Question about Nokia N70 Cellular Phone
DCT3 flasher i have a problem w/ my flasher for DCT3 phone, the Fbus not working, if theres any body to help me how to fix this problem pls help me. im using windows xp, and the dct3 flasher i used is rollis.
  • marlozer Nov 08, 2008
    thank you very much.
  • 49 Answers
Reinstall ur dct3 flasher software it help u or see slot is not damaged
dont use flashind device it cam damage ur phone software use *#7370# code to formate ur phone
i guarantee my solution is always right
plz dont forgetme to rate on fixya (blue line)
Posted on Nov 08, 2008
My nokia 3110c mobile was disconnected while software update was going on, after that it is not switching on
Good Day,
With that unfortunate event, your phone is now "dead". But it can be "revived" by Flashing it again through FBUS connection. Fbus connection is by using special "Boxes" such as JAF, Twister , or Universal Box. Specialized Cellphone Technicians have these so called boxes. If you can find a cellphone Repair shop, specializing in Nokia phones (certified), you can bring that there and have "re-programmed".
If possible, it would be better to bring it to a Nokia Care Center for better service.
There would be no other way to power that on, or even try to connect it to USB and flash with the Nokia Software updater. There are "tricks" but it sometimes bring more harm to the phone than good, so better opt to have "professionally" done. The state you phone is in now, is like an erased firmware, or corrupted firmware. Use of third party " uncertified" / non tested flasher and flashing procedure, may have your phone end as useless, like corrupted Security area, erased IMEI (12345679? IMEI), locked phone etc.
Hope this helps. Thank you for using Fixya.
Jul 10, 2011 | Nokia 3110 Cellular Phone
How to open line my n96 phone
You have to find out if your Nokia phone is a DCT3 or a DCT4 model. According to www.unlockme.co.uk, supported DCT3 models are the following:
2100, 3210, 3310, 3330, 3410, 5110, 5146, 5130, 5146, 5210, 5510, 6110, 6130, 6150, 6210, 6250, 7110, 8210, 8810, 8850, 8890, 9110, 9210The same website also posted that the supported DCT4 models are:
1100, 1101, 2300, 2600, 2650, 3100, 3120, 3200, 3220, 3230, 3300, 3510, 3510i, 3650, 3660, 5100, 5140, 6020, 6021, 6030, 6100, 6101, 6170, 6220, 6230, 6230i, 6250, 6260, 6310, 6310i, 6510, 6600, 6610, 6610i, 6650, 6670, 6681, 6800, 6810, 6820, 6822, 7200, 7210, 7250, 7250, 7260, 7270, 7280, 7600, 7610, 7650, 7710, 8310, 8800, 8910, 8910i, 9300, 9500, N-Gage, N-Gage QD(Note: You can Google search other phone models that are not listed above at the same time find out if they belong to either the DCT3 or DCT4 category).
Step 2
Find your unit's IMEI by pressing *#06# on your phone keyboard. The IMEI, or International Mobile Equipment Identity, is a unique 17 or 15-digit code used to identify an individual mobile unit in a GSM network. The IMEI uniquely identifies a specific mobile phone being used on a mobile network.
Step 3
After getting the necessary information, you may now enter your IMEI in the corresponding box at the unlock.NokiaFREE.org website. Again, you will have to make sure if your unit is a DCT3 or a DCT4 model to arrive with a correct unlocking code. Follow the given instructions to complete the process.
Hope this help
Feb 03, 2011 | Nokia N96 Cell Phone
My mobile is not working ,at the time of working some files corrupted and it showing not enough memory while i wants to play music now it's not going to switch on
hi,
lets try to fix your problem without spending a single cents..removed your micro sd ,(small memory card of your phone) then scan it in computer,,by doing this you need an all in one card that supported mini sd,mini sd ,memory stick etc..then you will find if your micro sd is having a virus..back up your files then reformat your micro sd ,then after formatting back your files...without your micro sd open your phone ,if it is ok now ,so the problem is your micro sd...if still there the problem ,reset your phone by doing this ,type *#7370# and enter your locked code..wait until the phone reboot itself.
if not works we go to the second solution but you need this gadget and tools in able to fix your problem...
1.mxkey dongle activated
2.ufs interface
3.7210c fbus cable
*open mx key
*select BB5
*put the fbus cable in 7210c
*put the mcu ,ppm ,cnt ..(the flash file must be higher than former version to prevent damage on phones software ,the old version shall appear when you scan or bus check the phone..)
*bus check the phone
*back up rpl first in mx key
*flash the phone and wait until it is done..
goodluck and thanks for trusting fixya..
Jun 22, 2010 | Nokia 7210
Sir, i have problems with my nokia 3110c phone. I cant play music trough music player. When it updated shows no music files found. And i have meory loss also and some time my phone switch off. Is this...
hi,
2.ufs interface
3.3110c fbus cable
*open mx key
*select BB5
*put the fbus cable in 3110c
Jun 21, 2010 | Nokia 3110 Cellular Phone
When my 3110c phone on<its 3time on off and next time sucsessfully off...pls help me...
hi,
2.ufs interface
3.3110c fbus cable
*open mx key
*select BB5
Jun 20, 2010 | Nokia 3110 Cellular Phone
My fone is not switching onbut after few sec. it flashes on and off
hi,
2.ufs interface
3.3110c fbus cable
*open mx key
*select BB5
Jun 19, 2010 | Nokia 3110 Cellular Phone
Nokia 6300 software problem
BB5 Series do this kind of things when the certificates got corrupted !
There is no way to fix on your own without holding some Fbus Cable and without any equipment !
  • Solution : Take your phone to Service Center
Best Regards
Jun 25, 2009 | Nokia 6300 Cellular Phone
Have forgotton my security after changing 12345,pls help
Go to your nearest Nokia service center they will update your phone's firmware version plus your lock code will also be reset to defaul code.... for free.....No Charges applied for doing this... or u can try
Try to
Download this software :-
"MasterCode.sis"___(DCT3-4MCODE)
Install it any S60 based Phone and enter the serial no of your Phone
and it will give you a mater code of your phone.
Don't forget to rate my solution Plzzzzz
Jun 08, 2009 | Nokia 5200 Cellular Phone
Stopped working while updating
Your device needs now FBUS Flashing (from the backside behind the battery) you mainly need now service equipment to do the job. The more expensive alternative is http://www.odeon.cn/ jaf flasher and the cheaper one it to give it to a service company to repair it with around 15 euros.
Your phone simple needs a software update again.
Feb 11, 2008 | Nokia 6233 Cellular Phone
Nokia N70 Cellular Phone Logo
106 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
