Question about Maytag HAV3460AWW Top Load Washer
Maytag washer fuse is blowing out what do i do, i put a new 10 a fuse in there but it still burned out, cycle wont start
  • 958 Answers
Check the resistance or grounded part in the unit. find the schematics and manually check the resistance of each part and find also which one is grounded. this would make the fuse blow.
tnx 4 using fixya,
Posted on Nov 07, 2008
Maytag washer model # mvwc200xw1.fill but wont agitate what is the problem?
first use a meter and check ur water pressure switch? that is what sends the machine the message to start wash cycle? You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube. If the machine starts to wash. the pressure switch is more than likely good. now take the original hose tube and plug one end and blow into it the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ? sometimes they get busted open or a pin hole and release air causing the water switch diaphram to not open. if both check ok then next the motor coupler or belt if belt driven.check with a multi meter for continuity the door switch, and if there is a little movement on wash cycle in 1 direction only then check the cam dogs in agitator.
Sep 30, 2014 | Maytag PAV2300 Top Load Washer
My maytag neptune front load washer wont start the cycle
you do know that this is the washer that put maytag out of bussiness,if you're having problems with it i wouldn't put a dime into it,replace it.
Aug 02, 2014 | Maytag Neptune MAH5500B Front Load Washer
The fuse blows every few loads
you have an electrical short or surge in the cicuit at the shut down point.
May 01, 2010 | Maytag Atlantis MAV6451 Top Load Washer
Maytag performa dryer suddenly stopped working, as if no power. i replaced both fuses and it worked. ran for about 15 mins and stopped again. any suggestions?
did it blow the fuses a second time.try this .put your dryer on a cycle that wont call for heat and turn it on.if the heat strips are not on and it still blows a fuse it is the motor.if the heat strips are on and it blows a fuse the heat strips are the trouble.
Nov 05, 2009 | Maytag Performa PAV2200
Maytag washer blows 1.5A fuse in back of the top compartment where the dial etc is
There is a micro switch next to the fuse. It is shorted out. Replace the micro switch and solve your problem.
May 20, 2009 | Maytag SAV571EEWW Washer
4A fuse blows when door is opened
You will need to order a coor kit it comes with fuses all parts including fuses there was a door switch problem and maytag sent a door kit to replace old parts
May 11, 2009 | Maytag Washing Machines
Front load washer doesn't spin
My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Start by making sure the machine is plugged into a live (working) electrical outlet. Then check the appropriate circuit breaker and reset it if necessary (or check the fuse if you have a fuse box).
Next, inspect the drain hoses and remove any kinks. Take a look at the drain, too - if it's clogged, call your usual drain service person.
Then close the washer door and firmly press the START/STOP button. In a few moments, after the door locks, the washer should begin to spin. (For your safety, the washer will not tumble or spin unless the door is closed and locked.)
If this doesn't work, please contact Customer Service at 1-800-688-9900 for toll-free assistance and service scheduling if necessary.
Sep 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune on/off button wont stay on
You have to investigate where the burning smell came from. Start at the timer and then check the main board. Also check the drain pump.
Oct 23, 2007 | Maytag MAH6500 Neptune Front Loading...
Maytag HAV3460AWW Top Load Washer Logo
70 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
