Question about Rangemaster 110 (Gas) Kitchen Range
Gas oven lights but goes out.
Hi there, I have a gas cooker that when I light it then let go of the oven knob the burner goes out. Any idea what is wrong? Any help is much appreciated. Regards Nikki.
I have a technogas cooker but the oven goes off from time to time do u have solution for this problem thank u
Posted on Nov 16, 2008
Push switch in and press button oven lights let go switch and oven goes out
Posted on Jul 30, 2010
I have a Frigidaire model FCG30B6Q0JWI-5A gas stove (Made in Costa Rica) and can't get the oven to stay lit. There is no electronic ignition, no pilot, it's just a regular run-of-the-mill light a...
While your holding in the knob after lighting the pilot,their is a thermocoupler that is heating up and will hold automatically what your pushing in, that thermocoupler is defective
Jul 28, 2011 | Ovens
I have a belling gas range cooker and only one of the ovens lights properly. The other one when I turn the cooker knob and hold it the gas comes through,it lights but as soon as I take my finger off the...
When the oven lighting mechanism lights the gas, the flames heat a temperature sensor that, once hot, increases the pressure in the sensor's copper pipe and opens a safety valve to allow gas to continue to flow without you holding down the button (It's made like this so, if your flame gets blown out, the sensor cools and cuts off the gas supply, making it safe from gas leaks). These sensors occasionally fail, and very sensibly "Fail safe" - No pressure in the sensor pipe, the valve won't stay open and there is no gas to the burner once you release the button.
If you take a look inside the oven at the back where the burner is, you will see the sensor, usually the bit that is in the flame is cylindrical, about an inch long made of metal about 3 or 4 mm thick, tapering at the end. It will be held in place by a nut that fits on a thread at the base of the sensor. Running from the sensor is a copper pipe that runs to the cutoff valve. Unbolt the sensor and withdraw it from the hole it is mounted in, trace the copper pipe back to the valve (where it is usually screwed into the valve with a 10mm connector that looks like a car brake pipe connector. Unbolt from the valve. These sensors are widely used on most gas appliances (Boilers, gas fires, cooker hob burners and patio heaters all use the same kind of sensor). You should be able to get a replacement from any gas appliance service agent. If you go into a shop, take it with you. The only thing you need to do is make sure the replacement you get is long enough. If you are offered one that is slightly longer, that
Jul 22, 2011 | Belling FarmHouse 931 Gas Kitchen Range
Just bought a Leisure Gourmet Classic gas cooker. Connected the gas and plugged it in but none of the burners will light. The ignition is working but no gas is getting through. Any ideas folks? TIA, Andy
I had a similar problem when my new Leisure cooker was installed last December. The burners would light when I held the knobs in but when I let go the flame would go out. The engineer took off each of the burner knobs and stuck a small wad of aluminium foil between the inside of the knob and the contact on the front of the cooker - he said it's a design fault and the gap is just a bit too large for contact to be made reliably. This fixed the problem and I've had no trouble since.
Jun 22, 2010 | Ovens
Oven won't light - electronic ignition oven
Hi, it could be your, electric heating element and oven burner gas valve. both are located in oven burner compartment, remove last bottom panel, locate oven burner, the valve that feed gas to burner, has two wires connected to it, that's oven valve could be faulty, also look on side oven burner, you will see electrical heating element, could also be faulty, it's better to replace both oven valve and element, that's the most common problem, but first check oven thermostat, that's knob you turn to light oven, if thermostat o/k, then it's your oven valve or heating element, (used to ignite oven burner) or call a mechanic, good luck.
Aug 12, 2009 | Kenmore 33169 Gas Single Oven
Belling G755 Cooker oven wont stay lit
I'll give this a go! With a cooker like this, you depress and then turn the control knob, press the ignition button and continue to depress the control knob for a few seconds. This is because a device called a thermocouple is heated by the flame and you have to continue to depress the control knob so that sufficient gas flows to heat up the thermocouple. If the thermocouple does not get hot or stay hot then the gas valve is automatically closed - stopping the gas. The thermocouple is a 'flame failure' safety device. If the gas gets cut off then the flame goes out and the thermocouple goes cold switching off the gas valve automatically. However, you are having to try and manually keep the gas going for a good five minutes. I would think that there is either a problem with the thermocouple or the gas control valve! Tony www.birminghamelectricsltd.com
Jun 18, 2009 | Belling Solitaire G755 Gas Kitchen Range
Rangemaster 110 gas cooker - RH Oven lights but doesn't heat up
Will the flame go out if you turn the control knob to the off position?
Sometimes gas cooking control knobs have two seperate types of control in the one knob. One control turn the gas on or off, one adjusts the variable quantity of gas allowed through a gap to your flame jets. Some control knobs can get gummed up and stick a little. The can be fixed by carefully taking apart the control knob, taking note of EXACTLY how everything goes back together and cleaning any gummed up bits. Then reassemble the knob and drizzle soapy water over the control to test for leaks. A leaky gas join blows bubbles and makes noise. Let me know if this fixes the problem.
John
May 08, 2009 | Rangemaster 110 (Gas) Kitchen Range
Oven lights on low flame but will not come up on high flame .cannon chester cooker.suspect by pass is not working. Do I need control knob/thermostat with the phial. Thanking you.
all gas range ovens have a small metal box in the back upper area of the broiler burner; a gas line runs into this box as do two wires; this is a "flame control " gas valve; the way it works is: after the pilot has been lit as you turn the oven temp control a heating element in the box causes a small valve to open allowing a larger amount of gas into the oven burner to ignite the whole burner If you can only get pilot flame on high replace this valve
Apr 26, 2009 | Ovens
Rangemaster 110 (Gas) Kitchen Range Logo
521 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Mike Carew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
