Question about Sharp R-1505 Microwave Oven
Sharp 1505 over counter microwave
Every thing is powered up but turntable won't work. keep seeing advice to change micro switch but not on parts list. can part be called something else. thanks Cleveland3141
  • Sharp Master
  • 9,098 Answers
It's almost certainly not a switch issue. If the primary interlock (lower door switch) were bad, the turntable and cooling fan would not come on and it would not heat.
If it heats, but the turntable won't work, the motor is likely bad.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
We have the complete service manual for this model and have uploaded it to our site here to help you.
You will need the free Acrobat Reader to view or print it in case you don't have it already.
Posted on Nov 08, 2008
Why would the turntable stop turning and the unit stop heating?
hi,
there is a micro switch that signals when the door is closed. this tells the machine that it's okay to start the turntable and heating process.. if the micro switch breaks or shorts out then the switch does not send the signal so the machine does not work.
hank
Sep 06, 2014 | Sharp R-1505 Microwave Oven
Sharp R-930CS microwave turntable stopped turning and neither convection or microwave are working (ie. not heating). Lights and fan turn on and counter counts down normally.
Look inside for one of many thermal cutouts (button type) test each for continuity (with the unit unplugged of course). Also look for burned wires and repair or replace them. If you get it running and it works fine... we're done. If it still acts up then replace the magnetron and or the capacitor.
Oct 19, 2013 | Sharp Microwave Ovens
Sharp Convection Microwave won't heat and turntable won't turn.
I typically find it is not door hinge issues but door switch issues, especially with sharp. You may heve a little movenent in the door hinge and that is allowing the door hook to move up and down on the plunger for a door switch that is probably a bit melted due to bad connections. If you check the door switches and look for any browning around the terminals where the wires push onto the switch you will probably find an overheated connectoion. Replace the bad switch and run better wires and better termninals to the new switch and it will probably be fine.
Oct 09, 2017 | Sharp R-930AK Convection/Microwave Oven
Our sharp r520lw just quit working, timer works, light works, all buttons work, (clear, etc) however turntable doesn't work and no
That would be a bad bottom door switch or its mount.
See the help file on door switches here.
See the service manual here.
Dec 13, 2011 | Sharp R-520LW Microwave Oven
My over the stove Sharp Carousel Model # R-1505F turn table stopped turning. What part do I need to replace. Also, I broke the glass turn table plate. What size is that and where can I order another...
Sears Parts Direct has the parts diagrams and many parts for the R-1505 microwave. The glass plate is part 4-3 ($33.99) on this page: http://www.searspartsdirect.com/partsdirect/part-model/Sharp-Parts/Microwave-Parts/Model-R1505/0958/0123370/50019999/00001?blt=06&prst=&shdMod= .
Without more tests, I can't be completely positive but the turntable motor is the likely problem. That is part 1-4 on the list above. However, it could be a wiring problem with the wiring to the turntable motor.
Partstore.com has many of the parts as well: http://www.partstore.com/Model/Sharp/Sharp/R1505.aspx .
I hope this helps.
Jul 29, 2011 | Sharp R-1505 Microwave Oven
Sharp r-1505 microwave. several segments in digital display do not illuminate.
Sharp had "issues" with that board (connector cable fail). That was back in 2002. Give them a call and see if they will send you a new control board (part # CPWBF070MRU0) All of the 0's are zeros.
If not, look at that ribbon connector where it's kinked, and you'll see a spot that should be repaired, ie broken wire.
Good luck with the phone call. Refer them to bulletin # MW-166.
fil
Mar 01, 2011 | Sharp R-1505 Microwave Oven
We have a sharp r-9h84b convection microwave and the carosel has stopped working when the tray is in place. Any thoughts the carrosel seems to rotate very slowly when there is nothing on it.
It's almost certainly a bad turntable motor.
The part number was RMOTDA079WRE0 but it is listed as no longer available.
In some cases, older microwaves are available locally at repair shops or on Craig's List.
If you want to keep your eyes open, this same motor was used in the following Sharp models:
R9A20
R9A50
R9H11
R9H60
R9H66
R9H71
R9H73
R9H76
R9H80
R9H81
R9H81B
R9H83
R9H84
R9H84B
R9H91
R9H91B
R9H93
R9H94
R9H94B
Good luck.
May 23, 2010 | Sharp R-9H84B Microwave Oven
Turntable stop working along with microwave and convection oven
would be a door micro-swtch sharp part # Sharp Part Number: QSW-MA085WRE0
Jan 07, 2009 | Sharp R-1405 / R-140 Microwave Oven
Sharp R-1505 microwave
The power fuse open , if open replace it don't make jumper it b
cause fire .
the power transformer builtin fuse open/
The door micro switch open /need to replace.
Jan 03, 2008 | Sharp R-1505 Microwave Oven
Microwave Ovens Logo
119 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
