Question about HP Computers & Internet
Director Want Launch - HP Computers & Internet
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Hello there,
I imagine you say, director from Hewlett P. Printers? well, depending on the OS, for XP, go directly for MSCONFIG and then disable director, this whould fix the problem, not, unintall the program of course.
good luck
OSky
Posted on Nov 14, 2008
I'm trying to scan a document, but the computer I want it to go to is not on the list. Also the computer is not recognizing the printer as also a scanner. The printer is an HP OfficeJet 7310...
is the solution center or hp director installed on the pc? look under add/remove and check if it's included in the list of programs installed. if it is there,look for it's icon on the desktop or click on start,all programs,hp folder,hp director and hp solution center.launch it from there.use it to scan from your computer.check for error messages and let me know.
if it is not installed ,you may need the disk to install it.or go to hp.com and click on support and drivers to download the latest version of the printer software.
May 27, 2011 | HP OfficeJet 7310 All-In-One InkJet...
I need a OfficeJet 7410 installation CD because my HP Director software no longer shows any scanning options in the opening screen. Can't use scanner from PC. Thanks, John
HP has now changed the HP Director to HP Solution Center with extra features. Downloading the latest software will help you install the new HP solution Center.
You have not mentioned the PC operating system like Win XP, Vista, Win 7.
Click on the download link below to launch the HP software and drivers page.
Choose the operating system to download the software for your printer
Download Page
Nov 03, 2010 | HP OfficeJet 7410 All-In-One InkJet...
My sony action buttons dont't work. Is there any way I can fix that. Please help me with that. Thanks alot
if its notebook
1) software: check quick launch buttons driver for your laptop model
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=1,24,72&DIRECTOR=DRIVER&TC=b2b
2) hardware : maybe the cable between the buttons and the board
hope that i help you
Feb 05, 2010 | Sony VAIO VGC-JS230J/S PC Desktop
Emedia guitar master not able to run after installation
Windows® Vista Error on launch:
“Director Player has stopped working” or “Macromedia Projector has stopped working” Most likely this problem is solved with the following steps:
  1. Click the “Start” menu and launch “Computer” from the right hand panel
  2. Navigate to the eMedia Guitar Master installation directory (typically this is inside your C: drive > “Program Files” folder)
  3. Navigate to the “Xtras” folder within your “eMedia Guitar Master” folder
  4. Delete the file called “SequenceXtra_1_9.x32”
Launch Guitar Master. It should open properly.
If the above solution fails to eliminate the problem, take the following additional steps:
  1. Click on the “Start” menu and navigate into the folder to the eMedia application.
  2. Right-click on the program icon and select “Properties.”
  3. In the box that pops up, select the “Compatibility” tab.
  4. Check the box “Disable visual themes.”
  5. If you can, check the box “Run this program as an administrator.”
  6. Click “Apply” and then click “OK.”
If you continue to experience problems with Vista, please make sure that your system is up to date. Download the latest updates for your operating system at support.microsoft.com. Get the latest version of QuickTime at www.apple.com/quicktime/download.
Dec 29, 2008 | eMedia Music Corporation Guitar Songs Vol....
HOW DO YOU USE THE hp PHOTOSMART c4385 SCAN FUNCTION?
Don't try to scan from the printer control panel.  You need to launch the "HP Photo and Imaging Director" from your computer.  I have HP Photo & Imaging SoftwareVersion 2.0 installed which I believe was obtained from the HP site for the C4385.
The scan function works fine if you use this software.
Dec 05, 2008 | HP PhotoSmart C4385 All-in-One Printer
No Scan options
launch hp director to configure scanner profile
Nov 28, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP director won't start up.
First check the version of internet explorer if it is Ver 7.0 then it is a issue with the ver of internet explorer.
If then follow the steps in thye below link:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00802504&dlc=en&product=79499
Good Luck
Apr 11, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 1315
If the patch or the updates did not work on the link I sent you try this Workaround: Open HP Director each time you use it If the update to HP Director is not available, or if you have installed the update and the HP Director window still fails to open, try this workaround.
  1. From desktop, double-click the HP Director icon to load the program into the memory. HP Director will not open at this step. Do not click anything else on the screen until Step 2 is completed.
  2. Press the Alt key and the Space bar together, and then select Minimize from the menu that appears at the upper left corner of the window. If necessary, click it again until HP Director minimizes. HP Director software displays as an item on the task bar (the row of open software programs that appears at the bottom of the desktop screen).
  3. Click HP Director on the task bar. The software opens and displays normally.
  4. Repeat Steps 1 through 3 every time you use HP Director.
    NOTE: The HP Director window might appear larger than normal, but the software is functional.
Cause In October 2006, Microsoft released Internet Explorer 7. The HP Director software that shipped with some HP products introduced between 2002 and 2004 may not be compatible with Internet Explorer 7. The HP Solution Center software, which replaced HP Director software on products introduced after 2004, is compatible with Internet Explorer 7 and does not exhibit this issue.
Mar 17, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP Director
Try to open the HP director from
Start >> All programmes or programmes >> HP >> HP director
Else reinstall the printer software.
Mar 14, 2008 | HP PSC 1315 All-In-One InkJet Printer
ok...try a test page first, with printer off the computer completely
and..check for newest printer drivers here
Feb 19, 2008 | HP PSC 2210 All-In-One InkJet Printer
Computers & Internet Logo
57 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
