Have set up my lexmark z845 put new cartrides in and while installin printer its saying unsupported cartridges
  • Francisco Cortes
    Francisco Cortes May 11, 2010
    this is pretty obvious based on your question.. so forgive me if asking you to confim something obvius: are you positive you're using the right cartridges?.. post the details of the cartridges you're using and we'll help you confirming if that's the case.
    Scholar:
  • 81 Answers
It is really in need that if you replace cartridges of printer is the same of what is originally installed because the terminals of printer might not in contacts with the cartridge. but if the terminals are in fit and are in the same patterns then try to update drivers to lexmark website if have some available drivers update for enhancement. or you really have to replace it with the same as originally installed.
Posted on Nov 15, 2008
I'm trying to get my X2670 printer to work but can't. Initially the power cord was not included but I have since hjad that sent to me. It now says I'm using an unsupported cartridge. Th
What cartridges does it say to use in the manual? Maybe the wrong ones were put in the box. After all they evidently forgot the power cord! Please rate my answer so I can get points awarded for it.
Jan 16, 2012 | Lexmark X2670 All-In-One Printer
Lexmark x4650 refilled ink cartridge but printer says it's empty and won't print
Lexmark does not recommend using refilled cartridges. However, if you have successfully used one before, there's a possibility that the refilled cartride got damaged along the process of refilling. Try to insert a different known working cartridge to determine if the other is faulty. Or better yet, try to purchase a new genuine Lexmark cartridge.
Jun 14, 2011 | Lexmark X2500 All-In-One Printer
Error 32 Unsupport Print Cartridge Lexmark T630
on the inside of the top cover on the left side when the door is open there is a little switch youll see a little metal tab 5/16'wide push on this and see if the error clears. if it does this can be adjusted. if not pull the cartride out there are two sensors on the right inside one close to the front this is an optical sensor blow this out with canned air if you dont have an air compressor. then further back inside there is a two pin sensor make sure that if you push in on these that they dont stick. next there is a smart chip on toner caartridge that lines up with those pins when its installed clean these contacts. doing all of these things usually geets rid of the problem. no parts have been replaced recently right? check the connector to the logic board this is theeonly 3 pin connector that has black and white wires. this sohlud fix your problem
Nov 24, 2009 | Lexmark T630 Laser Printer
Lexmark x9350 won't recognize new cartridges
hmmm this s the prb in u r printer settings...u jus give a print test after fixing the new cartridges...then if it works then there no prb in cartridges...or else there s dust in the printing rod...u jus want to giv the printer for service so that they will clean the motor of the printer and u r printer s set for working...cool!!!!
Jul 25, 2009 | Lexmark X9350 All-In-One InkJet Printer
Using refill cartridges
That is because they cannot e refilled. The ones you get with your printer ( 28 & 29) are what Lexmark calls "return program cartridges", which means they are for one use only.
I suggest you buy other cartridges that can be refilled. Those are either 28A or 34 (black cartridge) and 29A or 35 (color cartridge).
Here is a link to Lexmark's site, where you can see the list of cartridges that are compatible with your printer.
http://lexmark-cartridges.com/cfv2/printer.php?lang=uk&partner=&productName=Lexmark+Z845
Hope that helps!
Jun 05, 2008 | Lexmark Z845 InkJet Printer
Using refilled Cartridge for Lexmark z845
eagle338
Rank:wizard_s.gif Wiz
Rating: 79%, 740 votes
The only work around to this is to use two catridges(2 color and 2 black and white). The reason is the printer has a mechanism to check if the same catridge is being used again. SO when you have two cartridges when one is finished refill the other and use and vice-versa. This way you will be able to refill and use for ever without any problems..
Regards,
Eagle338.
Apr 20, 2008 | Lexmark Z845 InkJet Printer
Refilled color cartridge for lexmark Z845
Regards,
Eagle338.
Mar 13, 2008 | Lexmark Z845 InkJet Printer
Unsupported printer cartridge
uninstall printer, reboot and then reinstall using the lexmark printer cd or downloaded drivers.
Mar 10, 2008 | Computers & Internet
Unsupported cartridge error
I have an X5495 Lexmark and have recently been getting this **** "unsupported cartridge" rubbish. OS is XP SP2.
My history with this printer has been:
-when new, the printer worked fine until I needed to replace the original ink tanks. I refilled them, but could not get the printer functional again....nil print at all. After much frustration, I was informed by a little birdie that the cartridges that originally come with the printer will not work if refilled. Great. They are one use only.
-replaced with genuine high yield tanks. Then worked fine. Refilled once, possibly twice with suitable non genuine ink. Still working fine.
-once black ink tank ran low this time, refilled it and symptoms of no print from Word docs, not all parts of a web page would print. Surprisingly, photos off hard disc print ok.(??????)
-replaced black with genuine tank and colour with remanufactured tank. Error message of "unsupported tank". Now no print at all.
-left new genuine black cartridge in and refitted genuine colour cartridge that I have previously refilled.
-all print now ok.....finally.
Maybe they have a copy limit or the integrated print head in the black has crapped itself????????
During this process, I have uninstalled and reinstalled the driver several times.
I have found that it has to be COMPLETELY uninstalled. Using the Lexmark uninstall function does not remove all parts of the software (Lexmark toolbar for one). If the software is not completely uninstalled, you will get a spurious unrelated and rubbish pop up that installation cannot continue because of "insufficient processor speed" with a spurious set of numbers after it. This message bears no relation to the solution.
I have found that you need to search and delete ALL Lexmark files that you can find after the uninstall. I have also deleted entries from registry.....1 entry only from memory (be CAREFUL with registry). Then reboot system.
The driver should then reinstall correctly and fully.
Why do they make it so damn hard? Don't think I'll buy a Lexmark next time.......
Sep 05, 2007 | Lexmark X2350 All-In-One InkJet Printer
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
