Question about System Power Supplies
Sony Multiscan 200ES monitor
Accidently plugged the monitor into the serial port. monitor is dead. Help!
Alan L. Caldwell
Major USAF Ret.
    Scholar:
  • 87 Answers
Get a needle nose pliers straighten the pins that are bent. Make sure they are all good and straight. Unplug the monitor and the computer. Plug the video cable from the monitor into the back of the computer. (Make sure its in the correct plug this time)It should be a blue connector if it is a pc (on a mac it will be black) Plug the monitors power connector into the wall or serge protector. Plug the computer into the wall or serge protector. Turn on the monitor. It should precharge and goto sleep. Turn on the computer and the monitor should come out of sleep and be on.
If it doesn't work it could have burnt a component in the video card (if you tried to connect it with a bent pin) or the monitor. It is unlikly that this will happen. If it does I suggest heading to the goodwill to get a second hand monitor or do what davespcr said. They are relitivly cheap these days. You can pick up a CRT (picture tube) monitor from staples,office depot or even walmart for under 100$ if they stock them in your area. Be aware that some states charge a disposal fee for electronics. So be prepared to pay a ew tax.
Posted on Nov 18, 2008
    Novelist:
  • 115 Answers
Dear acaldwell,
Your monitor uses a HD-15 type cable. There should be 3 staggered rows of (5) pins each. (Some cables are missing the 4th pin in the second row, this is normal). If you used enough force, it's
possible that a pin was bent or even broken. I suggest looking at the connector (if not both) and make sure all the pins are intact and perfectly straight! If pins are badly bent or missing you should replace the cable. Next, check to see that all the monitor and power cables are fully seated, and of course, the wall outlet you are using has power. Do you know if your computer has a video card installed? If it does you may be trying the wrong monitor jack. (you'll know if there's a video card because toward the bottom of the computer, in the rear, there will be a 'horizontal' monitor jack as well as the 'vertical' jack near the serial port - make sure you're using the horizontal one if this is the case).
If this has not solved the problem, there's a good chance the monitor is no longer working and should be looked at professionally or replaced. Nowadays you can buy a very nice LCD Flat-Screen monitor for under $150, and you will be able to use it with your 'next' computer as well. Good Luck!
Posted on Nov 14, 2008
Printer adapter from serial 25 to usb printer
Frequently the 25pin plug on a PC is a parallel port, not a serial port. Perhaps it is this you mean.
Nov 23, 2013 | System Power Supplies
Tip
Laptop is plugged in but says it is running on battery.
You have your laptop plugged in but when you check it says that you are running on battery. Or, you have your laptop plugged in and it will not work because the battery is dead.
Both scenarios depict a broken power port on the laptop or possibly a bad power supply. Checking the power supply is easy. Using a DMM on volts DC set to 20 place the red lead on the center pin and the black lead on the outside of the plug assembly. If you do not have the correct voltage as listed on the power supply then you need a new one. While holding the leads on the power plug wiggle the wiring to make sure there are no breaks. If the power drops to zero at any time you need a new power supply. A good site is http://www.impactcomputers.com .
Many times people do not realize that their power port is broken until it is too late. If you continue to use your laptop after the port is broken you will destroy the power supply portion of the mainboard and it will cost you half as much as the laptop cost to repair and may make it not worth fixing.
When you realize that your laptop is not running on AC power, and it could be intermittant, you need to immediately take it to a repair facility to get the jack replaced. The average cost should not exceed $150 US.
This is not a repair procedure that I can walk you through. You can only get your unit repaired at an experienced reapair facility.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
on Nov 13, 2010 | System Power Supplies
My computers USB ports are not giving power to devises like monitor, mouse, and key board. How do I fix this?
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
hope this helps you
Aug 28, 2011 | HP System Power Supplies
Charging Light is on when battery in , and charger plugged in , no reaction when power switch is pressed , fan not spinning ,no power light ,nothing . When battery take out , no charging light when charger...
This sounds like a USB problem. If there is a short or damage within the port the computor will detect it and prevent it from starting. Usually it's a USB port you always use. This may help, Plug in the mains charger and remove all USB devices. This will confirm weather its the computer or a USB cable/device. If the computer still doesn't start, get a bright light and a magnifying glass and look inside all the USB ports on the computer. In the middle of the port there is a flat plastic piece with 4 metal contacts attached to it. Check to see if they are bent, twisted or flattened in any way and with a pin or other suitable pointy device, attempt to straighten any damaged contacts. If you cannot get the contacts aligned, just try to get them away from each other and away from the wall of the port, then insert a piece of card or folded paper above and below the contact strip and tape them down. This will insulate the port and stop a reoccurance of the problem. You should find the computer starts (with a few complaints from windows) normally. this has worked for me 9 times out of 10 for this problem.
Good luck.
Apr 05, 2011 | Compaq System Power Supplies
Have a T5026. There was a problem with the power supply. Had to hold the power button while booting up, lights would flash and machine makes a strange noise. I have replaced the power supply which fixed...
Make sure that you have the monitor plugged into your video card if you have one (usually a horizontal port), and not your motherboard(usually a vertical port).
If it's not a plug issue, then if you press F8 repeatedly while the computer is starting, Windows will give you a boot menu, select the option "Enable VGA Mode" and windows will revert the resolution to a more common one, and will allow you to reset the resolution to one that your video processor can handle.
Mar 03, 2011 | E-Machines Emachine T5026 power supply **...
Computer will not start. No fans, hard drive or monitor motion at all. But, a green light on my motherboard blinks.
Out university has hhad a failure rate on antec 450w psu of 40-50% over 4 years (total number of pc:s with this psu was approx. 300). Check your motherboard with a known-to-be-good power supply.
Feb 17, 2011 | Antec Phantom 500 500W ATX Power Supply...
I have a sony computer need help putting it back together
You are going to have to provide more info. Like model #, serial #, what components you're having problems with. Get together what you can find and repost.
Mar 15, 2010 | System Power Supplies
Computer doesn't switch on!
The troubleshooting techniques you might try is swapping them out with another monitor and keyboard. If they work then you know its the monitor and keyboard if they don't work then the motherboard is bad. The ports for the keyboard and monitor are integrated into the motherboard. So you can't fix the ports, the whole motherboard has to be replaced.
Don't forget to rate this solution with 4 stars before you log out.
Jan 31, 2009 | System Power Supplies
Power Supply
Check all power cables plugged into M/board if these are correct
remove all hard ware
hard drives / cd player and anything else
except for video and memory and test to see if it boots. If it does, one of the removed hardware is faulty if it does not then you have M/board failure
Aug 02, 2008 | E-Machines Emachine T5026 power supply **...
Power issues on new build
Hey mate smart PSU next time just unplug your power cable for about 5 secs plug it back in and try
May 09, 2007 | Atrix PSU 500 BLU PSCI-500BLU RET...
System Power Supplies Logo
278 people viewed this question
Top System Power Supplies Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a System Power Supply Expert? Answer questions, earn points and help others
