Question about Sony STR-DB940 Receiver
Front speaker channel cut off
The front left and right speaker channels on my sony amp cut out a few minutes after the amp is switched on. there is a click every time it does this as if it was switching between speaker channels.the amp usually settles down after 15 to 20 minutes but it is annoying especially when using the full 5.1 surround set up.the front centre and rear channels are unaffected.will i need to have the amp serviced or is it an easily fixed problem? thanks stephen
  • Anonymous Dec 13, 2008
    I do have exactly tyhe same problem.
  • 3 Answers
Always check the audio cables with another set before you do anything else.
Posted on Jul 12, 2008
    Problem Solver:
  • 15 Answers
I lean toward an overhating condition since the unit does not go into protection mode right away, and then returns.
My thoughts are as follows...
1) The receiver needs better ventilation
2) The speakers are below the rated minimum nominal impedance, causing the amplifier to strain and overheat
3) There is a problem within the amplifier that is causing this problem - this is not user repairable.
I'd try another pair of speakers which are rated at 8 ohm nominal impedance and give it a trial. At the same time, monitor the heat output from the unit (note that modern amplifier sections do run hot). If the unit runs extremely hot at a low volume and still shuts down on 8 ohm speakers, it's time for service or replacement depending on value.
Posted on May 27, 2008
B channel cuts off after a few minutes
Speaker is blown or amp channel is. Swap channel connections from a to b, etc, and test channel again. If it doesn't clip you have your answer. If it still clips out, your amp has a blown channel.
Apr 20, 2014 | Pyramid Zpa150 1500-watt Professional...
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
The amps in the receiver turn off and on all the time. The center channel rarely works, and the left & right channels turn off & on every 10-15 minutes as well as the subwoofer output. Is there...
loose connections,issues. disconnect center and front speakers from this receiver. turn on with rear and subwoofer. horrible sound but the point is it will eliminate the speaker issues and confirm loose connection if the receiver continues to behave the way you described.I have repaired a few for loose connections.
Mar 01, 2010 | Sony STR-DE975 Receiver
Sansui QS-100 Problem with one rear channel
There are 2 250v 4a fuses inside the amp. They can blow and
that channel will cut out. Check the fuses.
Nov 19, 2009 | Audio Players & Recorders
Front right speaker got wet, started cutting out. at the same time the rear right speaker started cutting. switched the rear speakers to opposite channels and this caused the right to work and left to cut....
the speaker getting wet will short it out. Shorting the output on any amp will ruin it. there is a right and left chanel with 2 outputs. Right chanel is damaged.
Sep 30, 2009 | Boston Acoustics GT-42 Car Audio Amplifier
No sound out of front left speaker
front left channel power amp needs rpair
Jul 08, 2009 | Sony STR-DG510 Receiver
RCA cable use
You can plug into the left channel and it will feed both the left and right channels.
To confirm that it's feeding both channels, connect the speaker to one channel at a time. With signal fed into the left channel only, you should get sound when you connect the speaker to either channel.
Apr 18, 2008 | Sony XM-754HX Car Audio Amplifier
Wiring Diagram for Sony car amplifier XM-554ZR
You can download the installation manual from the link below: http://www.sony.co.id/support/product/xm-554zr?site=hp_en_ID_i It has the following diagram plus other hookup info... Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 14, 2007 | Sony XM-2150GSX Car Audio Amplifier
Sony STR-DB940 Receiver Logo
236 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
