Question about Sony CPJ A300 Multimedia Projector
Image The blue image comes on when I turn on my projector,it stays on for about fifteen seconds the screen flashes then the projector shuts off. I've replaced the bulb and the problem still persist's.
  • 520 Answers
SOURCE: Image Problem
either dust build up beyond lamp or discolouration due to condensation on inside of lens.take lamp out blow inside or use hairdryer ,replace lamp.
Posted on Feb 23, 2008
  • 5 Answers
SOURCE: Sony VPL-CX6 Projector turns itself off. No image projected.
does the "lamp/cover"-led light up? i had the same thing happening, the lamp either broke or is about to break and the projektor won't turn it on again to protect itself. if its very urgent, open the projector pull the lamp out and put it in again, it might work for 1 or 2 more times, but it is very likely to explode (usually not breaking the projector but for sure not good for it).
good luck!
Posted on Aug 04, 2009
  • 231 Answers
SOURCE: The Projectors can nos display de image completely
change the display resolution
Posted on Apr 13, 2010
  • 172 Answers
SOURCE: my projector has a green and blue color at the margins ...
It is for dust.It need full servicing
Posted on Aug 13, 2010
  • 23 Answers
SOURCE: I have changed the bulb
Is the buld u changed right and in working condition.please clean the optic lens and image CRT board which ( Scanner image board) to see if the issue remaisn or nott
Posted on Sep 28, 2010
  • 699 Answers
SOURCE: I have a SONY VPH-D50 projector. Screen has green
You will probably need a new lamp.
Please dont forget to vote if you liked my answer
Posted on Feb 09, 2011
0 characters
1 Points
Projector image switches off when image gets super bright
Hi , what type of cable are you using for the video input source ? HDMI or RCA ? it very much sounds like a faulty cable or lose connection , would try that avenue first before anything else,
Mar 20, 2014 | Multimedia Projectors
Beamerproblem! I've got a red-color problem with
Take it to GameStop. They can find the problem lickety-split!
May 17, 2013 | Multimedia Projectors
Eiki LC-XC1 color problems
check all the optical parts around the blue lcd-panel, they might be darkened due to heat
May 07, 2012 | Eiki Multimedia Projectors
InFocus Projector-Searching
most likely it is your cable. If a for sure brand new cable doesn't fix it it is most likely the main board. Also try flashing the software again.
Apr 28, 2010 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
PT-L735 U projectors. Green screen and stretched
The green is the result of the blue device failing. Happens about 4000 hours or so. LCDs can't handle the heat. Check the scaling of the image of the second projector. 16x9 vs 4x3.
good luck
Jun 25, 2009 | Panasonic PT L735U Multimedia Projector
Need image to show on both the HP laptop and the InFocus IN15
make sure the laptop is plugged in and not on battery. also make sure the dmi-vga cable is not too long. the signal isn't strong enough to get to both screens.
Jun 04, 2009 | InFocus LP70+ Multimedia Projector
Sony CPJ A300 Multimedia Projector Logo
16 people viewed this question
Top Sony Multimedia Projectors Experts
Jaime Hernandez
Are you a Sony Multimedia Projector Expert? Answer questions, earn points and help others
