Question about Saeco Vienna Espresso Machine
Red warning light does not go off
Been away and when I got back it worked for 2 days then nothing. When you turn it on the green middle button flashes as normal - but then the red warning light comes on. Priming it gets only an ounce of steam and then stops. HELP.
  • 29 Answers
The red warning light is multifunctional. Be sure all your components are in tightly especially the central brew unit.
Posted on Jul 29, 2007
Use the end of a turkey baster to push water through the hole in your water bucket....do this a few times while having the hot water nozzle on. This fixes it for me.
Posted on Jul 26, 2007
SOURCE:
Red light flashing does not turn to green on dolce gusto piccolo
Same thing just happened to my Dolce Gusto Piccolo. It was off for 2-3 weeks, and after turning on, the light just kept blinking red forever. I tried pulling out water reservoir and putting it back repeatedly for a few dozen times (saw somewhere that air should be pumped out of the system), but It didn't help. Then I plugged out the power cord from the wall socket (while the machine was on), and plugged it back after a few seconds. Turned the Piccolo on, and it worked (blinked red shortly and turned green). Maybe it has something to do with induced current. And maybe pulling the water reservoir actually helped :)
Sep 20, 2013 | Krups Dolce Gusto KP 2100 Espresso Machine
Danfoss rx1 thermostat shows 'of' ?
Remove batteries from room stat,turn off the electrical supply to reciever unit.
Turn back on the electric to reciever unit,the red light should be on,press the top "manual" button,the green light should come on and boiler should fire (assuming the programmer is in an "on" period)
Press the bottom button,and keep it pressed,then press the top button until the green light flashes,stand about 6 feet away,and refit the batteries to the stat while observing the reciever unit,either the red or green light (cant remember which) should flash to show the 2 units are syncronised.
Another basic test if all seems ok,when turning the stat up or down,when the green light on the reciever unit comes on or goes off,its usually accompanied by an audible "click" ive found,that if this is not happening, the reciever unit does not switch either on or off,may be intermittant.
Replacement is the only cure.
garden led light
Jun 04, 2012 | Garden
Xbox 360 power button light keeps flashing and disc tray does not open
Hi when the power button flashes red if you hold down the little round white button under the dvd tray and keep holding it down then press the open button for dvd then it will flash a number of lights write this down.
it will be flashing 1 2 3 or 4 lights so write it down then hold down the white button again and press the draw open button again and write down how many again.
do this 4 times all together and tell me what code it has given you then i can tell you exactly what the problem is
so for instance
you hold down the little white wireless button and keep holding it down then press the open button for the dvd tray and say 4 lights are flashin
so write down 4
then hold white button down again and press open button again
it may flash 4 again
then do it again and it may flash 2 lights
then again and it may flash 2 again
when you have gotten these 4 codes post me a message and tell me exactly what they tell you and in the correct order so it may look like this
4 lights flashing
2 lights flashing
1 light flashing
2 lights flashing
if you look at where the button is where you turn it on well you have the green light in the middle well around this is four outer lights that light up red their are 4 of these 2 at the top and 2 at the bottom either side of the green light, their the ones that flash green when its spinning rounf with green lights so write this code down then ill be able to tell you exactly what the fault is ok
let me know then i can assist you further ok
Oct 05, 2010 | Microsoft Xbox 360 Console
Zanussi zwf 1430s,power going to machine but when button pressed green light does not come on just a red light nothing on display panel
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Hope this helped.
May 18, 2010 | Washing Machines
TV won't turn on
you need to replace the lamp in your tv, it is easy and you can do it. Look on the sides of the set for a door labled lamp, with the set unplugged open it up and remove the lamp, if the bulb is out it will have lots of glass in the lens
Jul 15, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
PL-CS55 headset lifts receiver but only get buzzing sound in
Try a system reset:
1. Lift the headset off of the charging cradle (the base).  Make sure the headset is turned off.  The green light on the base won't be on if the headset is turned off. 2. Hold down the call answer button on the headset at the same time as mute button.  The mute button is found on the little black wheel on the top of the headset.  Use the tip of your finger to push it straight in. 3. Hold both buttons until you see a green light on the headset flash.  It will be right below your thumb.  Hold both buttons until the green light flashes for a series of 2 flashes.  Then let go of both buttons. 4. Put the headset back on the charging cradle and wait 30 seconds.  Lift it back off and try again. 5. If this doesn't work repeat the process once more or try a resubscription.
Resubscription procedure:
1. Put the headset back onto the charging cradle.  Make sure the red light on the base is on and the yellow light is flashing. 2. On the back of the base there are two buttons for the microphone adjustment that can be pressed down.  Press both of those down until the red light and yellow light on the front of the base start flashing. 3. While the headset is still on the charging cradle press and hold the mute button until the red light on the base goes solid, and the yellow light stays flashing. 4. Unplug the power to the base and then plug it back in. 5. Wait 20 seconds and try.
Apr 22, 2009 | Plantronics PL-CS55 Wireless Headset
I have a digistat scr with a flashing red light and no heating there is nothing wrong with the batteries, this only occured after a poweer cut.
Try this first before condeming the unit.
1. Turn off the power supply to the Digistat SCR (receiver unit)
and leave for 5 seconds.
2. Turn on power to SCR unit and check red light is on.
3. Press override button No.2 and check the green light comes
on and boiler fires.
4. Press & hold down button No.1 (Keep depressed), then
press No.2 and keep depressed. {The Red LED light will flash
a couple of times and then it will go out}
5. Now release both the buttons – {the two LED lights should
come back on}
6. Get the Digistat+2RF/+3RF unit and stand two metres away
from the SCR unit with the Digistat+2RF/+3RF unit in your hand.
7. Remove the battery cover and fit the batteries.
8. The Red LED light on the SCR will now flash for approx. 7
seconds.
9. This confirms that the radio signal is being sent and
received.
10. The Digistat+2RF/+3RF and the SCR are now successfully
linked by a dedicated RF address.
Mar 21, 2009 | Water Heaters
Power on no picture
Power supply PC board must be rebuilt = replace all bad capacitors.............T.
Aug 19, 2008 | Akai LCT2716 27 in. LCD Television
Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Jul 18, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Saeco Vienna Espresso Machine Logo
762 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
