Question about RCA CC6263 Camcorder
How to remove safeguard mode from rca autoshot 200x digital camera
Unable to remove safeguard mode from rca autoshot 200x digital camera
5 Suggested Answers
SOURCE: Error message: E03 Unit in Safeguard Mode - Remove and reattach battery
HI, ERROR CODE E03 MEANS THE THE TAPE IN YOUR CAMCORDER IS TOO SLACK, ALL YOU NEED TO DO IS EJECT THE TAPE & TIGHTEN IT USING YOUE THUMB LIKE I DID, ONCE I PUT THE TAPE BACK IN THE ERROR HAD GONE ( FOR EVER I HOPE!) GIVE IT A GO ANYWAY, HAYLEY X
Posted on Mar 21, 2007
SOURCE: safeguard mode
My camera is on unit in safeguard mode and it says eject and reinstall tape! What do you suggest??
Posted on Sep 22, 2007
SOURCE: Error Code EO3 System in Safeguard Mode
Its a problem with the cilindrical thing in the tape holder
i blew air at it untill it spun an it worked
Posted on Nov 27, 2007
kala
  • 156 Answers
SOURCE: safeguard mode/remove battery & reattach
There should be a error code,what is that?
Posted on Feb 25, 2008
SOURCE: E04 unit in safeguard mode
i call a camera repair center and they tell me to Open the cassette door remove the battery for a day or two and i try open the cassete door and the safe guard mode went off but i got to try using the camera for a couple of hours to see how is doing.........................................
Posted on Mar 28, 2008
What kind of charger do I need for RCA autoshot 72x camcorder
suggest you contact the manufacturer thru their website customer support
Apr 10, 2015 | RCA Video Cameras
Where can I buy a battery charger for my rca autoshot
easy, type in the name in a search engine and you can find it that way
Oct 22, 2014 | RCA Autoshot Cc4352 3 Inch Lcd Color...
GOT A AUTOSHOT 200X CC6363 THAT EVERY TIME YOU TURN IT ON GET ERROR CODE E04 & WHAT DOES IT MEAN
E04 - Battery in Safeguard mode.
The most common problem with this kind of model. there actually no fix for this problem. Unless of course your a jvc technician and can manage to open and clean all the sensor inside.
Have you tried to most popular solution for that.. tapping a little bit on the side of that camera. lol.
Look closely with the memory card, make sure it is inserted properly. push it a little more.
You may need to remove the battery from the battery pack and then reinsert again before turning it on. Doing it a few times may help solve the problem.
I do suggest you remove the battery when not in use. Leaving the battery inside is the usual cause for having the E04 when turning it on.
Hope this helps.
Mace1Mace
Dec 25, 2010 | RCA Video Cameras
Safeguard mode
Eject tape compartment and let it open, remove battery and blow hot air by hair-dryer from 8 inch distance for 8-10 minutes and attach battery and check camera works fine?
Feb 10, 2009 | JVC GR-D73AG Mini DV Digital Camcorder
Need unit to put tape into, to play in vcr
What you need is a VHS C adaptor. I did a Google search and found at least 10 sites selling them. Rather than cut and paste, I suggest you go to Google and type in "VHS C Adaptor".
Oct 29, 2008 | RCA CC6263 Camcorder
Unit in sageguard mode
"safeguard mode" indicates a hard failure, normally associated with the mechanism. Try ejecting the tape if one is in the unit. Do not force the mechanism open as it will cost more have the cam repaired. If tape is defective and can be removed, try using a cleaning tape first, then a known good tape.
Dec 25, 2007 | JVC Digital Video Camera
Safeguard mode
Jun 03, 2007 | JVC GR-D275 Mini DV Digital Camcorder
RCA CC6263 Camcorder Logo
155 people viewed this question
Top RCA Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
