Question about Epson Stylus Photo R220 InkJet Printer
RX700 Is there a way to reset the protection counter on the rx700?
  • Anonymous Mar 07, 2009
    i rest the protection counter with ssc service utility,but after a few prints the counter says 1200,so obviously this programme dont waork
    Genius:
  • 1,447 Answers
Hi-
Yes pls call 562-276-4382 or refer to your manual regarding the reset.
Hope this help
Posted on Nov 08, 2008
Services riquierd error
your printer is need to reset firmware, don't panic it easy to do, go to net and search ssc utility for epson and installed it to the to your computer its free, after you download and installed connect your printer to pc and run the reseter. select reset protection counter. and restart your printer, then can print
Jan 29, 2013 | Epson Stylus Photo RX700 All-In-One InkJet...
Screen showed message that "parts
The message that you received indicates the ink pad absorbers are full and prevents the printer from running because unchecked it would leak ink everywhere including outside of the unit. To fix this you need to replace the pads with new ones and reset the counters to let machine know you have changed the pads. On top of that you must download a utility program for your model that will allow you to set up the counters so the printer will run. I strongly recommend replacing your printer especially when it is a refurbished item, even Epson feels it is better to replace.
Jan 08, 2011 | Epson Stylus Photo RX700 All-In-One InkJet...
End of service life error message epson inkjet printer RX700
This refers to the internal counter, actually located in the software on the computer determing that your waste ink pads are likely saturated and need replacement. You can download software from either Epson at http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp or at http://www.ssclg.com/download/sscserve.exe. Both of these software packages will allow resetting the counter. However one should either take the printer in to an authorized Epson or independent printer service company or if comfortable with messing around inside computers and peripherals, one can check the waste ink pad(s). On the RX700 there is a small access panel, on the back of the unit, on the left hand side when facing the back of the RX700. It is held in place with a Phillips head screw and small plastic latch tab on its bottom side. The pad material is clearly visible from here, with a pair of clear plastic waste ink tubes directed down into this waste ink receptacle. If this is saturated, wet and discolored, it should be replaced, before resetting the counter. Not doing so risks the excess waste ink overflowing and making a mess and possibly even shorting out some of the circuitry.
Sep 18, 2010 | Epson Stylus Photo RX700 All-In-One InkJet...
Service error
All you have to do is uninstall the RX700
and reistall again. The waste ink counter is in the computer. I found this out when the error lights did not light with the parallel plug out.Off-course you will have to do the same with ssc. This time keep resettting the waste.
Aug 15, 2010 | Epson Stylus Photo RX700 All-In-One InkJet...
Epson RX700 printer, end of service life message
This usually means that the waste ink absorbers are full. If your printer is under warranty, you can get them dealt with and the counter reset at an Epson Customer Care center. If your printer is out of warranty, you should consider if it is worth the fix. You can get this done by Epson or an independent printer repair person. (They might sell the parts for a dyi job.)
Once that is done, you can get a reset utility from the following URL: http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp . If you execute the reset without the pad replacement, you will get ink smearing on your documents after a while.
I hope this helps.
Jan 29, 2010 | Epson Stylus Photo RX700 All-In-One InkJet...
How to Solve Both Red Light Blinking Problem in Epson R230
Blinking alternately or not? If alternately, see status monitor. It may be end life service (waste ink pad full). Reset waste ink counter using Rx700 adjusment program. If not, it may be a general error.
Nov 12, 2009 | Epson Stylus Photo RX700 All-In-One InkJet...
RX700 Ink drip reset counter?
which buttons do I press when turning on my RX 700 after changing the ink pads which will reset ink drip counter? Thanks
Jun 02, 2009 | Epson Stylus Photo RX700 All-In-One InkJet...
Epsion stylus r230 series had got problem it refers that service
This is a standard problem for all Epsons sooner or later.
Your options are simple:
1. Take it to an official Epson service center and pay rather a lot of money to have the waste ink pads changed
or
2. Locate the SSC utility here:
http://www.ssclg.com/epsone.shtml
.. install and then follow the instructions for resetting and clearing the protection counter settings.
You will still need to decide what to do about redirecting your waste ink but there are plenty of resources for that if you look around google using the keywords: "epson waste ink kit"
Whatever you do, don't ignore the waste ink as it will overflow eventually.
Hope that helps.
Feb 20, 2009 | Epson Stylus Photo RX700 All-In-One InkJet...
Epson Rx500 waste ink collection pads cleaning/renewal......can this be done DIY If so can you advise with detailed method etc Regards Tibbs
The same instructions available all over the internet for the R300 should suffice for the RX500...
In terms of resetting the waste ink counter, the SSC utility will provide the necessary compatibility as well...
Apr 13, 2008 | Epson Stylus Photo RX700 All-In-One InkJet...
Epson Stylus Photo R220 InkJet Printer Logo
101 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
