Question about Citizen Blue Angels Skyhawk Watch
Analog time set
Can't set the hands to correct time
  • mywatch Nov 17, 2008
    I have the same problem. The digital time on the watch is correct but the hands never match up.
  • mcman30 Dec 06, 2008
    I as well have the same problem where the minute hand is 15 minutes behind the digital
  • 8,404 Answers
Yours is a light driven watch?
If it is like my watch, you cannot set the hands as the hands are driven by the digital.
Posted on Nov 13, 2009
I have a disallignement of 10 minutes between the digital and the analogical time. The digital time is perfect how can I allign the analogical one?
You have to know that analog time "follows" digital time.Any hour/minutes correction on the display has direct effect on time/minutes hands.Some times, mostly after battery replacement,hands might have declination.That is why there is a function so called "Hands home position adjustment".Using this function you can align both hands to 12/00 position.If there is any declination (I think is your case) you can correct.Try to enable this function by pressing for 4-5 sec the upper left button(A) until "HAND SET" appears.If hands are not aligned exactly to 12/00 position, you must correct by pressing the lower right button (D) for forward movement or the upper right button (B) for backward movement.In fact, minutes hand is aligned,hour hand follows.When both hands are set to 12/00 (home position) press button A again.Time Mode returns to the display.Normally hands will now show exactly according to digital (display) time.I hope this will help.
May 23, 2015 | Casio WVA105HDA Wave Ceptor watch
I bought this watch in May of last year. For the last 3 months, every 2 to 3 weeks I have to reset the hand home position. Once that is done, I have to then reset the home city and time manually. What...
Hand home positioning normally has nothing to do with time setting.
Just set your local time and date and then you can do the hand home positioning procedure.This will not affect the time setting.If hands,after a while,do not show correctly,this means that the watch is under severe magnetic field, after severe shock or finally watch malfunction.
You must know that on this type of watches analog time follows digital time.
Feb 05, 2014 | Casio G-Shock World Time Analog Digital...
How to set analog time for casio SGW 400 h please help
Analog time follows the digital time on Casio watches.If this is not happening,try the hands "set to 0" procedure using the manual.
Mar 31, 2013 | Casio Watches
To adjust the analog time for ga-110hc-1a
Analog time follows digital time.Correctly set your local time and analog time will come up correctly as well.If not, try to run the hands alignment procedure (H-SET) following manual instructions.
Mar 02, 2013 | Casio G-Shock GW500A-1V Wrist Watch
Hi I have a g-shock watch, problem is that even though I have synced the time to the correct area (London) my watch appears fast. I feel the watch has the correct time because on the little digital display...
all you have to do is to set the analog time, to do this just simply press the mode button until the H-SET in the digital face appears then press and hold the adjust button on the upper left until the digital time appears, then press the upper right button until the analog time reaches the exact time of the digital. last, press once the adjust button... I hope this will help you..
Feb 05, 2013 | Watches
The digital will not sync with the analog hands on my g shock
same problem here.. everytime i adjust the analog clock it moved but the digital clock dont so it means i can correct the analog but i cant correct the digital clock please help us..
Dec 30, 2012 | Watches
I have the correct time set in the watch, the main analog clock shows the correct time, but the UTC analog hands19:00 when the UTC digital time is 12:00. How do I reset the UTC analog hour hands?
The hands are driven by the digital. It seems to me you have the wrong digital city. Please review the setting instructions for your Skyhawk at: http://www.citizenwatch.com/
BTW, I love my Titinimum Skyhawk
Aug 03, 2011 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
My radio controlled watch is exactly half an hour fast according to the hands, but the internal clock appears to be correct. This happened when I tried to adjust the watch to Canadian time
If I understood correctly this watch have a analog watch display ..and it is half an hour forward..but when you set timing or the alarm it behave normal ..and so the internal one is correct ..but just do not display the correct time on the analog one ...If it do not have any means to correct manually the analog watch ..I advice to try to remove all power and stop the indicators at the exact time ...(a sharp hour...) and power it back after the exact time it is forwarded ....This way the analog clock will be stopped..and the internal one will go on and will adjust at the spot by the radio time ..and you will have both timers in correct display ...If it does have buttons or so in the back ..try to correct them by hand ..
Jul 12, 2011 | Watches
How to set the hands to match the correct digital display on my Casio wave ceptor 2734 wva-104h watch
Setting Digital Time
  1. The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
    Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
    Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
    After the time is set, press the upper left button to exit the digital time setting function.
  2. Setting Analog Time
  3. You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
    Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
Aug 21, 2010 | Casio Watches
I can't get the clock hands to correspond with the digital time.
You must set the "Zero" position for your watch. Follow the instructions at this address and your problem should be corrected.
http://www.geocities.com/watch_crazy/skyhawk/setting/setting.htm
Good Luck
Jun 18, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Citizen Blue Angels Skyhawk Watch Logo
222 people viewed this question
Top Citizen Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
