Marshall valvestate 40 guitar combo, clean channel works fine, dirty channel has no o/p have changed valve ecc83, channel indicator led comes on and valve lights up but still no o/p. Can you help please Andy
  • 1,512 Answers
Hi Andy
The problem you face is most probably the same that stops most all valve state amps from working. They suffer terribly from fry/cracked solder joints. You will have to remove the main circuit board from the chassis, and resolder any suspect joints you can see, particularly about the rear loop in out jacks, control pots on the front panel, and power supply. There is a large power resistor and zener diode that cause problems in this model from memory. The valve never fails in these amps. Due to the lower supply voltages they are run at, they are not under alot of pressure, and as such give good reliable service. Go over the amp for dry joints first, and see how you get on. I have repaired so many of these with that problem.
Posted on Nov 08, 2008
Marshall troubleshoot
First check the preamp valve in that curcuit
Feb 26, 2014 | Marshall Amplification Music
I have distortion on my clean channel I have changed the speaker but still same problem
Look at your indicator LED... is it off for the clean? Does it show yellow for drive and red for more?
Depending on if this LED is showing these correctely tells me where to look for problem. If the LED shows these correctely, then problem is with the relays that do the switching or a few transistors that change the gains for the drive and more functions.
May 04, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Hey, the clean channel on my Marshall 250dfx Combo amp isnt working the distortion and everything is working as normal, but the clean channel makes no sound at all, i was wondering if you can help?
The switching is done electronically by an analog gate chip. On IC9, check if the signal on pin 8 changes with switching between clean and OD... This is the actual signal that changes the gate. If you don't see a change there of say 5 volts, then the problem is in the circuits that drive this gate. If the signal is there, then the problem is in the clean channel audio op amps or the components around them. Let me know the results of the test.
Oct 18, 2010 | Marshall Amplification Marshall MG250DFX...
What is the position of each valve on the Marshall JVM410C chassis? I assume the one with the screen can is V1 but does it run from right to left from there for V2, V3 etc?
It doesn't matter. It takes 5 ECC83 tubes which have a smaller tube socket than the output tubes. The output tubes are 4 of EL34. If this helps please rate me.
Feb 23, 2010 | Marshall JVM410C 100 Watts Valve Guitar...
My problem is that the clean channel doesn't work. The OD1/OD2 channel works just fine but I'm not getting any sound out of the clean channel... any ideas?
Here is the schematic: There are a few possibilities.The jack for the footswitch for channel changing JS1 might be faulty. Zener diodes 1 and/or 2 might be faulty. Switch 2 may be defective. TR1 might be defective. IC 4 or 5 might be defective.Start with the channel switching circuitry testing in the order I gave you. Check the actual clean channel circuitry to see if you actually have a clean channel anymore. Before you do any of this make sure you know enough about troubleshooting and have at least a good VOM and are familiar with safety procedures. The filter capacitors in this amp store enough charge to kill you. A cheat to partially discharge them without damaging the amp is to unplug it from the wall while it is hooked up to the speaker cab you are using while it is on at a very low volume with a guitar cord plugged in. Make sure you use exact replacement parts if you tackle this. They don't have to be from Marshall, they just have to be exact electronic equivalents from a quality manufacturer installed correctly. I would recommend that if you have no experience or are at all unsure of the repair to take it to a Marshall dealer to have it done. Please rate me if this helps.
Nov 29, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Hi, I have a Marshall 8240. The Reverb output
probably the reverb tank These coils are very thin and tent to break easily
Nov 05, 2009 | Marshall Amplification Marshall MG250DFX...
Marshall 8080 valvestate amplifier
There could be a short in the rectifier diodes or in the transformer itself. Can you take some measurements inside the unit?
Let me know.
May 29, 2008 | Audio Players & Recorders
Marshall valvestate 8040 - how to change the valve?
Hi chagzuki, you are right, but only when the valves are used as outputs, You amp has transistorised outputs, and a single tube used for distortion/gain. You will get a very long life out of this tube also because its supply voltage that is is used in the valvestate preamps is really quite low. Just enough for it to work really, so the tubes life can be expected to be much longer than normal. It is also a preamp tube, not an output tube, so they rarely need changing. If you ever did want to change it(dont bother), it is located on the PCB inside the unit. You have to slide the sleeve off to get at it. Get yourself a JCM800=the best guitar amp ever built(imho), then yo got pure Marshall tone, and output tubes that need changing every 6 months or so. Now go RIFF OUT and dont worry about your valvestates' "valve"
Mar 22, 2008 | Audio Players & Recorders
479 people viewed this question
