Indesit w1a101 the filter is blocked but i do not know where it is, can any one help?
You have to remove the bottom bit of the front of the wamchine, you might need a knife, and the filter is behind that.
Posted on Nov 08, 2008
Indesit dishwasher 705. Error codes 1 and 3 (left to right) flashing. Not blocked filter as it drains water away.
Find the error code on the web so you know what the washer is complaining about (Google it). Because the washer drains water does not mean the filter is not clogged. Remove the filter and clean it to be sure.
The error code will point you to the requisite corrective action. An error does not necessarily imply failure, but it usually means just that.
Until you know what the washer thinks is wrong, you have little chance of correcting it.
Good Luck,
Pete
Jul 19, 2015 | Indesit Dishwashers
Indesit washer not draining
Check filter not blocked and pump turning freely
May 09, 2012 | Indesit Washing Machines
My WD 12X machine is not drying the clothes. They get hot but not dry. Is there a filter somewhere that needs to be cleaned?
Presuming that this is an Indesit WD12X.
Yes, there is a filter at the bottom left of the machine (It can be clearly seen in the illistration on Page 14 of the manual, figure 6).
If you don't have a manual, you can download a PDF of it here:
http://www.indesit.co.uk/indesit/_pdf/manuals/19503326500_UK-USA-AUS.pdf
It's highly likely that the water isn't getting evacuated because the filter is blocked and so there is just too much water to dry. Unscrew the filter, clean and replace. I'm amazed to discover that (so far as I can see) The manual never even mentions the filter! Well done Indesit
Jul 19, 2011 | Washing Machines
Ive got a indesit 1000 wil103....it seems like the filter is blocked but im unsure of where it is, as i put clothes in the machine but they come out dirty! please help!
Filter if this model has one down Bottom left hand side of machine , remove bottom plastic cover to see this, put down an old towel to save flooring ..good luck
Nov 19, 2009 | Indesit W 123 Front Load Washer
Indesit DI620 but won't drain the water after a wash
are you finding water in the filter or is the appliance filled with water,if it is only in the filter at the end of the cycle,this is normal as it is used to condensed the steam after the 80o final rinse which drys the cutlery.if ithe appliance is filled then check the drain hose not partily blocked with grease or partly blocked at the sink if plumbed to there
Apr 28, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
No instructons for W1A101 indesit washing machine
Head over to the manufacturer's website.
Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 14, 2009 | Washing Machines
How to reset indesit w1a101
to cancel program, move dial to any of the black dots and press start for a few seconds. neon will flash rapidly when program cancelled
Jun 25, 2008 | Washing Machines
Indesit widl126s
Suggestion: Possible your outlet filter is blocked; this needs periodic cleaning, depending on your usage. Clean this out and re-fit. Refer to your users' manual re. where the filter is....
Jun 15, 2007 | Indesit WA 125 Front Load Washer
Will not spin
When your water does not drain or spin, check the outlet filter first, then the pipe from below the tub to the filter. Your washer wont spin 'cause the pump/filter is blocked. There is a small door on the front, below which is the place you have to clean out first.
Dec 05, 2006 | Indesit W 123 Front Load Washer
Washing Machines Logo
565 people viewed this question
Top Washing Machines Experts
