Question about Lentek Intelli Vac Robotic Vacuum Rapid Charger Vacuum
Lentek intelli-vac won't hold a charge and we have purchased a new battery.
We have charged the new battery for over 24 hours and it is a stronger battery. When I unplug it the vac will move and inch and then say charge battery. Thanks for your help in advance.
How long does it take to charge the cordless vac?
The basic rule of charging is "charge for 3 hours for every hour of use".
You won't hurt anything if you charge it overnight, but don't leave it charging for more then 24 hours.
If you wear the battery out eventually, Batteries Plus can re-pack the battery.
Nov 18, 2016 | Vacuums
My DD hand vac won't hold the charge for more than one minute and just fades away! It has been charged for 24 hours.
Hi there! Your battery may need to be reset. Try depleting the battery. Run the vacuum until it completely shuts off, then re-charge for a full 24 hours. Hope this helps out! If you still have questions you feel free to reach out to us here on Fixya, Facebook.com/dirtdevil, or Twitter @DirtDevil.
Jun 30, 2014 | Dirt Devil Vacuums
Shark won't hold charge
How long are you letting it charge for? It's also possible the battery is defective, or there is a short in the vac.
May 26, 2012 | Shark Vacuums
The batteries will not hold a charge very long before it stops working.
Sorry to read about your problem, I hope this helps you out.
defective batteries time for new ones
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Vacuums
New battery. Charged for 24 hours. Light is green, but after 20 seconds light turns red and it stops.
There's a chance that the battery you bought is bad. There's a greater chance that the problem is with the charger. If you're using the dock to charge, try plugging the charger directly into the roomba just to rule that out. If that doesn't fix the problem, I would try borrowing or buying a new charger, and see if that works. If a new charger and new battery don't solve the problem, the problem must be with your roomba itself.
Sep 25, 2009 | Roomba Robotic Floor Bagless Vacuum
Model4210battry won't recharge, is it worth ordering a battery?
don't buy a new battery yet. you can reset the battery by charging for 16 hours, if this does not work, you need to take the battery out, push and hold the power button on your roomba for at least 15 seconds then reinstall the battery. plug in the charger directly to roomba not the docking station and charge until the battery light on the roomba is green. do not interrupt the battery charging cycle. after, leave the roomba charging for an additional 3 days or 72 hours. after, run roomba in max mode and run it till the battery is completely depleted. this will improve the battery overtime by charging again for 72 hours and depleting the battery. do this 3 or 4 times. and the battery should get better
Jun 28, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Cordless vac won't hold a charge
Like all batteries after a while they go bad/will not hold a charge. especially the kind that is always plugged in/always charging, like electric shavers, cordless vac and so on.
get a new battery
thanks for rating
Jan 14, 2008 | Vacuums
Lentek Intelli Vac Robotic Vacuum Rapid Charger Vacuum Logo
42 people viewed this question
Top Lentek Vacuums Experts
Are you a Lentek Vacuum Expert? Answer questions, earn points and help others
