Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer with Curved Shaft #P1500
Poulan 32 cc string trimmer mod.# ppb100
Unit will start and run if the choke is at 1/2 ... the primer bulb is full but has a swirl of air bubble's.. I'm sure it is an air problem but where? .. unit will die if the throttle is squeezed,,, thank's for your time,,, william r2000@aol.com
  • 1 more comment
  • whtyford65 Apr 17, 2009
    unit will only run at idle and smokes.
    mine is the 25cc p 1500
    will die if i use any throtle at all
  • Anonymous Apr 20, 2009
    erratic running then stops
  • Anonymous May 03, 2009
    I have the same issue and discovered that there was a pinhole in the primer bulb. That may very well be the culprit. I'm installing a new one and hope that will do the trick.
    Problem Solver:
  • 5 Answers
Try checking hoses and bubble.mine did that cleaned carb with clener also change air filter mine was clogged ran fine after change air filter
Posted on May 13, 2012
  • 50 Answers
After you have done all the suggestions #1 gave you, make sure the tubings are good. They deteriorate over time. Also be sure to check the spark arrestor. This is part of the muffler. Good luck
Posted on Nov 16, 2008
Try checking the fuel filter, not sure of the exact location but should not be to hard to find. Try looking in the gas tank if it's not readily located. If small 2 cycle engines sit for any length of time ( 30 days or so) with fuel in them the filters can become clogged. If your not going to use it for extended periods or storing it for the winter make sure you drain the fuel tank and run the carburetor dry.
Posted on Nov 14, 2008
Husqvarna 128ld won't start
May have an air leak in the fuel line, primer bubble could be split or the primer bulb base is blocked.
Jun 16, 2012 | Husqvarna 128LD 28cc 2-Stroke Gas-Powered...
I REPLACED THE PRIMER BULB AND NOW THE TRIMMER WILL NOT IDLE UNLESS IT IS AT FULL THROTTLE
Try swapping the hoses at the primer bulb. You may have put the return hose on the purge side of the primer bulb.
Sep 04, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
I bought a Poulan PPB100 at a yard sale for $20.00. I got it home and got it started and running but it leaked gas like no tomorrow. I took it apart to see what was needed and found that all the fuel...
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Please vote on this solution.
Aug 28, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Trying to replace the fuel line and the primer hose both were rotted off not sure what goes where on my poulan pro ppb200 31cc string trimmer there are two lines into the tank the primer wont fill i have...
The smaller line is connected to the fuel filter in the tank and goes on the carb body opposite the end with the hole in the cover. A larger diameter line coming out of the tank is the fuel return line and has the little connector on it just inside the tank to hold it in place there
It goes on the carb body (if primer is on carb) by the bulb.
If there is an external bulb...the small line is the same...there would be a larger line going from the carb body (nearest the end with a hole in the cover) to the smaller nipple on the primer bulb. A third larger diameter line would be connected to the larger nipple on the primer bulb and running to the little nylon connector inside the tank. This is the fuel return line and the smaller diameter line is of course the fuel supply line.
Aug 07, 2010 | Poulan Pro Pp125 25cc Gas Straight Shaft...
Weedeater dies when you open choke
After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
May 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Primer bubble is cracked.minimal fuel is getting to carburator. when it starts it will run a few seconds then cut off.Won't run except in full choke. Please Help
The primer bulb needs to be replaced. It is introducing air to the system and not allow fuel to flow. Replace it and check the fuel lines while you are at it.
HTH
Good Day
Oct 29, 2009 | Craftsman 25cc Gas Line Trimmer
32 cc string trimmer will not run
It sounds like you need to adjust the fuel mixture screw in the carb. To do this, while it is running adjust the screw in either direction until it runs properly without the choke.
Sep 10, 2009 | Craftsman 25cc Gas Line Trimmer
My Poulan Pro weed trimmer SM132 does not run. I replaced the primer bulb and spark plug and it ran fine for 10 minutes. Now it will only start with the choke on and dies immediately. It will not start...
The primer does require two lines attached as it is a Walbro style primer. All four SM132 models uses the WT628 Carb. Since the trimmer ran 10 minutes then you have got all the lines connected right. Mostly you got trash in your carb or it simply needs rebuilding as the diaphragm may have pin hole in it or the check valves are worn out. Depending on the age and use of your unit you may also have a sticking piston ring.
Aug 23, 2009 | Poulan Garden
Poulan Trimmer PPB100 fuel lines
The larger of the fuel lines is the main fuel line. It is the one that has the filter stuck in the end of it and runs out the larger hole in the tank to a fitting on the carb. The smaller line should be about one inch into the tank and comes out the smaller hole and runs to one of the nipples on the primer bulb. Press the primer bulb and put your finger in front of the fittings. The one that you feel air coming out of when you do this is the fitting that runs from the primer bulb to the carb. Hope this helps and good luck.
Jul 15, 2009 | Craftsman 25cc Gas Line Trimmer
Poulan 25cc 2-Cycle Gas Powered String Trimmer with Curved Shaft #P1500 Logo
1,598 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
