Question about DXG Technology DXG-321 Digital Camera
Not functioning I've changed batteries a couple of times thinking this was the problem; no help, When I slide the back to use the view finder, the camera should turn on. Absolutely nothing happens. It acts totally dead. Is there an "internal" battery that I'm not aware of? Thanks. Danni
0 characters
1 Points
Fujifilm FinePix S1600 The monitor display is not working. Can it be replaced and if so how easy is it?
It could be that you have it set for EVF which means that you are using the tiny view finder instead of the LCD screen? It should have a button close to the view finder labeled EVF/LCD, you can alternate between the LCD screen or the tiny viewfinder? This function if mainly to conserve battery power or if you are out in the sun and cannot frame a shot and so you use the view finder like the old cameras, hope this might help you?
Dec 09, 2014 | FUJIFILM Digital Cameras
My camera was working fine one day and would not come on the next time I tried to use. I've put new battery in and this is not the problem. Can you help?
Do you hear anything when the camera is turned on? Perhaps you're just not seeing the display on the View Panel? When you flip a tiny switch, which I've done accidentally, it turns off the panel display so that you can only look through the view finder. Each camera is different, so be sure to check your manual to locate this switch.
After you turn the camera OFF. You may also want to check your battery placement. One incorrect placement will cause the camera to be "dead". Also look into the battery compartment to make sure a battery has not leaked on the leads. If you can't see the metal on any of them you may want to carefully clean it using a small Q-Tip or a pencil eraser. If you use an eraser be sure you get all the left over residue out of the chamber afterwards.
You've probably already tried these things, but hopefully it will help to get your camera working again.
Apr 22, 2011 | Fuji FinePix S3000 Digital Camera
Images thru view finder are blurry
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Oct 04, 2009 | Canon PowerShot A60 Digital Camera
LONG wait periods between shots... r11
change your setting to auto and see it that helps
Jan 04, 2009 | Nikon D50 Digital Camera
Camera not functioning after power on
Firstly switch off the camera
press and hold the ok button and turn the camera on and off for few times
whilst keeping this button depressed
Jul 20, 2008 | Nikon Coolpix L11 Digital Camera
No image through view finder or LCD
Have you checked to see if the mirror is in the UP postion?
May 05, 2008 | Nikon Coolpix 5700 Digital Camera
Query Regarding No Display on LCD (view finder) in Canon Digital IXUS 750
With the camera on, have you tried pressing the DISP button once? It's the lower left button on the back of the camera. It manually turns the display on or off as desired to save batteries (you can then aim through the optical viewfinder).
Mar 02, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon S1 IS view finder / LCD monitor black out
This is a defective CCD that Canon is repairing free of charge. Go here for details:
Nov 24, 2006 | Canon PowerShot S1 IS Digital Camera
DXG Technology DXG-321 Digital Camera Logo
18 people viewed this question
Top DXG Technology Digital Cameras Experts
Derick Williams
Level 1 Expert
Are you a DXG Technology Digital Camera Expert? Answer questions, earn points and help others
