Question about Dell Inspiron 2650 Notebook
Slow starting Dell Inspiron 2650
It takes almost 30 minutes to start the window and sounds like the hard disk keeps running. Once the window is open, it takes several minutes to open a folder.
Every thing is slower than molasses running on a cold wintery day!
  • rhiis Nov 10, 2008
    This one is also so slow to up load any web site, and even slower to shut down, and to play a game is almost impossible.
  • 3,940 Answers
The first thing I would look at is hard drive free space. Almost universally, critically slow systems have a hard drive with no free space. What most people don't seem to understand is that Windows requires a minimum of 10% of the hard drive to be free space to allow the operating system room for swap files and other temporary files needed to run the OS efficiently. This can be made worst by the fact that Windows only reports the size of a file on the hard drive, not the amount of space actually allotted to the file (This has to do with cluster size and the fact that only one file is written to any part of a cluster and in this case it is small files that waste a lot of space)
Things you can do.
1. Run disk cleanup, and get rid all temporary files.
2. If you use an email client like Outlook/Outlook express, delete unwanted emails, then empty the deleted items folder.
3. Open Internet Explorer, Tools, Internet Options, delete all cookies and temporaty internet files.
4. Go to add/remove programs in control panel, uninstall any programs or applications you do not use.
5. If you have a large amount of pictures or music files on the system, burn them to CDs or DVDs and free up that space.
6. Go to System Properties, Advanced Tab, performance section, settings button, select Adjust for Best Performance, Click Apply, Click Advanced TAB, Virtual Memory, Change Button, Select System Managed Size, Click Apply close then reboot.
7. Go to MY Computer, right click C:, Click Properties, Tools Tab, Defragment the Hard Drive
8. Adjust power management to Maximum perofrmance.
Posted on Nov 09, 2008
Got Dell Inspiron 2650 2002 from a friend, free. Want to restore to factory settings. How? Installed Windows XP and Norton Anti Virus
Hi and welcome to fixya!
There are two ways to restore this machine to factory settings;
First is thru the Recovdery partition in the hard disk itself:
  • 1 Close any windows currently open and click the Inspiron's "Start" button. Select "Shut Down" and choose the "Restart" option.
  • 2 Tap "F8" when the Dell image appears on the screen. Continue tapping the key until the advanced boot menu loads.
  • 3 Scroll down to "Repair Your Computer" and press "Enter" to access the DataSafe local backup screen. Click "Next." Select "Dell Factory Image Recovery and DataSafe options."
  • 4 Click the "Restore without preserving new or changed files" radio button and click "Next." Click "Next" three more times and click "Restart" to restore the disk drive to its original condition. Follow the on-screen prompts to set your operating system settings.
If the hdd was already repartitioned or corrupted, the second option should work:
  • 1 Insert the Dell recovery disk in your Inspiron's optical drive and close the "AutoPlay" window when it appears. Shut down any other open programs. Click "Start" and select "Restart."
  • 2 Tap "F2" as soon as the Dell image appears on the laptop's screen. Scroll to the "CD-ROM" option and press "Enter." Tap any key when you see the "Press any key to boot" option.
  • 3 Press "Enter" when the setup screen appears. Press "F8" and highlight the Dell's hard drive partition. Press "Enter."
  • 4 Follow the instructions on the screen to choose the Inspiron's operating system options. Click "Finish" and remove the recovery disk from the optical drive. Click "Start" and select "Restart."
Hope this helps!
Takasashi
Jul 19, 2011 | Dell Inspiron 2650 Notebook
I just purchased the dell inspiron mini and it runs very slow. It takes about 5 minutes to completely start up and using Facebook seems to load it down and creep along. Is there something I can do to...
If you purchased this computer new ... return it and have the retailer make it right. If this is a previouisly owned computer, it might be worth the $75.00 to have the big box store take a look at it.
May 03, 2011 | Dell Inspiron Mini 10 Notebook
Good Day! I would like to ask for your help about problems regarding to my Toshiba Satellite 1801. My laptop is very slow, refreshing it takes almost 5 minutes and Opening a programs takes almost 15...
Welcome to FixYa!
here are some steps that you may follow .
1. go to start > run> type MSCONFIG
a window shall open and DISABLE all the items that are being run at START UP
here are caps
See if that helps you ?
More over have you tried installing a Anti-virus.Cause sometimes Virus make the computer slow.
, as a tip De-fragment your hard drives time to time.if virus has hit your computer try installing a fresh copy of windows and then installing Anti-virus .let me remind you when you install a copy of windows do not attempt to open any drive cause there are auto-run viruses. so you first clean your computer then go to other drives clean and safe.
Do comment if it helped you in ANY MANNER !
Apr 13, 2011 | Toshiba Computers & Internet
I get this problem and can't get past it help please Unmountable_boot_volume its a problem with the recovery system a blue screen for dell inspiron 2650
I sure hope you kept a recent backup. Something has gone terribly wrong in there. If you didn't keep a recent backup, do you still have the Windows setup disk(s), or the Recovery disk? It sounds like you will need to do one of those. STRONG ADVICE_ DO NOT start to run a Recovery or Resoration disk NOR a backup and then stop it part-way done! I did that recently, and it took me 3 months to find a solution. It deletes all your partitions. Then nothing will work without much research and work. Once you start a recovery from a disk or a backup, let it finish! It may take awhile, but it's worth it. Don't panic. Just do a backup restore or a restoration disk, and any lost data, will be lost. People call using the Restoration CD a "reformat". It gives you a fresh install of Windows. Try to always keep a recent full partitions backup, it's worth it's weight in gold. Feel for you!
Dec 21, 2010 | Computers & Internet
Dell inspiron 2650 frozen on blue welcome page
try this...
turn on the laptop,,,
keep pressing F8
a menu screen will appear,, select SAFE MODE using the cursor keys and hit enter,,
once it boots in safe mode click no to use system restore..
follow the onscreen instructions to send it back to a date when it did work,,
it will shut it self down and restart in a propper manner..
if that fails,,
when u turn on the laptop it displays a menu,, it shows to press a certin key to enter system recovery,, press that key,,
follow the onscreen instructions to restor the laptop to factory condition..
Jun 03, 2010 | Dell Inspiron 2650 Notebook
I have a working Dell Poweredge 2650 with 2 x Xeon 1.8Gig processors, 5 x 36GB hard disks, running Windows 2003 Server. I have recently purchased a newer Poweredge 2650 with the same configuration except...
You should be able to do this by moving the drives all at once ALL DRIVES MUST BE PLACED IN THE SAME SLOTS 0,1,2,3,4, do not mismatch else it will be a nightmare ............HOWEVER BACKUP your data up if you are going this route,on paper it might sound like a winner,however not all that glitters is gold.controllers though they might be the same have different firmware which allow them to do different things,so if you are going to this the os drive raid 0 or 1 must be two seperate is drives.once this done,how is your raid set up for the other drives once you have a good back up to restore if there is any complication,move the over in the same order,remember POWER DOWN BEFORE YOU ATTEMPT THIS .PS REBUILDING TAKES FOREVER.
GOOD LUCK
Jun 08, 2009 | Dell Refurbished PowerEdge 2650 Server
DISK DEFRAGMENTER WON'T START
Try disk cleanup, do anything to improve memory, turn off everything except defrag. Check task manager, it'll show you what's using memory.
Apr 04, 2009 | Dell Inspiron 2650 Notebook
Dell inspirion 2650 does not for mat hard drive it
you might have to Debug and then format the hard drive heres the link for debuging the harddrive and then try to format..hope this helps.
http://en.community.dell.com/forums/t/19020652.aspx?c=uk&l=en&cs=ukdhs1&s=dhs
Regards,
Khushroo
Mar 09, 2009 | Dell Inspiron 2650 Notebook
Keyboard
Try this:
Shut down, unplug the AC adaptor, removed the battery, and hold the power button for up to 1 minute to discharge.
Make sure there are no stuck keys.
Restart.
Apr 08, 2008 | Dell Inspiron 2650 Notebook
Inspiron 1150 Slow startup, slow printing, unable to run 2 programs at once
What Operating System do you run? If it is Windows XP SP2 (Home Edition or professional), here are some things you can do to speed up your system. 1st you should remove all programs that are not required from the start menu. Start > Run > Msconfig > startup tab. Unselect all that are not necessary. Also Right click on my computer > properties > Advanced > Performance settings > Adjust for best performance. This should speed things up a little. I would recommend atleast 512 MB of memory to run Windows XP and its applications decently. You should consider an upgrade.
Dec 20, 2007 | Dell Inspiron 1150 Notebook
Dell Inspiron 2650 Notebook Logo
355 people viewed this question
Alun Cox
