Question about JVC GR-SXM740 S-VHS-C Analog Camcorder
Tracking problem When I record, the picture looks fine. When I playback, the picture has lines as if there is a tracking problem. I tried adjusting the tracking, but it does nothing. What can I do?
2 Suggested Answers
  • 4 Answers
SOURCE: JVC GR-DX76 - No Picture
which view finder? contrast or brightness?
Posted on Apr 24, 2008
SOURCE: tracking appears to be out - can it be adjusted?
Giving in and taking the camera back to the shop for repair!
Posted on Jul 07, 2009
0 characters
1 Points
I have recently acquired a sony analog video camera model CCDF-201 this camera plays back previously recorded 8 mm tapes but when I try to record with this camera the screen is running lines through the...
The problem is with the CCD which is the sensor when it is defective the pictures get disturbed also.Please replace the CCD from any service center,
Aug 27, 2010 | Sony Video Cameras
Rolling of picture
You camera is PAL and you are attaching with Ntsc TV or VCR. Both Pal and Ntsc are different systems and incompatible to each other.
If you want to see correct playback of your Camera, it requires Pal or Multi-System color TV.
Need further info, please let me know.
Oct 04, 2008 | Sony Handycam CCD-TRV68 Camcorder
Streaks in playback
the first thing i would do would be to try a head cleaning tape-if that doesn't help see in your book or menus if you can adjust the tracking on the camcorder-when the tape heads get worn over time they need to be aligned and that is what tracking does-some older models allow you to manually adjust-good luck!
Jun 12, 2008 | Canon ZR60 Mini DV Digital Camcorder
Tracking seems off
I have had the same problem. There is no way to manually adjust the tracking on this Hitachi, or on most 8mm cameras, for that matter. I copied all of my more recent tapes to DVD first (2 copies of each) and then I went to the oldest tapes, which for some reason were OK. When I got to one tape that gave me trouble, I just let it play in the camcorder for about an hour. It adjusted its own tracking so that the picture was OK. Then, I rewound the tape and copied that one. I still have 2 tapes that will not adjust. I am going to send those out to a copying service. I hope they can adjust the tracking and make the copies I need.
By the way, I used this camera and a Panasonic DMR-E55 to make the DVD copies.
Jun 04, 2008 | Hitachi VME545 Camcorder
It's not tracking -- it's dirty heads -- you can purchase an 8mm head cleaning cassette and use it to cure these problems. Tapes recorded with the dirty heads may still have issues afterwards.
Nov 17, 2007 | Hitachi VME535LA 8mm Analog Camcorder
Hi8 playback problem
your guides have come loose , probably - the digital sound will be next to go because the bottom edge of your tapes are being folded - open the cassette tape lid by pressing the small pin near one hinge and gently lifting the door - if there are any creases ? get the guides aligned ! to protect your library ; ( if there are no creases , try a sony d8 cleaning tape - once ! before getting a repair quote ) ;
Jul 27, 2007 | Sony Handycam DCR-TRV460 Digital Camcorder
My camcorder not playing back
First, try head cleaning by trained technician. Tech will clean manually with cleaning chemical each head to make sure video heads are performing 100%. Otherwise, they will probably quotes you for tracking adjustment. Head cleaning is typically around $25-50. Tracking adjustment might cost you around $100-200 in US depending on service time.
Mar 17, 2007 | Panasonic Palmcorder PV-GS14 Mini DV...
Partial static in playback and record even after head cleaning
Replacing the cylinder with video heads part number A7048897A will cure the problem. If you need more help please advice. Arpi
Mar 16, 2007 | Sony Handycam CCD-TR517 Camcorder
JVC GR-SXM740 S-VHS-C Analog Camcorder Logo
21 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Larry Stiles
Larry Stiles
Shekar Avadhani
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
