Question about HP LaserJet 2840 All-In-One Printer
Error paper jam
I had a paper jam which I removed unit stills says there is a paper jam.I unplugged unit for a couple days plugged back in still getting same error paper jam.There is no paper jam in unit I rmoved the one piece that was jamed the pathway is clear now. Is there anything else I can do.My email :brenda.adams1@gmail.com
  • 27 Answers
Ellow bkadam,
there something little piece of paper stuck at you fuser there.that why appear paper jammed...try to open u fuser cover...maybe it can help
Posted on Nov 07, 2008
FS-3900DN rear unit paper jam
Hello, Power down the unit.Unplug power from wall. Power back up, if the error still happens, there is a small piece of paper somewhere, take toner out and look, or pull down back cover and look in there.
May 22, 2014 | Kyocera FS Office Equipment & Supplies
Message reads:-Paper is jammed in the product. Turn off the product, open the scanner unit, and remove the paper. See documentation.' I have checked for any paper jammed, but finds none. I have even u
Did you try unplugging the power cord and waiting a couple of minutes, then plug back in and see if the printer resets itself. Also try checking all the paths that the paper travels through the machine for any scraps of paper that may have torn off during the jam up. Sometimes a very small scrap will prevent printers from resetting themselves. Also disconnect the printer from the computer before unplugging so the printer doesn't receive any signal from the computer. It may not mean anything.
Dec 28, 2011 | Epson WorkForce 600 All-In-One InkJet...
Saying that I have a paper jam after I have
Try this :
turn off the printer
unplug the power cable
lift your printer up then put it in an upside down position
then shake your printer from left to right for about a couple of mins.
see if there's any foreign object stuck inside the printer.
After that
put the printer back to it's normal position
then plug the power cable in
turn on the printer
and check if you still have the error.
Feb 25, 2010 | Brother Office Equipment & Supplies
Carriage Jam on my HP Officejet 5610v All-in-One printer
If I move the carriages to the center of the bar they slide on (would be the center of the paper) and close everything it seems to re-load, I've had to do this several times over the last few years and so far it always works
Feb 09, 2010 | HP Officejet 5610 All-In-One InkJet...
Purge unit error 5c00 4 flashes
Reset will not clear a purge unit error. Sometimes you can remove the purge assembly and clean out all the ink covering the moving parts. You clean with just water, most times I just replace the purge unit, around $30.00
Dec 22, 2009 | Canon PIXMA® MP530 All-In-One Printer
Is saying clear paper jam when no paper is jammed , i have tried switching everything off and back on but still comes back, have checked all around for jammed paper but cant find!
Try this:
Unplug the printer from the wall and wait for about 5 minutes before plugging back in. This may be sufficient to cause a "hard" reset of the unit (turning the unit off and back on from the front panel switch is a "soft" reset as the circuit boards still have power to them.)
If that does not work, unplug again and look closely in the printer's paper path. There may be a small shred of paper hung that is blocking a sensor unit.
Nov 19, 2009 | Lexmark Office Equipment & Supplies
Paper jam and still won't print
Hi
Thanks for using FixYa. Before you can clear the error message, you must locate where in the unit the paper is jammed.
Unplug the machine for safety. Now follow these instructions based on where the paper jam is located.
1. Pull the paper tray out of the machine.
2. Pull out the jammed paper.
3. Reset the machine by opening the Upper Jam Clear Cover and then closing it.
If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
4. Remove the Lower Jam Clear Cover from the back of the machine. Pull the jammed paper out of the machine.
5. Put the Lower Jam Clear Cover back on. Make sure the cover is set properly.
6. Open the Upper Jam Clear Cover. Make sure that there is no jammed paper left in the corners of the machine.
Note: If the paper is jammed under the print head, unplug the machine from the power source, then move the print head to take out the paper. 7. Close the Upper Jam Clear Cover.
8. Close the output paper tray cover and slide it forward, then push the paper tray firmly back into the machine. While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 15, 2009 | Brother Office Equipment & Supplies
Paper jam
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
334
Jun 29, 2008 | HP Officejet 5610 All-In-One InkJet...
Paper jam
open all door in your printer , front and back. , look for paper stuck inside and remove it. Sometimes small pieces of paper are difficult to be found.
If it is a Laser printer, you will also need to remove the toner and paper try and look for jammed papert underneat.
Once you done, restart the machine.
If you still have paper jam error try unplugging printer from power outlet for 5 minutes then restart.
If you still get error, then either there is paper inside or your printer may be faulty.
Regards
Mar 15, 2008 | Computers & Internet
HP LaserJet 2840 All-In-One Printer Logo
939 people viewed this question
Ben Johnson
