Question about GE JVM1860 Microwave Oven
Ge jvm1860 microwave oven
My spacemaker micro wave has suddenly started making a crunching noise whenever it is heating up food. No noise if fan on only, and I have tried without the turntable turning. It is 4 yrs old and the fodd heats up as usual. It is just the darn noise its making. Any ideas? thanks
  • Anonymous Nov 27, 2007
    I had the same problem. I took the unit apart and found the "MOTOR STIRRER" was making the noise. There are two similar motors in the unit. One operates the turntable. The other is at the top of the unit and I have no idea what it does. The one at the top is the one I needed to replace. Please note that there are two different motors in the unit with two different part numbers. Make sure to order the correct one
  • GE Master
  • 9,098 Answers
Rotu is right - it certainly could be crud on the waveguide vcover or waveguide. If not, it might very well be be a bad magnetron. My understanding is that GE had a run of bad magnetrons and/or other problems in the high voltage section, but I don't know if they publicly acknowledged it. If it's not a dirty waveguide problem, I would contact GE or an authorized servicer. If you don't have a manual, you can download it here: http://www.geappliances.com/service_and_support/literature/
Posted on Oct 18, 2006
  • 175 Answers
Could the noise you are hearing be maybe an electical sparking/arcing noise? It could be that the wave guide cover inside the micromave cavity is dirty, and needs to be cleaned. If it is not, then it could be a bad magnetron crackling and going bad. If this is the case, it is likely going to damage the waveguide and render the microwave unrepairable. I wouldn't use it until you have it checked out or take it apart and check it out yourself. Hope this helps.
Posted on Oct 17, 2006
4 Suggested Answers
  • 18 Answers
SOURCE: Microwave not heating food and is making loud noise.
You have burned out the magnatron (heating element) which is common on GE microwaves. most service companies will charge about 200-250 to replace it
Posted on Jan 31, 2009
jsrock516
  • 5911 Answers
SOURCE: I have a GE Spacemaker
If everything works, but the microwave oven does not heat, this is commonly caused by a failed magnetron. The magnetron is essentially, the heart of the oven. This is what produces the RF energy that heats your food.
Here's what you need to determine whether or not its worth fixing:
1. You will need to uninstall the oven from over the range in order to replace the part (you will need to do this anyway, if you decide to buy a replacement oven).
2. You will need to ensure the oven is UNPLUGGED before servicing anything inside the cabinet. You will need to remove the exterior case in order to access the magnetron. There are several websites that you can use that illustrate how the oven is assembled:
searspartsdirect.com pcappliancerepair.com appliancepartspros.com
If you've never repaired an appliance on your own before, a microwave oven is usually not a recommended appliance to start with. Some models can be rather involved in taking apart.
3, The magnetron replacement part number for the model you have listed is WB27X10305. The average cost is about $80. NOTE: I found the part listed for the best price at appliancepartspros.com at a cost of $76.
You need to decide whether or not $80 and the amount of labor involved is worth the effort as opposed to replacing the entire oven at a higher cost and less labor (other than the installation). Review the parts illustrations at the recommended websites to see if this is something that you may be able easily take apart and reassemble.
If you have any questions, please post back and let me know. I hope you find this information helpful
CAUTION: DO NOT operate a microwave oven with the exterior cover off. The voltage inside the High Voltage network where the magnetron is installed can exceed 3,000 volts.
Posted on Aug 17, 2010
Testimonial: "Hi jsrock516 - thanks for your expert information. I don't think this is something we can fix on our own and as you said probably cheaper to replace. "
heatman101
  • 43501 Answers
SOURCE: Our GE Profile Spacemaker microwave started making
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
sgfhg
Posted on Sep 30, 2010
GE spacemaker GL1800 runs but does not heat
For that sound it will need atechnician but for not heating you cqn replace fuses
Sep 13, 2014 | GE SpaceMaker Microwave Ovens
My microwave doesnt work
If you hear an unusual buzzing noise, the magnetron (the component that actually generates the microwaves) or other electronic module may be broken. This is not easily fixed; contact a service technician.
Thanks,
micro
pls. rate..
Mar 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Micro wave GE space maker 1800 is heating food well but with noise and turntable not moving,,what could be the problem?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
heatman101
Jan 23, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Why would my microwave no longer heat or cook?
micro waves use a tube inside that generates micro waves and like a light bulb they eventually blow out. the tube is not considered replaceable and cheaper to just get new unit.
Apr 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Sparks and strange noise when microwave is turned on even when empty inside. i have a ge jvm1850smss over the oven microwave.
YOU SHOULD NOT RUN MICRO WITHOUT ANY THING IN IT / THIS WILL OVER LOAD THE MAG TUBE . AND SOME TIMES FRY IT .. The sparking and arcing is probably a bad wave guide . this is sometimes caused by food splater / it gets in the cracks and corners and then cooks till it truns to carbon which conduts the micro's and thus arching .. clean it good and touch up any burns in the metal and repl wave guide cover. mm hope this will help .. mm
Dec 20, 2009 | GE Spacemaker Over-the-Range Microwave
Spacemaker (JVM1871SK) 1800 Microwave doesn't microwave
Remove the case and see if you can localize the smell. Likely suspects are a shorted high voltage diode (replace) or a shorted stirrer bearing (replace stirrer)--a fan-like device located within the sheet metal waveguide near where the microwaves enter the cooking cavity. Make sure to have a cup of cold water in the cooking cavity when looking for problems. The problem could also be the high voltage transformer or the high voltage capacitor, but these are more rare problems. There are no radiation problems with the case off, but there are high voltages associated with the magnetron and it's power supply.
Oct 08, 2009 | GE Profile Spacemaker 1.8 Cu. Ft....
Wont heat food
It could be that the "grinding" noise was actually "arcing" taking place inside the cavity or uder the cover. The magnatron is possibly damaged or the h.v. diode. Should be repaired by qualified repairman
Sep 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800 hum/buzz noise but heating works
the magnetron needs replacement my friend, although you can still heat up food but eventually it will soon fail.
appreciate your kind comment
Apr 12, 2009 | GE XL1800 1100 Watts Microwave Oven
Microwave run with a different noise and stopped heating up food
heatman101
fkj
Mar 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Jan 31, 2009 | GE JVM1860 Microwave Oven
GE JVM1860 Microwave Oven Logo
816 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
