Question about Canon PIXMA iP1800 InkJet Photo Printer
Pixma iP1800 ink absorber almost full error msg.
Any quick fix? Any reset codes, etc.?
  • vincedevlin Nov 07, 2008
    Any quick fixes, reset codes, etc. for "ink absorber almost full" error msg.?
I have use canon pixmaip1300.
But recently the printer does not print.
Becous error5100
Posted on Mar 09, 2009
Why is my canon ip1800 printer still not printing after cleaning the ink absorber, I still get the message ink absorber is full
Shelly, Did you reset printer after cleaning absorber.
Press and hold the "Power" button and reconnect the power cord. When the printer comes on, release the button. Wait five seconds and push the "Power" button again. This resets the printer's internal memory and overrides the "ink absorber full" error code.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
The ink absorber is full Canon Pixma IP1980 IP1880
How to Clean Canon Ink Absorber
iP1800 ink absorber
Apr 07, 2016 | Canon Office Equipment & Supplies
How could i fix my cannon ip1800 encounter this problem,ink absorber almost full?
This is a job for a canon repairer. the ink absorbers are in the bottom of the printer and the whole print engine needs to be removed in order for them to be changed. its a huge job. (and very messy too). After that the software needs to be reset to remove the message.
Jul 04, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Ink absorber if full, contact service provider? is there any other remedy?
There are two remedies for an error ink absorber full. First, is the ink absorber pads is actually full of waste ink and needs cleaning. The second is to reset the printer to clear the error and let the printer print again.
Clean the two absorber pads
. Its is actually two absorber pads located on the right side of the printer, under the ink cartridges when it is in home base position.
How to access the pads and remove it for cleaning?
Turn on the printer. Lift the top cover to expose the ink cartridges. As soon as you lift up the cover the cartridge carrier will move away from its home base.. Then the pads will be exposed. It will be a dirty job so be prepared with your tweezer and extra cloth for some ink spill. Using the tweezer, lift up the pads sitting on a rubber retainer. The pads can be easily clean by placing it under a running water. Warm water will be nice to remove the ink from the pads. After this, you can now return the pads. However, the problem will not be solve especially if you are currently facing the waste ink absorber full error.
Reset the Printer using an iP Tool
iP Tools are utilities designed to clear errors that will appear in an iP1800 printer. Download this iP Tool here.
while the printer is on Run this software
1. Click Reset Main to reset the waste ink counter and
2.
Click Reset Platen button
If errors still persist.
Press and Hold down Reset button and wait until the printer restart.
Release the Reset button and wait until it fully initialize.
Happy printing.
Please comeback and rate this answer.
Thank you for using Fixya.
Aug 18, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
My Canon iP1800 ink absorber is full.
The following reset method has tested and work perfectly to reset waste ink counter. Step 1: Reset hardware
  1. Press Resume button hold for 1 – 2 minutes
  2. Open the cover
  3. Release the catridge and then put catridge again
  4. Close The Cover
  5. Turn Off
  6. then Turn On again
May 28, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Can I fix my full ink absorber myself? Canon iP1800
Only service centre can help you to replace the ABSORBER KIT.
May 25, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
I have a Canon ip1800, which keeps coming up with the message," ink absorber is full" Please advice how to sort this problem. Thank you
The printer counts the number of prints and cleaning cycles and when you get that error you need a shop to replace the ink absorber pads and reset the counter so the error goes away. If you bypass the error, the ink will fill up and leak out or ruin the printer sensors. The absorbers cover the entire bottom of the printer and require complete disassembly to remove.
Jan 18, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
PIXMA IP1800 INK ASBORBER IS ALMOST FULL . WHAT DO I DO TO SAVE THE PRINTER.
When the ink absorber gets full you need to take the printer to the shop. The printer has to be completely taken apart to replace the absorber which covers the whole bottom of the machine. After that you need to get to the diagnostic mode which only Canon techs can do, and reset the absorber counts. In my shop the repair runs around $80.00
Jul 02, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
The ink absorber is full... for the canon PIXMA iP1800
My printer is not printing for feed paper. It tells me that it has a paper jam, but there is no paper in the printer. Please advise
Dec 05, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
How to reset canon ip1800
ink absorber is full contact service" ???????????//
Oct 03, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
321 people viewed this question
old marine
old marine
