Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Faint blue "cloud" on upper left screen duriing viewing
I have a Sony KF50WE610 for the past 4 years. Great TV, but just very lately there is a faint blue "cloud" at the upper left of the screen that seems to come and go during viewing that is more noticable when only faces are on the screen. When the set is off, the blue cloud seems to stay in the same position, almost like one of the lights inside is still on. I had a projection bulb replaced shortly after the initial purchase in 2004 and other than that, no problems. I am connected to cable, no satellite.
    Novelist:
  • 135 Answers
MisterSony is 100% right. Many early model Sony LCD projection sets suffer from UV deterioration of the color filters within the optical block. The xenon mercury vapor light gives off UV light which is supposed to be filtered inside the optical block, result, similar damage like that of sunlight on plastic. Some models exhibit blue discoloration or stars and others a yellowish green cast. The TV has to be completely gutted on XBR's to replace the optical block, anywhere from a 1 to 2 hour repair depending on the model. Another secondary issue is dust accumulation from drawing in dusty air, reducing the airflow and allowing the lamp and optics to heat up. Many of the sets have 4 fans, 3 of which cool the lamp and optics. Cleaning the lamp fans would likely require a trained Sony tech since some of the TV would have to be disassembled.
As for the warranty, most of the Sony extended warranties for the optical block issues have expired by now (11/2008). You can visit the Sony website, go to support and type in your model number too see what issues they are still supporting on your set. It's likely you will have to climb the customer service ladder to overcome the expiration. I can't say that owners who registered their warranty with Sony got notified of the optical issue. I assume Sony took into consideration how many units went out before they modified the optical block and how long it took for the problem to appear which is probably how they set the extended warranty time frame. If they won't accomodate your problem, you can always offer to split the cost of the repair, but beware the optical block could cost in the neighborhood of $1000 and about $450 for labor. This and other known concerns is why I will NEVER buy a projection TV again. I advise everyone to buy either LCD or (gulp) plasma.
One other tip. If your TV fails to come on, check the bulb (user replaceable) first before calling for service. Often times the lamp light won't indicate a failure, but the set will blink the red power light. The lamp capsule inside the reflector may shatter evidenced by a "pop" as you turn the set on. Other times the set may turn off unexpectedly and turn back on within 2 minutes and repeat this cycle as the lamp near the end of it's life. It could also show sings of picture darkening before it goes. If the lamp is two years or older, consider getting a spare so you don't have to go without when the lamp goes. Don't touch the lamp glass, ever!
Posted on Nov 09, 2008
  • 320 Answers
I hesitate to tell you this for fear of a bad rating from you, but it is likely the optical block is the source of your problem. Sony was covering replacement of the optical block for this unit until June of 2008, but that warranty extension has expired. I would suggest you contact Sony customer support at 800-222-SONY to see if they will allow for some type of accommodation to cover either the parts, the labor or some portion thereof. Sorry!
Posted on Nov 07, 2008
One yellow, one pink, and one blue spots appeared on my tv screen.
The set if projection which model here is, has arced and now each of the three picture tubes used has a tiny permanent burn mark on its screen.
That is what you are seeing, the set uses three picture tubes with screens like the old tv sets===the coating has been burnt in each, want to prove it, remove rear cover and cover any one of the three lens and that mark on one tube will go a way.
Not fixable.
Dec 23, 2012 | Mitsubishi WS-55315 55" Rear Projection...
Sony 60" HDTV Plasma WEGA....Picture Problem
My guess is that you're not missing the color it just appears muted... That problem is a common one in both the 50 and 60 inch models. And if you change video mode with nothing hooked up you'll see a faint color where none should be...
That's simply dust in the optical block on one of either the red, blue or green lcd panel. Wipe it down with a non-linting cloth and a "light" amount of windex and you're back in business...
But check it out by switchin through the video modes with nothing hooked up.. The faint color you see if the lcd panel that's having the most problem and the one that's muting your green.
Bill
Nov 10, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Little blue dots on screen and large blue haze in upper left corn
Sounds like the light engine is going bad...that's why they stopped making these rear projection sets using LCD's. Costs almost as much as a new set! But get a second opinion before trashing it.
Apr 15, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Faint lines show up when i get dark screens in movies
First check what color of faint lines comes then reduce Screen Volts in TV of that CRT (tube)
Take off lower front cover, speaker grille of TV, there you will see focus control block that has 6 control knobs, upper 3 knobs are focus adjustment of red-green-blue CRTs and lower 3 knobs are screen volt controls for red-green-blue CRTs. Turn screen volt control knob CCW to reduce screen volts of desired CRT.
Put TV on any free AV input so screen will be dark enough to adjust screen volts.
Thanks.
Aug 28, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony KF50WE610 Won't power on Red light flashes
I had this same issue with a 46" Sony. I replaced the bulb, and it is as good as new. I hope this helps.
Jan 27, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Faint red lines in a curved arch like pattern
Is there a cheaper solution? $600 sounds like you just throw it away to me...
Aug 02, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
On screen yellow tint
yes, is the optics unit block, the blue lens have a cloud in the lens
Jul 04, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony KF50we610 blue dots and blue cloud
Check the optical block repair at sony's warranty website...
Could be the problem they have been covering it under a recall of sorts. $1250 for the optical block and they are only doing it until the end of the year so don't waste any time
May 03, 2007 | Sony XL-2100U Projector Lamp for...
Guys I did this myself real easy. Just don't turn the corresponding screw too far. Only need to adjust it until the lines go away. Do it on a darker screen so the lines are more visible. I did the red 2 years ago and the green 6months before that. The blue lines are coming on my screen now and I've fixed it in 10 minutes. The TV is amazing.
Apr 10, 2007 | Sony KP-51WS500 51" Rear Projection...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
505 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
