Question about Garmin GPSMAP 498
Garmin 498 - trouble finding satellites
Unit turns on fine but very slow to find satellites and the last two trips the unit never located satellites. Have checked cable and antenna.
  • tkohn Nov 26, 2008
    My Garmin 498C works fine for two or three hours and then it cannot locate the satellites. I unscrewed the coax cable and cleaned it and sprayed corrosion X on it to try and remove any corrosion or saltwater buildup on it but this did not alleviate the problem. Coax is not damaged in any way. I am thinking that maybe the antenae in malfunctioning.
  • Anonymous Jan 11, 2009
    takes ages to find satellite!
Push power/menu together or power/page together. the whoole unit will reset. you will lose all saved data but this may help
Posted on Dec 29, 2008
I have a Garmin 52LM. I accidently hit the set location option. Now every trip I try to use, it doesn't start on my current location. HELP
Just let the unit "find" the GPS satellites in view by turning it on and leaving it where it can "see" the sky. It will sort itself out once it starts receiving GPS satellite signals....
Mar 14, 2017 | Garmin n&252;vi 52LM Essential Series 5"...
Greetings . . . I turned my Garmin 2720 on in my
Take the GPS out of your van to an area with a clear view of the sky. Power the unit on. If the unit is working correctly, then it will acquire the satellites. You can then put the unit back in your van. You may have to reposition the unit to keep the satellite lock.
If the unit does not acquire satellites outside, then the unit is defective.
Mar 03, 2017 | Garmin StreetPilot 2720 GPS Receiver
My Garmin GPS 498 stopped locating sattelites. How can I fix it?
Power off the Garmin unit. Press on continuously the upper top left corner of screen and then power on the unit by pressing once on the Power button. You should be prompted to clear all user data, or asked if do you really want to start up in maintenance mode. Press "Yes" to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode. I hope this helps. Good luck
Mar 14, 2011 | Garmin GPSMAP 498
I have a garmin gpsmap 498, 4 yrs old. I have been loosing satellite reception. I have examined the coax cable- I do not see any issues. Where do I look?
Had same problem,,, you need to perform an "Auto-Locate" With unit plugged in but not turned on, push the Page and Power buttoms at the same time,,, continue to hold down the buttons until the "I Agree" message appears. Then release the buttons, agree by pushing Enter. The system will then go through an Auto Locate sequence that corrected my problem.
Sep 10, 2009 | Garmin GPSMAP 498C Sounder GPS Receiver
Battery replacement now ca't find satellite Garmin c320
I had the same issue with the only difference that I haven't replaced the battery yet. When my unit can't locate or acquire satellites I change between GPS and WAAS mode. Within 45 seconds my unit successfully locates satellite. After some time if I disconnect unit I might have to switch it back to GPS and so on, and so on, and so on. It worked for me for past 3 months... Hope it will help you...
Nov 12, 2008 | Garmin Nuvi 360 Bilingual GPS Navigator...
Abnormal Powerdown Error Code
Your battery is dead, which is causing the problem with "slow to receive satellites". Normally when you turn off the unit it will remember the last location and time, then the next time you start the unit it already has the time and current location to acquire satellites, but with a dead battery it has to start from scratch. Check the screen and see if it says "Locating Satellites" or "Acquiring Satellites". Locating satellites will take longer. Replace the battery and your problems should go away.
Jul 22, 2008 | Garmin StreetPilot C330 GPS Receiver
Reset before trip completed
Hmmm, It has a stop navigation button, and it needs time and line of sight to the satellites to figure out where it is....somewhere in that fine manual that came with the device you can expand your knowledge of the fine workings of this nifty piece of electronics!
Jun 10, 2008 | Garmin nuvi 350 GPS Receiver
Trouble acquiring satellites
Garmin nuvi
will not acquire satellites
Apr 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Aquiring satellites
Are you outside with a clear view of the sky? It should find satellites once the unit is turned on. Does it say "Looking for satellites" or "Acquiring satellites"?
If it is "looking for satellites" then it means that the unit have lost all data (time, date, location). If it is "acquiring satellites" then it have date and time, but not location.
Looking for satellites require a longer setup time (could be as much as 15 minutes). Acquiring satellites is much faster (not more than 2 minutes).
Date and time is updated from satellites once the unit gets a satellite lock.
Jan 31, 2008 | Garmin StreetPilot C330 GPS Receiver
Trouble Acquiring Satellites
This can be easily fixed....
I had the same problem, I returned first piece and exchanged for the second. Had the same problem with second and took back to Circuit city. The GPS guys took out 3rd one for me and had same problem. Then the manager came who has been using these for couple of years and tried to set the home location 3 times and it worked 3rd time. He did the same for the second returned piece and it also worked. He says since these pieces are programmed for Kansas we need to give 3-4 tried before the piece first 'locates' satellite and then acquires satellite. After the the piece just turned out to be awesome.
Oct 02, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin GPSMAP 498 Logo
1,319 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
