Saunier duval isofast f35e condens boiler is making loud vibrating kind of sound when hot water tap is turned on. Could this be the fan? Boiler is 15 months old
  • adrian69 Jan 15, 2009
    I have the same problem. My boiler is also 15 months old, and everytime you use the hotwater the pipes bang. Also sometimes there is no hot water at all only tepid and the heating comes on by itself, although it is not timed to and the eco temp is set at 6 degrees. AND it loses pressure quite often and forget using a tap and having a shower at the same time. Plumber been out twice, the problems are getting longer with this boiler.
zeusfaber
  • 247 Answers
SOURCE: Vaillant Ecotec combi boiler -
David,
The fact that you're getting a little burst of domestic hot water suggests that the boiler is capable of circulating hot primary loop water through the heat exchanger, but doesn't necessarily do so when it needs to.
What seems to be lacking is a recognition that domestic hot water is now being drawn off, and that the boiler needs to fire up and divert the primary flow through the heat exchanger.
A good place to start might be the flow switch (usually in the bottom of the boiler, where the cold water supply comes in) or the electrical connections to it.
A.
Posted on Oct 07, 2008
jcpark50
  • 52 Answers
SOURCE: boiler making a loud hissing
sounds like a stuck expansion valve, the compressor makes pressure, but it can't be released to absorb heat from the desired environment. You could go to the manufacturer's website, request a detailed diagram of your system, find the expansion valve and order a new one. Can you put it in yourself and recharge the system? Probably not, call a repairman.
Posted on Nov 07, 2008
SOURCE: hi,i have a vaillant turbomax
I had this. Open up the main case, take the second inner case front off to expose the boiler.
Clean the thermocouple which detects the flame being lit with some steel wool held with needle nose pliers. It will be all sooty and will turn off the gas as a safety precaution if it does not detect heat fast enough.
Don't listen to the gas man who will say "needs a new circuit board mate" as this is usually a stock response.
Posted on Jan 05, 2009
SOURCE: Repressurise Potterton Performa 24 boiler
hope this is helpful. On my potterton 24 combi boiler it is the valve that sits the lowest, with a slight indent in the black tap. if you turn this for a short period you will hear a hiss and the pressure will quickly build to the desired pressure, when you can them turn the tap back off.
Posted on Feb 05, 2009
  • 3 Answers
SOURCE: How do I increase the water pressure on the saunier Duval boiler?
not enough infromations give more detail
Posted on Dec 09, 2009
SAUNIER DUVAL model 31-026. Where can I obtain a troubleshooting manual?
Boiler Manuals: Saunier Duval - Plumbase
https://www.plumbase.co.uk/documents/index/10000204
Boiler Manuals for the Saunier Duval range. ... Saunier Duval Thema Range · Saunier Combitek F23E · Saunier Duval Isomax F28E · Saunier Duval Sylva ..
Aug 20, 2015 | Heating & Cooling
Saunier Duval ISOFAST F35E on hot water only makes a noise like a motor bike that vibrates through the pipework, this does not happen when the central heating is on, any ideas as to the cause.
The water pipes (steel) are probably full of rust. The noise is air in the pipes.
Use the pressure relief valve to let air escape.
The risk is if the relief valve is old it may not shut off.
Also air will build up again
Nov 05, 2014 | Water Heaters
Where is re ignition location on saunier duval condens f24 e
Wrong category !! Try question in the correct category !
Dec 19, 2013 | KDS Valiant 6380iPTD-01 Notebook
Boiler pressure saunier duval
Appear to be corroded/plugged inlet valve. De-pressurize system and check inlet valves and line.
May 11, 2013 | Water Heaters
Low pressure Saunier Duval therma condens boiler
May need to replace valves (appear to be corroded and plugged with deposits) and install a water conditioner in the inlet line if you have hard water.
Hi, I have a Saunier Duval? Theilea twin 28e
You may want to check the Pressure Reducing Valve On the supply line to the building. Easiest way to check is get a guage that hooks up to your hose bib (usually found in the sprinkler section at your hardware store). If your pressure is getting above 80, you need a new PRV.
Feb 14, 2011 | Water Heaters
Low pressure for SAUNIER DUVAL TERMACLASSIC
there is a blue tap at the bottom of the boiler when you turn it and nothing happends the screw had broken off inside you can do 2 things here put a new filling tap on the boiler , or get a filling loop put some where else on the system and if you still get low pressure replace the low water pressure switch...
Jan 31, 2011 | Heating & Cooling
Hi, Got a Saunier Duval Thema F 23 E and need to repressurise it (currently at 0 bars). can you provide any help on how to do it? Thanks.
http://www.saunier-duval.co.uk/manuals/pdf/noncurrent_products/installation_ThemaF23e-SBF23e.pdf
Here are complete instructions for installation and service including purging air and refilling. One of the first suggestions is that service is to be referred to a competent technician.
Gary
Dec 18, 2010 | Water Heaters
I have a 11 year old Saunier Duval and the hot water hardly works
suggest you call a repair service. gas appliances are dangerous to DIY they explode when people do not use the proper safety precautions
Aug 31, 2017 | Combi Centre DX - Mango
Heating & Cooling Logo
330 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
