Question about Dell E173FP 17" LCD Monitor
Laptop screen damaged?
Hi - yesterday my lcd screen looked like it had a score at the top, about a few cm long, but I couldn't feel any tears on the surface. However, today, there is black fuzziness all along the top (looks like leaking ink), and a huge score running from the original line all the way across the screen to the right hand side. There are also now hazy black lines near the top which weren't there before....any ideas? Is it broken beyond repair???
    President:
  • Dell Master
  • 1,314 Answers
Nothing is ever broken beyond repair, but most of the time the cost of repair actually exceeds what you can purchase a new one for. And with 19" LCDs selling for around $139, you get a bigger screen and less money than it would cost to actually replace the screen on that monitor.
Thanks and please take a moment to rate as fixya.
Posted on Nov 07, 2008
Purple laptop display
Sounds like you either cracked the screen (does it get more colorful with a little pressure?) or that the video cabling has come loose at either the motherboard or the lcd. Find a tear-down video for your laptop model and check these connections. Reseating them should be fairly straightforward.
Nov 10, 2012 | Toshiba Computers & Internet
Acer aspire 6930 LCD replacement is foggy and distorted
hate to say this but it sound like you need another screen replaced
Jul 29, 2012 | Acer Aspire Computers & Internet
I cant fix the backlight of the lcd screen of my laptop
If the Video Cable is damaged, you may want to think about obtaining a new one.
Apparently your solder connections didn't work, or you haven't repaired all of the damage.
Wires could be stretched and broken inside their insulation sheath, and you may not see it.
Use a multimeter, and perform a continuity test of each wire.
Inside the sheath of the Video Cable are wires that lead from the motherboard, and go to the screen Inverter.
You know this.
What you may not know is there are wires inside the sheath of the Video Cable, that lead to the wire/s going to the screen Inverter.
One of these wires may be damaged down in the sheath, and is not visibly apparent.
Suggest replace the Video Cable, and put your mind at ease that it is not the problem.
The CCFL in your Display Assembly is about 2mm Thick, and almost as long as the LCD screen is in height.
Not knowing the exact manufacturer and model number of the laptop;
1) I can't tell you if their is just one CCFL, or two.
The CCFL bulb should be located on one side of the LCD screen assembly. (Unless it is a dual CCFL model)
2) I can't tell you if your LCD screen backlighting is CCFL, or a series of LED lights.
It has been posted that you laptop may be a Sharp PC-GP10-CM
[ http://www.ebay.co.uk/sch/i.html?_nkw=sharp+pc+gp10+cm ]
The wires leading to the CCFL bulb are soldered to the ends of the bulb. Perhaps there is a bad solder joint,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
Me?
I would replace the Video Cable.
Regards,
joecoolvette
Apr 25, 2012 | Computers & Internet
I bought my daughter a lap top from Tesco for her school work. After just a few weeks the screen stopped working. Tesco sent it away to be looked at but sent it back stating that they couldn't do...
LOL, buy a screen off eBay and replace it yourself. Never deal with Tesco again!!! Go to ebay and but in your laptop's model and find a screen. For example if mine laptop was a HP Pavilion DV8000 I would put in the ebay search "HP Pavilion DV8000 LCD Screen".
Or you can check with your local computer repair shops and get a quote from them on repairing the screen. Check with the guys at: http://www.generalsystemsconsulting.com They will fix it and ship it back by Fedex or UPS and most times their price will beat any quote including the shipping charge.
Mar 28, 2012 | Computers & Internet
I haveMy compaq presario CQ40 and my monitor screen got flicker always for past few days and more red horizantal lines @bottom of the screen, where i couldn't see the data,time,date... Plz help me...
This is usually a sign of either a bad LCD screen cable, a bad LCD screen, or a bad display adapter.
If you connect an external monitor & you get a picture without these red horizontal lines, then your display adapter is OK.
Diagnosing a bad LCD screen cable or a bad LCD screen requires that you disassemble the LCD screen panel, & swap them one at a time with a matching part. This way you can identify which part is causing the problem & replace it.
Sep 02, 2011 | Compaq Presario CQ40 Series Laptop Charger...
Hi, I purchased a Samsung N145P 11 days ago, yesterday when I returned from work the screen was damaged as if someone had dropped the notebook, however it was in my house all day and nobody could have...
I would find that highly unlikely, in all the years of service I have never seen what you have described, in all cases it was human intervention. The lcd screens are quite robust unless you leave glasses on the keyboard or other object and close the lid which will crack the lcd or a fall.
Jun 29, 2011 | Samsung N145-JP01US Netbook
Touch screen shows wear and tear
LCD will be replaced as there is no cure for wear and tear on its surface. Required LCD part number is appended below:
A1334748A... FTS BLOCK ASSY (35STMG07)
Available in Sony Parts Store for $154
If you are handy with electronics stuff repair then can replace it easily, remove side and bottom screws and take apart front and rear cabinet of camera. Unlock connector that holds lcd flexible connection wire, remove solder connection of back light source plate from lcd flexible wire, solder back light connections in new lcd flexible wire and insert it in jack on main board of camera.
Local camera repair shop will help you to replace lcd if you feel uncomfortable doing so.
Thanks.
May 19, 2010 | Sony Cyber-shot® DSC-T200 Digital Camera
My dell laptop lcd splashes the OS and then goes dark. It works fine with an external monitor. I have a feeling that there is a loose connection since the top is almost falling off
Think you have answered your own problem here. If the external screen is ok, then the fault lies with the laptop screen.
Solutions..
1.) Remove keyboard top cover (download a "how to" guide if not familar with doing this)
2.) Remove screen bezel
3.) Check the inverter connections (inverter looks like a thin tube)
4.) Check cabling from motherboard to monitor /inverter for signs of fraying, tears, bare wires
5.) Check connections of the cable for damage.
If the above are ok, then you may have a damaged inverter. In any event, i'd look to repairing the damage to the loose lid, as its putting a strain on the wiring
Feb 09, 2010 | Dell Inspiron™ E1505 PC Notebook
We have a chip in our LCD screen.
I'm very sorry but unfortuately if it's showing a bright light then it has damaged the matrix of the screen & the only way to repair it would be to have the screen replaced. Possible you could claim accidental damage under your home insurance to help cover the costs.
Oct 15, 2009 | Televison & Video
Dell E173FP 17" LCD Monitor Logo
124 people viewed this question
Alun Cox
