Question about Panasonic Microwave Ovens
I have a Panasonic microwave oven model # NNL 939 (1000w) that is what is stated on the booklet. My problem is that both oven lights went out and want to know how to replace them.
  • Panasonic Master
  • 9,098 Answers
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Nov 08, 2008
Can the microwave grill mw11b be used under oven broiler
No, specifically states on user instruction booklet not to. Microwave only.
Jul 08, 2014 | CorningWare Vintage Corning Ware Pyroceram...
Light nn-sa651s
Panasonic FAQ:
The microwave oven model NNSA651S was manufactured in a way that the oven light turns on only while cooking. - FT
Stupid design!!
Feb 19, 2013 | Panasonic NN-S541 Microwave Oven
Where is the high voltage capacitor at on panasonic microwave model nn-sn960s
behind the control panel,while your checking the h.v. cap check the h.v. diode for a shorted condition as this will also blow the 20 amp fuse too
Jan 06, 2013 | Panasonic NN-H275 Microwave Oven
The display window is stating the oven is in "demo mode". We did have a power failure prior to this function happening. What can we do?
I had the same problem after a power cut and eventually thought of switching it off at the mains and turning back on after a couple of seconds... it worked. Just needed to reset the clock and off I went!!! ;-)
Feb 05, 2011 | Panasonic NN-T888S Convection/Microwave...
I wish to download the instruction booklet for my microwave
If yours is a US model, try here.
If it's not a US model, follow the support links here.
Aug 19, 2010 | Panasonic Microwave Ovens
Question: Can the Tastiwave oven be used?
I don't own one but per the TastiWave Quick Start Guide (which can be downloaded as a PDF document), The wattage must not exceed 1300 Watts. In the Instruction manual and quick cook recipe guide (also a downloadable PDF document) it states that:
"The recipes in this booklet have been written for an 1100 Watt microwave oven. Please adjust your “cook times” accordingly. Microwave must have a revolving turntable and the interior
must measure at least 14” wide x 14” deep x 7 3/4” high".
I hope this answers your question ;-)
Jul 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic NNH965BF microwave starts but immediately shuts off
your mag has gone bad and possible that the inverter board as well, not really worth the hassel
Feb 06, 2010 | Panasonic NNH965BF Microwave Oven
Light stays on continuously in Panasonic microwave oven.
Problem solved by adjusted the door to close correctly.
Oct 21, 2009 | Panasonic Microwave Ovens
Operating instructions how to set the clock etc con my mircoware
hit clock button press in the time with the numbers on the pad and press the clock button time solved
Apr 03, 2009 | Panasonic NN-P794SF Microwave Oven
Microwave Ovens Logo
61 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
