Question about Intel D915PBL Motherboard
Whistle when starting the computer there is a loud whistle and then it shuts down
  • ishoot4u Nov 07, 2008
    my computer makes a loud whistle or screach and then shuts itself down
    Sergeant:
  • 306 Answers
The POST (power on self-test) routine checks the video card, RAM, keyboard, etc. and makes a series of beeps which if there are alot of beeps may sound like one long screechy sound. Reseat the video card if you are using an AGP card, the RAM, check the CPU release lever on the side of the socket as well as the heat sink/fan, the drive connectors and the keyboard. If it still screeches then remove all but one RAM stick, the drives except for one drive, if you have an onboard video connector use that and remove all other PCI cards and the AGP card. If no onboard video then leave the video card in ensuring that it is lined up and seated properly and connect the keyboard. Doing those steps should fix the problem or isolate the problem to the faulty component.
Posted on Nov 08, 2008
My 93 jeep grand cherokee laredo 5.2 has a loud whistling when accelerating. It has killed my fuel economy and i have no power when down shifting. I have already checked all fluids
Possibly the catalytic converter is plugged/broken up. I have seen this several times. It will idle fine, then when accelerating, it will whistle loudly and will not accelerate very well. Exhaust is your problem.
Apr 03, 2016 | Jeep Cars & Trucks
Vw sharan loud whistling from front of car
one of the cabin seals has come lose or part of the plastic under the windscreen has a gap, can happen with plastic. just need to reseal the gap or refit it and seal at the same time. its body panel sealer can get it in a tube for a sealer gun or you can get the brush on type from most car part stores.
Nov 28, 2017 | Cars & Trucks
Whistle in computer
Bogus unit - return it for another.
Aug 21, 2017 | E-Machines eMachines Desktop PC
96 ford prob gt whistling very loudly when accelerated
IAC idle air control valve is not working. Let me know how you make out?
Jun 20, 2012 | 1996 Ford Probe
2002 merc cougar 2.5 liter has loud whistling
Sounds like a vacuume leak, use some carb cleaner in a spray can and gently spray the engine. When you find the leak the engine will stumble, check in that area for the leak.
Apr 26, 2010 | 2002 Mercury Cougar
Whistling from engine
This is a symptom of the inlet manifold gasket having a leak.The whistling is air going in through the small leak/hole in the gasket.With the throttle butterfly shut,air is getting sucked in the only way it can.Try tightening the inlet manifold bolts 1st.But more than likely the gasket needs replacing.Hope this helps
Jan 09, 2010 | 2000 Jeep Cherokee
Loud whistling noise from back of vacuum
On the back side of most kenmore vacuums, there is an air relief diaphragm that, when the motor is sucking but there is no air flow, will pop, causing the sound you heard. check your hose for blockage, check your bag and or filter for blockage,even your attachments/wands can become lodged with debris. Often, after a few, the motor will get hot and the machine will shut down. This is a thermostat on the motor that protects it from overheating. I am quite sure that this will solve your kenmore woes, fine choice in vacuum, kenmore, tried and true. hope to have helped! Have a super, and hopefully sucking(ha ha) Sunday
Jan 03, 2009 | Kenmore 34720 Upright Vacuum
Intel D915PBL Motherboard Logo
113 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
