Question about Panasonic Vacuums
Hi I’ve got a Panasonic vacuum cleaner MC E468 1600W a few years old now but works well up to recent problem. Not picking up I checked the obvious things and found excessive air being sucked in around the hose housing at the back of the vacuum (as it enters the waste bag) On inspection it appears to me as if there should be some sort of gasket that may have perished and been sucked in, however I can’t identify any such part. Any thoughts on what the problem/solution may be will be appreciated. Thanks Keith
  • 328 Answers
The hose on the back might be loose - check to see that the hose is not obstructing anything where it screws in at the back - or indeed the screws may be loose themselves; some of the MCE 468 models had an additional ring washer that sits between the hose and the body at the rear. Usually inside the machine where the bag is, there will be a gasket that fits over the hole of the dust channel leading from the dust bag - if this has come away then its a possible reason to why the suction is poor or excess suction coming off the back of the hose. If however the brush roll has stopped, it may well be that reason alone to why its not picking up as well so you should check the sole plate too as there may be some clogging or the motor pulley belt has snapped. Contact Panasonic UK customer services as they may well have the part for your machine. (http://www.panasonic.co.uk/html/en_GB/544169/index.html)
Posted on Nov 14, 2008
How do I improve suction of the Panasonic mc cl310 vacuum
Hi, it's Jeremy from Crucial Vacuum.
There are a few potential solutions you should try. You can check the hose and canister to make sure nothing is lodged in them. If nothing is there and it does not fix the problem, your issue could be related to your brush-roll. Check your brush-roll to make sure that nothing is interfering with it. If that does not solve the issue, the next area that should be checked is your vacuums filters. Filters should be replaced every 3 to 6 months for optimal performance.
You can purchase direct your replacement Panasonic vacuum parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 05, 2014 | Panasonic MCCL310 MC-CL310 MC CL310...
Hi, I have Pnasonic Vacuum cleaner MC-7650 -2000W,while working machine stops its own.I tried all the way ,all in vain
If it operates less than 15 minutes suspect the filter is blocked and that will cause the motor to heat triggering shut off.
l have seen this and the filter may be washable or not.
Dec 04, 2012 | Panasonic Vacuums
Panasonic vacuum cleaner MC-5030 stopped and don't work
Unplug, check if brush has cord wrapped. Check for fuse, if applicable.
Check power lead in another supply socket. Check for reset button, if applicable. Contact Panasonic technical support for suggestions before heading to service centre.
Jun 17, 2012 | Vacuums
Need owner's manual for Panasonic MC-9420 canister vacuum cleaner
goto> http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Vacuum-Cleaners/Canister-Vacuums/model.MC-3920
Feb 21, 2010 | Panasonic Vacuums
Panasonic MC-E468 vacuum cleaner loss of suction
HI If the cleaner is loosing suction make sure to check all inspection tubes and the dirt channel hoses after the spinning brush. Also check the main hose for any clogging. One of the worst faults of this model is clogging hoses. Hope that helps you.
Feb 27, 2009 | Panasonic MC-E583 Bagged Upright Vacuum
Belt drive
http://www.partstore.com/Model/Matsushita/Panasonic/MCV7395.aspx?SearchTerm=True
Dec 11, 2008 | Panasonic MC-V7395 Vacuum
Order drive belt
Panasonic belt # MC-V2708 is the correct belt for model MC-V7395.
Panasonic Vacuum MC-E450UK
Panasonic MC-E 450UK upright vacuum cleaner.
Just had this problem myself...........easy to get at it when you know how.
Panasonic UK wouldn't help me so I spent some time working it out..........here it is.
Remove the hose from its mounting storage at the rear (called hose clip) where the main body of the vacuum cleaner meets the base of the handle assembly. Remove the screw at the rear of the handle assembly which is behind where the hose 'was' situated and is located inside the deep recess.
Using the soft part of your clenched hand as a hammer, knock the base of the handle assembly at the front and it will slide backwards off the main body of the vacuum cleaner. Don't be scared, give it a thump and keep moving it backwards with a few more knocks.
Next remove the two screws at the front which hold the mains cable and on/off switch cover in place.
Finally looking from the rear once more, lift the plastic 'lug' at the top of the cover and which is part of the cover. This will now allow you to release the cover and pull it forward.
There you go! Told you it was easy!
Watch out for the funny little spring at the front behind the cover in the tiny plastic tube where it connects to the small rubber tubing as it could possibly try to escape.
You now have complete access in order to cut the intermittent part of the cable out and remove it from the 'choc' block.
Happy fixing!!
Jack.
Apr 07, 2008 | Vacuums
Vacuums Logo
202 people viewed this question
Top Panasonic Vacuums Experts
jasbo
jasbo
Joseph Hoffmann
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
