right hand side before turning it back on, if it does not go all the way back to the left again try to find what is jamming it.
is the alarm or any other lights on?
Dec 12, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
Hi oki 320 turbo printer started to print very light ,i want to change the ink ,but i do not know where to put the ink ,please help
There is now ink in the machine. You just have to replace the print ribbon. This is the small black box that is mounted to the printhead.
Jul 13, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
How to buy the ink for oki microline 320 turbo
google for it on the net like refil or new cartridge
Nov 06, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
OKI DATA MICROLINE 320 TURBO PRINTER PROBLEM
Hi Charles,
Use the IBM proprinter driver for this printer and select IBM in the menu of the printer.
Hope this helps.
Dezzi
Sep 10, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Oki 320 Turbo -- Unclear characters in output
If it is not the ribbon, you may have to replace the print head.
Genuine Okidata Print Head
Mfr Part #:
50063802
Hope that helps...
Jun 21, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Alarm light Microline 320 Turbo 9 pin printer - won't print
We swapped out the printer for another one we had in the office that was working. The new printer also got the alarm light. From that we concluded that it was a bad serial card. We swapped the serial card from another printer, and the original printer started working perfectly. Now we just need to find out where we can purchase another serial card, as we have no more 'spares' around here.
May 22, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Oki 320 turbo alarm light
check the mesage in your operating mannual
Sep 13, 2007 | OKI MICROLINE 320 Turbo Matrix Printer
OKI MICROLINE 320 Turbo Matrix Printer Logo
1,303 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
