Question about Citizen Watches
Citizen solar tech 180 watchband pins needed
I need to find watchband pins for the links. I have a couple that are worn out and need to be replaced. I have bought several pins that look the same, however, citizen must use a special size. I need to find a distributor for them.
SOURCE: CITIZEN TITANIUM SOLAR TECH WR200
If you can't see a buckle on the outside, you may have a invisible double lock clasp. Look in the inside of the watch, if there is bar, find the center of the bar and place one thumb on either side of the two links in the center of the bar. Press outward, away from the watch the two links will open an expand to reveal a "butterfly" expansion.
Hope this helps.
Posted on Dec 27, 2007
slp11508
  • 43 Answers
SOURCE: watchband is one segment too long
You need the a watch link remover tool. This can be purchased online or a jeweler can do it for you. I would take the watch to where you purchased it and they should do it for free.
Posted on Jan 05, 2009
escapement
  • 2334 Answers
SOURCE: I need to remove some links from my citizen metal
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 01, 2009
  • 110 Answers
SOURCE: Hi. Just purchased a Citizen Eco-Drive JR3 in
Try placing it in sunlight or daylight for a day and see if that makes a difference. If it is more than a 4 years only the capacitor/battery may be old and needs to be replaced. A low wattage lamp may be slow at recharging the cell.
Posted on Oct 31, 2009
escapement
  • 2334 Answers
SOURCE: Citizen solar watch will not keep time if removed from light
If your watch is light powered, it does not have battery. However, there is a capacitor which needs replacement. New capacitor usually revokes light powered watches and makes them work as new. Rate me,plz.
Posted on Feb 02, 2010
Citizen e810h25691
If the watch is worth spending money on a new band then go to a jewelry store where they repair and sell watches. I got one there.
Sep 08, 2014 | Citizen Watches
How do I add a link to the wristband?
Thank you for contacting FixYa.
  • Turn your watch on its side so the links are vertical. On the inside of the links closest to the clasp you can see arrows, which point in the direction that the pins must be pushed out. Only about four links on either side of the clasp have arrows, because these are the only links with removable pins. On the edge of the links on the opposite end from where the arrow is pointing you will see a small circle where the pin is inserted.
  • 2
    Place the tip of your pointed tool on the small circle mentioned in Step 1. Push downward on the pin in the direction the arrow is pointing. Once the pin starts to come out of the link, use your fingertips or a pair of tweezers to completely remove the pin from the link. You may need to use force, but be careful not to scratch your watchband. Use a pointed tool from a jeweler's or hobby kit or watch pin removal tool.
  • 3
    Slide the links apart where you removed the pin so there is a gap in the watchband. Slide your new link into the gap and fit the neighboring links into the new link so it matches the rest of the watchband.
  • 4
    Insert the new pin into the watchband. You will need to insert two pins, the pin you moved in Step 2 and your new pin, into the two empty pin holes. You need to insert the pin small end first so the larger pin head does not pass through the link. Insert the pin against the direction of the arrow rather than in the direction the arrow is pointing like you did in Step 2. Use your pointed tool and your fingertips to push the pins completely in the links until the pin head is flush with the edge of the link.
  • Best regards. Jewel
    Sep 16, 2010 | Nixon District Watch
    How do i install additional links to this model watch? the company mailed me 2 additional links but no installation instructions Fossil model ES1967
  • Place the tip of your pointed tool on the small circle mentioned in Step 1. Push downward on the pin in the direction the arrow is pointing. Once the pin starts to come out of the link, use your fingertips or a pair of tweezers to completely remove the pin from the link. You may need to use force, but be careful not to scratch your watchband. Use a pointed tool from a jeweler's or hobby kit or watch pin removal tool.
  • Slide the links apart where you removed the pin so there is a gap in the watchband. Slide your new link into the gap and fit the neighboring links into the new link so it matches the rest of the watchband.
  • Insert the new pin into the watchband. You will need to insert two pins, the pin you removed in Step 2 and your new pin, into the two empty pin holes. You need to insert the pin small end first so the larger pin head does not pass through the link. Insert the pin against the direction of the arrow rather than in the direction the arrow is pointing like you did in Step 2. Use your pointed tool and your fingertips to push the pins completely in the links until the pin head is flush with the edge of the link.
  • Aug 18, 2010 | Watches
    How do I remove a link to make watchband smaller.
    I just got a Citizen Eco-drive watch similar to this one (mine is titanium) for Christmas and took it into the jewelry store today to have it resized. Unfortunately, things didn't go well and it is now on it's way to another jewelers shop for repair. The pins have a short sleeve on them that is supposed to remain inside the links. However when they removed the links, the sleeves came out and they couldn't put them back in. Without the links, the pins do not remain secure in the links. I recommend you take you watch to a jeweler to have it adjusted professionally.
    Dec 26, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
    Pin on the watchband is protruding
    No need to buy a new watchband friend, you need a new pin. The spring inside the pin has lost its elasticity ... you won't spend a fortune ....
    Please rate the resolution.
    Mar 18, 2009 | Casio Pathfinder PAG60-1AV Watch
    Take link ot of watchband
    take it to a jeweler because if you do it your self your warranty is no longer valid
    Jan 06, 2009 | Citizen Aqualand Duplex JP104009E Wrist...
    Watchband is one segment too long
    Jan 02, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
    Hope this helps.
    Dec 26, 2007 | Citizen Eco-Drive BL006056H Wrist Watch
    Instruction manual
    Go to this link and follow instructions for finding your particular watch movement and then lookup instructions.
    http://www.citizenwatch.com/COA/English/settings.asp
    Dec 05, 2007 | Citizen Aqualand Duplex JP104009E Wrist...
    Watches Logo
    150 people viewed this question
    Top Citizen Watches Experts
    Jimmy Accardi
    Ansel Alberto
    Ansel Alberto
    Are you a Citizen Watch Expert? Answer questions, earn points and help others
