Question about Akai PT4298HD Rear Projection Television
Turns on but not picture or sound. Power LED blinks
TV turns on but the Picture and Sound do not work. THe power LED blinks. Any thoughts?
  • Anonymous Mar 25, 2014
    tv turns on then cuts of led light has a steady blinking
Directly inside the tv on at the end of the power cord is a fuse needs replaced
Posted on Jun 15, 2007
    Sergeant:
  • 337 Answers
Your set might not be producing the high voltage it needs to light up the screen , it might be missing the supply voltage the supply volts to the output transistor ,if this voltage is missing is because the transistor is likely bad(shorted) and it has opened a fuse or a safety resistor.If you are familiar with tv service you have a place to check but you are not too familiar be safe and call a professional,high volts circuits are dangerous.
Posted on Oct 17, 2006
  • Omar Urrutia
    Omar Urrutia Oct 17, 2006
    Your rating is also important.
SOURCE:
How do I fix my Sony TV?
Sir
please one thing remember that red led blinking indicate specie fault please watch red light count and find the correct fault which is written below
Monitoring Items Number of Flashes of red led Main Power Supply Voltage Error 2
DC_ALERT1 3
DC_ALERT2 4
DC_ALERT3 5
Backlight Error 6
Internal Temperature Error 7
Audio Error 8
Digital FE Error 10
Trident Error 11
Balancer Error 13
T-CON Error 14
thanks
Sep 22, 2017 | Sony Televison & Video
Phillips 52pfl5704d turns on screen blinks, no video
The replacement board could be defective. Your TV worked fine until there was a power loss so its time to troubleshoot to find out how the power loss affected the original board in theTV. There could have been a power surge.
Dec 12, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Mitsubishi WD-62526 turns on-n-off
I would bet the illumination lamp has reached the end of it's life (~$40 online). Should be easy to replace. Also possible the ventilation vents need cleaning, which could cause the lamp to overheat and turn off.
Dec 12, 2013 | Mitsubishi WD-62526 Projection TV
Panasonic plasma tv turns on but no picture or sound
Same issue with - Panasonic TH-50PX70A , power UP with red standby, then power ON by remote - only Gives GREEN led blinking 35-40 times, followed by solid green led with no no picture no sound.
>> Solution; unplug Plasma from AC 10-15min, then plug in & power on to Red standby led,, At this point - Power ON tv while holding down both -Volume Down and F (function Select) buttons (front panel door) at the same time turns picture ON,all ok.
Jul 25, 2011 | Panasonic Viera TH-50PX80U Plasma TV
My 52 in jvc model lt-52x579 turns on but there is no picture or sound and about two seconds later the led light for the power starts to blink i tried to turn it off but it just keeps on trying to turn on...
Sound like the power supply board has gone out .Unplug the tv for 2 or 3 minutes and plug it in again and try to turn on. Some times they will come on .But It sounds like the PSB is going out .
Feb 14, 2011 | JVC LT-52X579 52 in. LCD TV
Samsung LA40A550 no picture and sound
Power supply board is dead.That the board,the power a/c cord go into it.Replaced the power supply board will solved ur tv power lite LED light indicator blinking and ur tv power will be stable and work again.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 04, 2010 | Samsung LA40A550 40 in. HD-Ready LCD TV
Sony trinitron tv
If you have sound but no picture it means that your power supply and tuner are working correctly. The number of times the timer LED blinks is the code for the problem with the picture. The computer will stop the picture and blink the timer LED if the vertical circuit stops working, if the picture tube is too weak or if the horizontal sweep has stopped. The set should be serviced by a qualified tech familiar with Sony sets.
Sep 03, 2007 | Sony WEGA KD-34XBR970 34" TV
Akai PT4298HD Rear Projection Television Logo
123 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
