Question about Acer Aspire 9500 Notebook
S video output
Can anyone guide me on how to set up my computer to dispay on a tv through the s video output?
    President:
  • Acer Master
  • 1,314 Answers
1. Connect the S Video cable from the out on your laptop to the in on your tv.
2. Press the key combination on your laptop that switches the output from the screen to the external device. This varies per laptop but there should be a picture of a screen in blue above one of the number keys. You press the function (FN) key on your laptop and that button with the screen on it (usually 5) and that will redirect the output. Make sure your tv is set on the input of the s video so you can see it.
Thanks and please take a moment to rate as fixya.
Posted on Nov 07, 2008
No video signal vga laptop to tv
Make sure you have the TV's input set to PC or Computer to receive the signal from the VGA.
Make sure the connections are snug on the computer and on the tv.
Reboot the computer and see if it automatically starts the display on the tv. If not, there are a sequence of keys that you can press to toggle the display between the tv and the computer.
Normally to toggle the display you will have to Press and Hold the FN function key located at the bottom left portion of your keyboard and then hit the corresponding key (F1 thru F12) that toggles the display. The correct F1 thru F12 key to hit will have the CRT/LCD on it or it might have the icon of a display.
Apr 22, 2012 | Toshiba Computers & Internet
Tip
How to burn protected iTunes stuff to DVD?
Many users want to burn DRM protected iTunes videos/movies/TV shows to DVD playable on home DVD player and enjoy on the widescreen TV. I know you can enjoy iTunes movie on TV with Apple TV, but why do you have to spend more $299 if you can do that with some easy software. What you need to do are just two steps:
1. Remove DRM protect from purchased iTunes video/movie/TV show to unprotected video.
2. Burn the non-protected video to DVD.
This step by step iTunes to DVD guide will teach you how to burn iTunes video to DVD, let’s start it.
Step 1 of iTunes to DVD guide: Remove DRM protect from purchased iTunes video/movie/TV show
Step1. Download iTunes DRM Remover, then install this DRM removal software, click button “Add” to input DRM protected movie or music, you can also directly drag-drop them into the main processing window.
Step2 Set the output settings
Choose your file and set the output settings in the "Convert video to" area:
Step3. Begin to convert DRM
After finishing all the necessary settings and editing, click the "Start" button to start converting, That's all.
Step 2 of iTunes to DVD guide: Burn the non-protected video to DVD
Please download and install the Cucusoft Video to DVD Burner at first.
Launch Cucusoft AVI to DVD/VCD/SVCD Converter pro, you will see the right UI.
1. Select radio button "To DVD"
2.choose the "merge" or "batch" tab.
3.Click "Open" button to open your movie file(s)
4. (optional) Set your preference. Region "4" in red frames can set the output MPEG properties.
5. (Optional) Set the advanced settings as following.
6. Click "Convert" button to start the conversion task
7. After you click "Convert" button, the following dialog will pop up automatically.>
8. After video conversion done, the "CD/DVD Burning engine" will be launched automatically. Please choose the DVD burner.
9. Please place a DVD-/+R/RW disc into your DVD burner. If it is a rewritable disc, the program will erase the disc before burning DVD disc.
10. When burning DVD is done, the DVD disc will be eject automatically. You can also find the output file at the output folder.
Done!
Source from:
http://www.dvdtoitunes.net/itunes-to-dvd.html
iphonebooy,know nothing but news about Apple's.
Just jailbreak ipad,ipad transfer,
mac video converter ipod transfer.
on May 24, 2010 | Computers & Internet
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
Can anyone let me know how to stream video from laptop to tv. wirless
Streaming video from your computer to your TV depends entirely on what kind of setup you already have. Many standard laptops come with output jacks like s-video, which hook directly into a TV. For fancier setups, you can buy a graphics card which includes video output.
Nov 13, 2009 | Computers & Internet
Sound card, multimedia card, tv tuner card.
sound cards are card fitted in pc to get sound when soundc slot of motherboard is malfunctioning or driver is not available,multimedia cards are cards for storage connected through USB and display cards are used when video slot of pc is malfunctioning or there is no driver.higher memory display cards are known as graphic cards.
Sep 28, 2008 | Compaq Audio card Sound Card
No video - blue screen...
since you bought this console used, it maybe set to HDMI 1080p/ 1080i/720p output(by the original owner) and if your TV does not support this there will be no picture, the only way to lower the output resoloution is to get into the options menu but to do that you will need a freind with a tv that supports whatever resoloution its been set too.
Mar 13, 2008 | Sony Playstation 3 (PS3) Console
Connecting PC to sony SXRD with RGB cable no display?
How are you connecting the PC to the TV (ie which input and what type of cable are you using?)
Aug 12, 2007 | Sony KDS-R50XBR1 50" HDTV
Acer Aspire 9500 Notebook Logo
93 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
