Question about GE Refrigerators
GE Fridge not cooling
I have a GE GSS22QFMBCC refridgerator, that does not appear to be cooling properly. I can hear it running, but, both freezer and fridger are warm.
    Problem Solver:
  • 9 Answers
If there is frost at the back of the freezer compartment then the refrigerator may be frost blocked or the defroster heaters may have failed. Turn the freezer control to number zero (off). Leave the freezer door open so that the blower will run. Leave this way for several hours until all signs of frost on the back are gone and ther is no water dripping from behind the back panel. Now try to run the refrigerator normally on settings of 5 or 6. If the freezer cools normally then the problem may be solved. If the frost builds up again over several days then the defroster heaters will probably need to be replaced.
Posted on Aug 23, 2010
    Genius:
  • 1,122 Answers
Is the freezer fan running?is there any frost in the freezer?can you pull the frig. out and see how hot it is?is the comp. fan running?is the comp. clicking on and off,let me know what you find-mike
Posted on Nov 07, 2008
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Ge tfx25jrbb-ww refridgerator not cooling
The first thing to check is if you can hear the fan running inside the freezer. This not only keeps the whole freezer cold it alspo circulates air down to the refrigerator keeping it cool as well.
May 28, 2012 | GE Refrigerators
I have a ge refridgerator gss25k side by side. thefridge/freezer are not cooling. the bottom of the fridge freezes and the top is warm.
There is an air duct that connects the fridge to the freezer. A fan circulates air to cool the refrigerator.
The inside fan has stopped working or is blocked by ice.
Defrost the freezer. If the fridge starts to work properly then you have an auto defrost problem. If the fridge still does not work then there is a faulty fan.
A technician can help you there
Apr 03, 2011 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
I have an older side by side GE refridgerator model number TFXC222J. The freezer section is working but the fridge side is not cooling. light works.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | GE Refrigerators
The refridgerator is not cooling - coils are not iced over. what should I try now? Both sides not working properly. This is a side by side model.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
tut
Aug 01, 2010 | GE GSH25JFR Side by Side Refrigerator
The refrigerator and freezer are not getting cold but I can hear the motor running.
Hello there:
If the compressor is running and you can hear it than you are going to have the refrigerant recharged in the unit.
If you continue to run the unit without refrigerant you will end up with the compressor quitting and this you do not want ok?
I hope this has been very helpful for you ok?
best regards michael
Nov 05, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Refrigerator not cooling, freezer is working.
heatman101
fdite
Oct 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE regrigerator not cooling or freezing
first defrost it by turning it off for 1\2 to 1 full day,put towels on the floor to catch the water,when a refridgerator gets frosted up it cant circulate the cold air,and if its one with the freezer on top then the cold air cant blow down into the refridgerator,check inside the refridgerator at the top where the thermostat cover is there will be a vent hole,it could have ice built up so much that its totally blocking the air flow.This usually happens when hot food is put in the refridgerator and causes steam,or the refridgerator runs too much caused by bad door seals,or the cooling fins on the back or bottom underneath plugged with dust and the freon gets too hot causing condensation inside the freezer which causes it to frost up,a plugged drain hole will back up water and freeze,the fan in the freezer may have stopped working,which is about a $60.00 part,and finally a bad defrost element (about a $40.00 part)which is a glass tube inside the freezer with a coiled up wire inside it that heats up at certain times to defrost any ice build up,(which is the last thing to check)
May 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My Whirlpool ARC7472 fridge freezer has stopped cooling both feezer and fridge. Removal of the cover in the freezer shows no ice build up, the fan runs, but no cooling effect in the chiller pipework to the...
it is low on refrigerant and has a sealed system leak without the proper leak detection equiptment and charging tools best left to the local ref tech
Apr 28, 2008 | Refrigerators
Refrigerators Logo
204 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
