Samsung LNT4665FX 46in flat screen LCD power supply cycles on/off, with audible que. Blue light at bottom of screen remains lit, but screen remains black. Does not respond to manual on/off or remote control on/off. Disconnected from power source for approx. 10 mins. Power supply energizes and blue light comes without aid of manual on/off switch and TV begins to cycle on/off again as before.
Check out the fixYa solution for the Samsung LNS4051D- it sounds like the same problem. Defective capacitors. You may need different part though.  We just fixed my mom's LNS4051D with that problem. I have the LNT4665 and although it hasn't failed yet, I am tempted to get some capacitors just in case.
Posted on May 18, 2009
IF I CRACKED THE FRONT OF MY LG HD 1080 FLATSCREEN..HOW MUCH WOULD IT BE TO FIX IT?OR SHOULD I JUST BUY A NEW ONE?
Posted on Nov 09, 2008
POLAROID P40LCD12 SCREEN AT BOTTOM COMES ON BLUE FADES THEN GOES GREEN ABOUT 5 INCHES LOST ON BOTTOM TV WORKS OK BUT THE SCREENS STARTS BLUE ABOUT 5 INCHES FROM BOTTOM THAT FADES AND TOP HALF PIC OK BUT...
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 02, 2017 | Polaroid Televison & Video
Samsung TV shutting off by itself and relays clicking
If you don't know what you're doing, don't open it up to fix it!
There are HAZARDOUS voltages on the power supply board EVEN WITH THE TV UNPLUGGED!!! The capacitors can hold a charge for several weeks!
Clicking noise can be coming from bad capacitors on the power supply board.
It's usually easier to just replace the power supply board.
Sep 09, 2016 | Samsung UN55B8500 TV
My TV started to cycle off and on recently
Despite having caps that 'look good', the power supply could be failing.
Aug 16, 2016 | Samsung LN46D630M3FXZA - 46in Lcd Hdtv...
I have a 46in. Samsung LCD TV. It worked lastnight now I tryed to turn it back on and all it does is the power light flashes and it make's a clicking sound can you help thank's very much.
The clicking noise indicates that its a power supply related issue. When the relay switches turn themselves off you will hear that sound. The first thing you should try is to unplug the set and hold for 5 minutes before plugging it back in and turning it on? Why? Because a power surge may have triggered these relays and unplugging them will reset them so that you can see if the set turns on. Otherwise we will proceed accordingly and troubleshoot the components provided you can follow a schematic.
Sai.
Mar 23, 2010 | Samsung 46IN LCD 1200:1 460DX BLACK 8MS...
Samsung lnt 4665fx/xaa lcd wont turnon just makes clicking sound
Sounds like the power supply board has failed, VERY common problem. You can call 1-800-samsung for the nearest service center.
Jan 22, 2010 | Televison & Video
52" Samsung LCD will not turn on. Blue light is on
Have you ssen the back light lit up? If not, the power supply may have problem. If it has back light, then the suspection are the main board, T-con and inverter. Those boards need checked to find out exact defective board.
Aug 17, 2009 | Samsung LN52A850 52 in. LCD HDTV
Samsung LNT4665FX LCD-Clicks before coming on
Bad power relay get it fixed before you have more issues the psu cost around $25 bucks on ebay good luck!
Aug 15, 2009 | Samsung LN-T3253H 32 in. LCD Television
Televison & Video Logo
775 people viewed this question
Top Televison & Video Experts
Electro Med Services...
