Question about Mitsubishi WD-62827 62" Television
Whites and Light Blues Very Pixely
I have a two year old WD-62827. I just changed the light source, but all light blues and whites are very pixely. If the screen is still it is clear, but if it is moving it seems weird. Any help is appreciated.
  • 2 more comments
  • Tim114 Nov 07, 2008
    I am watching a 62 HD TV, however it does this on all setting from 1080I all the way down to low def stations. I just changed the light bulb, but that was not the problem. Not sure if my Blues are going or what.
    I bought this in 2006 new. I did buy the 5 year warranty so it is still covered. The DLP light engine, is that something that can be fixed?
  • tiggerb101 Jan 03, 2009
    My TV just started to do this same thing, I can see it more on still screens like the blue background of the DVR screen, but also does this on the DVD that is connected direct to the TV via DVI. so i know its not the signal from the DVR. Have you been able to find out what the problem is?
  • Jesse Teeters May 11, 2010
    This could depend on the source. If you're talking about Cable T.V. then it could be the compression that the cable company is using. However if this happens when you're using a full 1080P source, then *** may be a problem with the T.V. Whatcha Watching?
    Problem Solver:
  • 11 Answers
If it's happening on all of your settings, It's probably going to be a problem with the DLP light engine. That TV came out in 2005, right? Did you buy it brand new, or as a floor model etc.? In any case, it's more than likely out of warranty and going to be a pain in the wallet. Best Advice I can give you with this info is hold out for some price cuts this holiday season. Sorry I couldn't be of help.
Posted on Nov 07, 2008
  • Jesse Teeters Nov 07, 2008
    Fixed? Not sure. I know it can be replaced. If you're still under warranty, call the store where you bought the extended warranty and tell them the issue and that it wasn't like that when you bought it. The DLP engine has a spinning color wheel that breaks up the white light from the lamp...so if anything is off in the calibration any number of things could happen.
    FYI How it works:
    http://www.optomahometheater.com/howto/b...
WD-62827 62 in. HDTV Television: mY LAMP WENT OUT ND NEEDS TO BE REPLACED, IS THIS ...
yeah ive had this tv for 4 years replaced lamp when i got it then about a year ago there was a but power surge that ruined 2 pc monitors and that lamp just google WD-62827 replacement lamp pick a place to buy from the only tool you'll need is a phillips screwdriver
May 17, 2010 | Mitsubishi WD-62827 62" Television
Whites and light blues are really bright and everything else dark?
Try Tv repair World.com for the Coolant replacement kit.If this tv is under 10 years old,if it 10 it end of it life span.
Feb 04, 2010 | Philips 51PW9303 51" Rear Projection...
I have a 110v motor with 2reds 2 whites 2 blues
Study the name plate, there will be a diagram for different speed and voltage configurations.
Sep 26, 2009 | Kitchen Appliances - Others
I have a black and white wire to hook to. leviton has black, blue and white. green also but thats a ground. what do i do with the blue wire? this is a single switch to a gfci then to outside lighting....
The blue wire is the switched hot wire coming from the leviton.
So:
black hot/source to black leviton -- blue leviton to black for light fixture or black "line" on GFI -- all whites connected together.
Charlie
P.S. If the GFI is only powering a light fixture, it is not needed.
Sep 23, 2009 | Leviton 6124H-A 6124H-A Decora LCD Timer...
Green Flashing Light - TV Powers Down (WS 62827)
Initialize the settings by pressing "menu, 2, 4, 7, 0, enter". After settings have been initialized, press the system reset button on the front of the TV.
Aug 08, 2009 | Mitsubishi WD-62827 62" Television
Service man says light engine. how much? jvc model hd52g886
Whites are yellow can be a convergence or color balance problem, and lamp going out could also be a bad ballast board, black spots are usually light engine, could be a different fault on DMD board.
The fact is that when you get all this symptom together unavoidably you have a faulty light engine.
The light engine is the most expensive part to replace, its price for this model is always over $1600 ( I know, keep the heart tablets at hand).
Here is the part for your model: TS-COP7A-SAA-R
Mar 28, 2009 | Toshiba 46HM95 46" HDTV
3 year old Mitsubish 52" DLP mdl.WD-52627 TV displays all "Red" colors as Brown-Grey in color. Going to the color level menu and maxing out the Red color bar does no good. Also intensifying...
Found out I have extended warranty and I am awaiting service company to respond in order to conduct service to find the problem.
Thank You
Jun 30, 2008 | Televison & Video
Mitsubishi WD-62827 Problem
Uh Oh! Unless this is something simple like a loose piece inside the projection chamber shadowing the screen it would have to be the light engine ($$$) warping due to overheating of its plastic housing. Check inside the cabinet for loose objects in front of the lens, then clean all the fan filters, then call your warranty company.
Hope Ya Fix It!
Jan 15, 2008 | Mitsubishi WD-62827 62" Television
Mitsubishi WD-62827 62" Television Logo
144 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
