Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Bottom drawer cant get drawer out to get screws out from side walls
Look on the bottom side below the front. You will find two clips that can be pushed in to remove the drawer.
Posted on Nov 08, 2008
How do i get to the fridge fan in model lfx31945st its an LG. I have the fan to replace
You must remove all shelf's, bins and drawers. Next remove the guide on the lft side for the lowest deli drawer (The long one at the bottom).
The metal guide in the middle of the back wall is where the screws are to hold the whole back wall in place and the top one has a small plastic cap. Remove the cap and the 2 or 3 screws in the center track. Set the track off to the side.
The whole back wall comes out starting from the top. Sometimes you have to slightly bend it in the middle to get it started.
Be advised!!! These have a service flash on them regarding an incomplete defrost and typically are solid ice behind the back wall!! Do not force as you can damage the evaporator.
If there is solid ice then the main board will probably be needed along with what they call the "controller" to shift the defrost points a little. I have yet to see one of these fans go bad since they are dc low voltage motors.
Feb 09, 2018 | Refrigerators
Ice maker is just pouring out water, not making ice cubes. Do I need a new ice maker? It is inside the bottom drawer freezer.
Hello;
My name is Peter. I am a retired field service refrigeration technician.
This is a open question. You did not provide a model number. Your model number is located in your fresh food section on the side wall near the top.
I am going to assume the water in the ice bucket is frozen. If this is the case then you have a leak in you icemaker mold. The mold cost more than a new ice maker, about $80.00.
25472320-3kd4nzpyfrydni0byqzalvn5-2-0.jpg Is this what you have? Go into the internet and you can get a new icemaker for about $40.00.
To replace: back off the two top screws. Remove the bottom screw. With a small flat head screw driver wedge into the back wall conduit connector and disconnect. Lift up and pull off the wall
Feb 23, 2015 | Refrigerators
Why is bottom drawer of refrigerator freezing shut
You have a clogged drain in the freezer from the defrost system. You will need to clear out all the ice, remove the rear wall and clear the drain under the evaporator as well. Failure to remove all the ice from the drain system will cause this issue to return. Good Luck
Jul 23, 2014 | Whirlpool Gold White-on-White 21.9 cu. ft....
How do you install whirlpool duet pedestal
Make sure that you get the pedestal designed for your washer. The white pedestal for the GHW9400P would be LAB2700MQ. (There are slight differences in the pedestals for different series washers. The holes in the base of the washer will not line up with the holes in the pedestal for a mismatched combination.)
First if your washer has been installed, uninstall it. You need to turn off the water. Then disconnect the power cord and (carefully) the fill hoses. Loosen the hoses first and then completely remove them. Drain the hoses into a bucket. Disconnect the drain hose from the back of the washer. Use pliers to squeeze the clamp to get the drain hose loose.
Pull the washer away from the wall. Cover the area behind the washer with cardboard and tip the washer onto its back (on the cardboard).
Pull out the drawer of the pedestal. Next snap the spacers into the holes on the top of the pedestal. (These are part of the hardware kit in the drawer of the pedestal.) Remove the shipping spacers from the front of the pedestal (behind the drawer). Remove the Philips head screw from the drawer slides and pull the drawer completely out (save the screws). Push the slides back into the pedestal.
Look at the washer and remove the feet if present. Partially install two of the hex head screws from the pedestal installation kit in the bottom holes of the washer. (These are at the center back of the washer if it is standing up.) Leave the screws about 3/8" from the bottom of the washer. Move the pedestal over to the washer and slide the keyhole openings of the pedestal over the two partially installed screws. Position the pedestal against the top of the washer and insert the remaining two hex head screws. Do not tighten completely.
Align the pedestal with the base of the washer on all sides. When it is lined up, tighten the 4 screws by reaching through the drawer opening of the pedestal. Bring the washer and pedestal back upright. Reinstall the washer (remove the packaging if this was a new install). Level (front to back and side to side) the washer using the pedestal feet (again reach through the drawer opening). Make sure that all 4 feet touch the floor. Tighten all 4 locknuts.
Pull out the drawer slides and reinstall the drawer. Reinstall the Philips screws. Close the drawer.
For pictures of the install, go to the Whirlpool support site http://www.whirlpool.com/owner_center . Search for your pedestal and get the installation manual. The direct link for the LAB2700MQ0 install is http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208537141.pdf .
I hope this helps.
Aug 04, 2011 | Whirlpool GHW9400 Duet Washer
How do I replace the cabin air filter on my 2005 Toyota Matrix?
For 2005 Toyota Corolla (and Matrix), the location of the cabin air filter is inside of the drawer (passenger side). Open the drawer, you will see a screw on the RIGHT hand side. Unscrew it with a cross shape screw driver. Unlock the drawer from the screw holder. And take the drawer out of the cabin. After the removal, you will be able to see the location of the cabin air filter. There is a lock at each side of the filter cover. For each side, use two fingers to pinch the lock and pull out the cover. You will see the old filter after removing the cover. Pull it out, and insert your new filter.
Put the cover back. Make sure the two locks are firmly locked. Put the drawer back. To make this work easier, you may lock the bottom of the drawer first, as there are TWO locks on each side of the bottom drawer. Close the drawer to see if the position is right. Place the screw back, that's all
May 23, 2011 | Toyota Matrix Cars & Trucks
I have a 4 draw Plano Tackle box as I have something stuck behind I can't close bottom draw,can you tell me how to remove draw as I've tried and cannot remove regards Sno
Use a long flat blade screw driver with a 1/4 inch blade. From either the right or left side, with the top drawer fully open, take the screw driver and place the blade between the inside of the outer casing and the drawer guide and gently pry the casing away from the drawer guide and pull the drawer open until you release the side catch on the drawer. You only need to free one side, and the drawer will sort of pivot out and the other side will be free at that point as well. Repeat for the rest of the drawers except for the bottom drawer which you will be able to access anything behind it as the upper drawers will not longer be blocking access when removed. I had a small bag of sinkers sitting on the bottom.
Feb 16, 2011 | Plano Four Drawer 757 Guide Series Tackle...
My side by side GE is leaking water on the freezer side. It is coming in from bottom and water is freezing under the drawer.
You have a stopped up and or frozen defrost drain line. Pull the bottom drawer out and look for ice underneath the bottom of the back wall. This is where the drain hole is. Thaw this out and make sure that the drain hole is not blocked. Water should pour through this hole freely when it is working properly.
Jun 27, 2010 | Refrigerators
Climate control drawer is 20 degrees, freezes everything,
on the bottom part of refrigerator right wall , theres a thermister, i bet is faulty
Jul 11, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Whirlpool duet washer model GHW9400PWO
Removing the Washer Top
Three screws secure the washer top at the back of the washer. Remove the three screws and lift the top from the washer.
Removing the Console from the Cabinet
Disconnect the Touch Pad/LED Assembly ribbon connector from the left side of the Central Control Unit and release it from the wiring harness brackets on the right side of the washer top
Remove the detergent dispenser drawer by pressing down on the release tab at the back of the drawer and pulling it completely out of the washer.
Once the drawer is removed, remove the screw in the recessed hole next to the drawer opening. Release the tab securing the right side of the console to the washer
Open the washer door and place a flat-bladed screwdriver into the slot in the bottom center of the console. Push the console up to release center console tab. Be sure the ribbon cable clears the cabinet frame.
Removing the Touch Pad/LED Assembly from the Console
The Touch Pad/LED Assembly is removed as a single unit and contains the Push Buttons, LEDs, cable, etc. The buttons can be replaced separately
Jun 28, 2008 | Whirlpool GHW9400 Duet Washer
Bottom drawer hard to close
Check the drawer slides on each side for cracks or a screw that has come loose. The drawer should slide in a groove on each side firmly. Hope this helps. JT
Oct 10, 2007 | Miele 3.7 cu. ft. / 105 liter Upright...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
115 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
