Question about TMI Products Vizualogic 7 in. Headrest Pkg. Hummer H3 06-Up Ebony Leather/Video Car Monitor
Dvd player has fuzz in center of screen
When the player is powered up it has a fuzz in center square of screen. However i can play the dvd on passenger side and see the image on the drivers side where the fuzz isn't blocking it out. these are only a little over a year old. Installed by the Hummer dealer.
2 Suggested Answers
SOURCE: Invision DVD/CD/MP3 Player Monitor Ax 2005 Lincoln Aviator
I am having the same issue as clemmons....
if you were able to resolve, please let me know.
Posted on Dec 30, 2010
BLU RAY WONT PLAY ALL DISCS
Your problem is the firmware version. Contact Toshiba Tech Support 1-800-631-3811 they will send you a disk with a firmware update along with special instructions on how to update the unit. I had a similar problem and they send me the firmware version 1.013.
Jun 18, 2010 | Toshiba BDX2000 Blu-Ray Player
Everything powers on, it plays dvd's cd's and the radio but the screen won't come on and the little square at the bottom keeps flashing.
Hi.
That usually means that there is no video connection.
Check the video connections to displays and check the video connection at the back of the main DVD unit.
Regards.
May 28, 2010 | Kenwood Excelon DDX-7015 Car DVD Player
Cannot see the screen Philips DVP5990 DVD player. Setting problem
You may have probably turned on Closed Caption on your TV. Unhook the DVD player to find out if it disappears. If it disappears then Closed Caption is on on your TV. Turn off Closed Caption. If cannot find how, give me the brand and model of your TV.
Oct 30, 2009 | Philips DVP5990 DVD Player
Can't play DVD on VLC on HP Pavillion dv5 running Vista.
problem with DVD drive, HP has this problem, not only that, Drives for laptop doesnt suit to work long. if under warranty, try to change that as soon as possible.
Aug 12, 2009 | Computers & Internet
Can't play movie
There's a switch located on the rear of the dvd player in regard to prescan or something like that. Switch it OFF and the player should work fine.
May 19, 2009 | Memorex MVD2042 DVD Player
Ws65909 Mitsubishi Tv and Dvd player
First forget the DVD.
  • Go into menu
  • and find close caption (TURN IT OFF)
  • If you find (TEXT) TURN IT OFF
those feature specially TEXT is who creates that square. was created for original programers to allow broadcasters send signals. Is not used for anyone. that squre is the empty space to write down a note. as i said not needed there TURN IT OFF. refer to your users manual to get easiest to this area. and read more about it.
Apr 12, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Flashing square on screen
I have an upconverting 1080p extended detail DVD player. I just started showing squares on the screen as the previews and movie plays but shows FBI warning etc OK.Is the player ready for the "heep"? I just had it cleaned.
Feb 13, 2009 | Astar PD-3060 Portable DVD Player
Big white square appears when playing a DVD.
Check your Closed Caption settings. Either turn it off or change it to text 1.
Sep 16, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Freeze up on DVD
Hi vaffl I read your symptom this morning and it sounds like you might have a tracking problem. In order to confirm this problem remove the top cover. I would start by measuring the power supply voltages. Load a disc in the player and press play. See if there is any change in the voltage levels durring the time that the player starts acting up. Sometimes a faulty voltage regulator will cause this problem. I hope this helps you. Bruce
Mar 17, 2007 | Toshiba SD-V280 DVD Player/VCR
Black square on screen
Seems that you have to go into setup and look at the Closed Captioned screen set up.
Aug 27, 2006 | Panasonic DVD-F87 Multi-disc DVD Player
TMI Products Vizualogic 7 in. Headrest Pkg. Hummer H3 06-Up Ebony Leather/Video Car Monitor Logo
Top TMI Products Car Audio & Video Experts
greg benton
Tommie Jones
Level 1 Expert
Are you a TMI Products Car Audio and Video Expert? Answer questions, earn points and help others
